Interesting Quadrant Chart
Discussion in 'Modern EPA Stoves and Fireplaces' started by Oldhippie, Dec 9, 2013.
  1. Oldhippie
    Oldhippie
    Ashby Ma
    Just proves the numbers really aren't meaningful or prove any point. But the question about why wasn't BK on the chart is interesting, because they are clearly a competitor to the same market, and (I think) BK would actually look poor on that chart, by their own numbers they publish on their site.
    What would be really cool, would be if someone (like consumer reports) actually did a consumer reports like chart, with all of the meaningful metrics. You know the ones that have all the little circles that are either filled in or not, depicting 5 levels of good or bad for each item.
    I wonder of someone has done one of those.
  2. bogydave
    What are the meaningful metrics?
    Can we come up with a list of the top 10?
    Ease of loading
    Ease to empty
    Ease of operation & control the burn
    Heat out put range.
    Burn times
    Heat movement/fans
    Glass door clean? .?
    Come up with more &/or better ones?
  3. bogydave
    Can we make one, have each of us fill it out for our stove/s we are using.
    Grade 1 poor thru 5 excellent. (1 thru 10 )
    10 , 15 or so things to grade.
    Then a little blurb for comments of good thing you like
    Bk easy to control the burn & heat output with the thermostat
    & things you'd like to see improved.
    Like the smokey glass on the bk & smoke out the top of the door on reloads
    Trilifter7 likes this.
  4. concretegrazer
    concretegrazer
    Southwest MO
    Add maintenance to the list.
  5. bogydave
    Ease of loading
    Ease to empty
    Heat out put range.
    Burn times
    Heat movement/fans
    Maintenance
    Ease to find/replace the cat
    Dealer support
    BrianK and Trilifter7 like this.
  6. bogydave
    We tried to get it going. I fanned the embers pretty hard, not many hot coals got going.
    So did Brian.
    Hope no one took Brian & my jibbing & jabbing for more than it was.
    We were having fun in case someone thought it was more.
    I like/follow Brian's thread on his Woodstock Beta testing & he follows my BK operation & performance.
    Of course my BK has been proven & he's still in the test mode. LOL :)
    BrianK likes this.
  7. Oldhippie
    Oldhippie
    Ashby Ma
    All of us on the east coast went to sleep. But I think this is a good idea.
    Some others are:
    Price
    Capacity options - small/med/large categories
    Clearances
    Install flexibility - top flue exit/back flue exit
    Wood loading flexibility - Top load, front load, side load - Side load, left/right option
    Attractiveness
    Another thought, there needs to be a weighting factor multiplier to each metric, as some are going to be much more important than others for each buyer. For instance, some people have clearance as critical need, others not so much, so top exit/rear exit is or isn't important.
    This could be a very interesting chart. Another reason for weighting, is course some metrics are so subjective as to be only set by the buyer. Example: attractiveness - some people would call a Woodstock Fireview ugly (or course they would be wrong :)) others would call it beautiful.
  8. sherwood
    sherwood
    Ease of operation and control, quality of build, and how well it heats a home similar to one's own are to me by far the most important factors. By far. I would like to see data on actual temperatures achieved in the same condition in similar homes by different stoves. That's the only metric that I think is REALLY subjective at this time. We just don't have factual comparison data. We have statements about heating ability from people we trust, but we don't know how B's stove would do in A's home. Having that information would be immensely helpful in the stove shopping process.
  9. BrianK
    BrianK
    West central PA
    trog·lo·dyte
    ˈträgləˌdīt/
    noun
    1
    : a member of any of various peoples (as in antiquity) who lived or were reputed to live chiefly in caves
    2 : a person characterized by reclusive habits or outmoded or reactionary attitudes
    1. — trog·lo·dyt·ic
    milleo and Oldhippie like this.
  10. Oldhippie
    Oldhippie
    Ashby Ma
    LOL!! :rofl: :lol::rofl: :lol::rofl: :lol:
  11. bogydave
    15 features so far. Any more important ones?
    Wood stove features list:
    Rate 1 (low ),2(med) or 3 (high) for importance to you . Then 1 (low) thru 10(meet or exceeds) for how your stove meets the feature.
    Ease of loading
    Ease to empty
    Ease of operation & control.
    Ease of installation
    Heat out put range.
    Burn times.
    Cost $$
    Heat movement/fans
    Maintenance
    Dealer support
    Attractiveness
    Clearances
    Tough & well made
    A comment section:
    little blurb for comments of good thing you like:
    & things you'd like to see improved:
    Less smokey glass on the bk & smoke out the top of the door on reloads
    Gonna need some help defining the features.
    Like, what do yo mean by clearances, ?
    For "maintenance", what maintenance items?
    BrianK likes this.
  12. Oldhippie
    Oldhippie
    Ashby Ma
    I haven't played with a spread sheet for sometime, but I am going to see what I can do with this tonight as a first pass.
    BrianK likes this.
  13. bogydave
    Started new thread
    "wood stove features list"
    Got a basic excell sheet started, not sure how to attach
    Used a screen grab picture
  14. Backwoods Savage
    The problem with so many "features" and having them compared or rated is that it would be impossible to keep personal bias out of it.
    What I'd like to see would be a comparison of stoves using different types of wood. That is, btu output and burn times. But again, this would be difficult as one would need to be certain with chimney heights, straight vs elbows, etc. Fact is, there are so many variables that it would be too time consuming and difficult to compare simply because you can't burn a load of wood in one stove then turn around and burn that same load in another. Then there are the variables of outdoor and indoor temperatures, trying to get the same would really be tough. We could go on and on and still not come to a definite conclusion; sort of like Congress.
  15. bogydave
    Send one of the new steel stoves here.
    I'll put in another chimney next to the one I have.
    Do a test side by side with the same wood (2+ year birch) !
    You all could send me various wood types to test :)
  16. bogydave
    Just be as honest as you can , we're human, some bias is expected.
    There are thing about the BK model I have that I 'd like to see improved on.
  17. Oldhippie
    Oldhippie
    Ashby Ma
    Dave, you are so nice to offer!! Don't be too surprised if one shows up on your front door! :axe:
  18. bogydave
    Would be a fun thing to do.
    Definitely get to burn the black off the glass :)
    We still get winter here :zip:
    Send white oak, hickory & locust for the first 2 year test LOL :)
    Oldhippie likes this.
  19. sherwood
    sherwood
    See a problem with "Burn Times". I assume you want to know what they are, as well as how important & how your stove rates. Burn time may be very important to you and to me, but my need and wish may be for a 12 hour burn time, while your need and wish may be for a 24 hour burn time.
  20. mywaynow
    mywaynow
    They are not there to provide meaningful information. Control yes. Red tape, for sure.
    BrianK likes this.
