I'm ready for a chain grinder
Discussion in 'Chainsaws and Power Equipment' started by CtRider, Feb 29, 2024.
  1. John D
    John D
    Syracuse ny
    In reality probably not much I have heard a lot of good things about the harbor freight grinder and I have heard a lot of good things about the Chinese copy of the Oregon grinder you can buy on Amazon for around a 100 bucks
    Screwloose likes this.
  2. Eggshooterist
    Eggshooterist
    Erff
    I had the harbor freight grinder. I set it out by the road.
    Screwloose and John D like this.
  3. John D
    John D
    Syracuse ny
    Really what was wrong with it I am just asking I have a jolly grinder
    Screwloose and Eggshooterist like this.
  4. Eggshooterist
    Eggshooterist
    Erff
    Only one adjustment for cutter angle, inaccurate from left to right without modification, only one size wheel available from harbor freight, all plastic and flexible. I got it for $10 used. You couldn't give me another. I preferred hand filing with my Stihl 2-1 sharpeners. Much better results. I'm picking up a lightly used Tecomec super jolly Saturday.
    Mrxlh, John D, JD Guy and 2 others like this.
  5. Highbeam
    Highbeam
    Yeah, I've never had a problem with needing more than one adjustment for cutter angle or lack of left to right accuracy or the one wheel size. The flex is actually something I use to my advantage so that's fine too.
    I would hope that spending 3-10x as much on a grinder will give some people some improvements but we'll all still get the wood cut. Maybe the professional sharpeners that do this for a living see some benefit.
  6. Eggshooterist
    Eggshooterist
    Erff
    The other issue I had with the Harbor freight grinder is the inconsistent clamping of the chain holder.
    John D likes this.
  7. John D
    John D
    Syracuse ny
    Thank you for your information
    Always can learn something new
    Eggshooterist likes this.
  8. Eggshooterist
    Eggshooterist
    Erff
    You're welcome bud. The clamping thing was irritating. It would change the tooth position from cutter to cutter if you didn't pay attention.
    John D likes this.
  9. KSPlainsman
    KSPlainsman
    Kansas
    I'll be curious to see if the Super Jolly rocks your cutters a bit. Mine does, but I've got a good system that alleviates it. Just something to keep an eye on when ya get it.
    Eggshooterist and John D like this.
  10. John D
    John D
    Syracuse ny
    Is the head a little loose I now you can shim them
    KSPlainsman and Eggshooterist like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Thanks for the heads up. I'll be paying attention.
    KSPlainsman likes this.
  12. John D
    John D
    Syracuse ny
  13. KSPlainsman
    KSPlainsman
    Kansas
    Yeah, it does have a little play, but I use it to my advantage a bit. Mine, you have to try to make it move side to side. It's not a sloppy type of play, if that makes sense.
    John D likes this.
  14. CtRider
    CtRider
    Ct
    28" standard husky bar
    John D likes this.
  15. 0rion
    0rion
    I don't use the clamp on mine. I just use my left hand to pull and hold the chain against the stop. Ignorance is bliss in my situation I guess haha. Like I say...I'm a hobbyist at best so I definitely don't know more than the bare minimum and I'm always willing to learn. Like someone else said (which may have been in jest) I actually do use the flex of the harbor freight head. I set it a little tight and flex it to the right to get the bottom of the tooth and let it come back into the cutter as I bring it out.
  16. Yawner
    Yawner
    Louisiana
    Found an Oregon 511a for sale for $100, is that a good deal?
    Chaz likes this.
  17. Eggshooterist
    Eggshooterist
    Erff
    Id say yes if its complete. A quick search shows $380-480 new
    Chaz, KSPlainsman and John D like this.
