I'm out!
Discussion in 'The Wood Pile' started by Creekin, Mar 2, 2019.
  1. Creekin
    Creekin
    Manitoba
    After a long cold snap, i went through way more wood this season than I would have thought, last night loaded the last of what I had that was dry-ish
    Hoping to cut up some logs this morning
    Had to work till lunch, figured pick up some chains for the saw after and get to it. Well made it to the saw shop and didn't realize they closed at noon, dang it!
    Went to my buddies place and mentioned I needed wood, he said I could have all the poplar i forgot to pick up in fall all bucked and stacked!
    Got at least a cord and a half brought home
    Will get me going for a bit till get sone cut, (i know its not ideal but....)
  2. yooperdave
    Now dat ain't good....no like.
  3. Chaz
    Chaz
    Southwestern NY
    Well that isn't great at all Creekin
    :doh::hair::hair:
    At least you have some of that poplar wood, beats nothing for sure.
    :fire:
    Hope you can find/harvest some standing dead wood.
    :saw::axe::stacker:
  4. TurboDiesel
    now, about that hoarder card...:whistle:
  5. Creekin
    Creekin
    Manitoba
    Sometimes feels like I'm on the 6 month plan, :headbang:
  6. yooperdave
    It seems you were! :picard:
  7. WeldrDave
    So, what you have to do now is: Figure your full winter burn and cut :saw: x3 at a minimum this year, then find some standing dead to help you get through the next two years. You'll be busy! ;):whistle:
  8. papadave
    Time for a new plan, eh?
    Ther's one called "The 3 year plan"......you might have heard us mention that.
    Just doin' a little chop bustin'. That plan works for more than just having dry wood. Takes a couple minutes to get there, but it can be done. Like Dave said (the one right above me, not me, or the other one above him), figure out what you've burned this year and work on getting more than that for next year.
    Took me almost 4 years to get to Dry wood status and the full 3YP. Like money in the bank.
  9. yooperdave
    Yup, Dave, Dave and even the aforementioned Dave are all correct!
  10. papadave
    There are other Dave's that'll tell ya' the same too.
    You WILL be assimilated. :handshake::tree::axe::stacker:
  11. Creekin
    Creekin
    Manitoba
    I've actually got about 9 cord of elm piled up for next year, 6 cord of oak that might be ready for the year after that, have a number of logs that need to be cut up but under snow at the moment
    Hoping to hit it pretty hard before the ground thaws, need to cut for 14 cord per year now
  12. yooperdave
    Whew, now that 's better!
  13. Creekin
    Creekin
    Manitoba
    Ive been trying hard to get to that mythical 3 year plan, guess I should have mentioned too that my folks have been raiding my stacks all winter too, in fall i was like "i got lots, never run out", then my cousin brought me about 100 pallets to which I paid him with a cord of ash:doh::headbang:
  14. TurboDiesel
    ok...for supplying your folks, you get to keep your card.:handshake:
    now, about that trade...
    :BrianK:
    :heidi:
  15. Creekin
    Creekin
    Manitoba
    There was actually a bit of an reason behind it, my cousin put in a boiler last winter, he's been cutting up pallets to burn in it
    Figured if I can get him to switch to cord wood i might have some help out in the bush
    Other reason, flat broke, couldn't give him cash, besides have lots of wood!
  16. Stoveburner38
    Stoveburner38
    Springfield,ohio
    14 cord a year man I want to hang out with you I only get to cut 3to5 cord a year
  17. Creekin
    Creekin
    Manitoba
    Been contemplating building a processor for some time now, slowly getting parts and pieces together, beam, engine, wedge material, pump, etc.
    If not an actual processor then an insane splitter with conveyor to dump into the 3 ton truck
  18. Stoveburner38
    Stoveburner38
    Springfield,ohio
    as much wood as you process a year it would be a smart move.
  19. Creekin
    Creekin
    Manitoba
    Figured after i had a good stash built up, start selling some to get back some $$
    Got my eyes on getting a bobcat to make moving things around easier too
  20. Horkn
    Yeah that is.
    This is a short term near out then. :)
