If you had to choose just one.....
Discussion in 'Chainsaws and Power Equipment' started by fox9988, Nov 25, 2013.
  1. cmag
    cmag
    Long Island
    Any truth to the rumor, saws with electronic fuel injection ?
  2. MasterMech
    Demolition saws, yes. Chainsaws? Sadly, no.
  3. concretegrazer
    concretegrazer
    Southwest MO
    Here's 1.:D
    Oliver1655, SolarandWood and fox9988 like this.
  4. bogydave
    +1
    If buying a new saw today
    For me
    Ms362 would be a close 2nd
  5. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    034Super/036 if buying old... MS362 if buying new. Having said that, I did great with just the MS250 but a lot of it is dependent on the wood I run into.
    I haven't had the pleasure of running the 562XP, but I trust MM and others. Power seems impressive...
  6. lukem
    361 and 20" bar suits me fine. Ignorance is bliss on everything else.
    Chvymn99 likes this.
  7. Nixon
    Nixon
    West Sunbury,Pa .
    If I had to be limited to one particular saw / displacement , it would be in the 70cc range . Assuming that it would have to be a currently,or soon to be released saw ..... Ms 461 ,or the mythical 572xp .
    mdavlee and amateur cutter like this.
  8. amateur cutter
    Yep, I'm with Nixon. Gotta be in the 70cc range. I could make all my firewood with a 260, but 20" bar on the old 046 would be my rig. A C
    mdavlee likes this.
  9. bogydave
    20" bar , for firewood, seems to be the most liked size
    Pallet Pete likes this.
  10. Pallet Pete
    Pallet Pete Moderator
    Ovid
    It's very convenient chains aren't overly expensive and the bar isn't to long. It tends to be right for 99% of what a homeowner cuts.
    Nixon likes this.
  11. SolarandWood
    SolarandWood
    Syracuse NY
    i most like the 28" bar on the 95 but would never choose that setup if I could have only one
    mdavlee likes this.
  12. Hinerman
    Hinerman
    NE Oklahoma
    Yes it does. I sold mine to a friend who does tree work. He had been using a 311 before that (tight wad). Next time I saw him his eyes were wide open and he was grinning ear to ear. He said "Man that thing cuts fast" "Man cutting bigger wood is so much faster" "Man that thing has power" "Thanks for selling it to me", and on and on. He gives me all the wood I want from his jobs... It is a side job for him so I don't get a lot but free wood is free wood. He loves it when I show up to help him buck and load the wood because I bring the horsepower. I was limbing for him and cutting some into firewood lengths with my "wicked work" 260. He was in the tree. I had been cutting for a few minutes and stopped. He and his helper were staring at me; they were like, "What kind of saw is that? It sounds awesome and cuts like crazy...."
    Back on topic. If I had to pick one it would be 60cc with 20" bar.
  13. DexterDay
    DexterDay Administrator
    Northeast Oh
    I love my 036 Pro (better than the 2- 361's I owned and sold) and it would take 2nd place for sure, but as MM stated, the 562xp is a fricking beast! Runs the the pizz out of a 20" bar and revs to the moon as fast as a rocket! For a one saw man? 562xp
    (This is the logical answer)
    I would choose a 70cc Monster (045/440/046/460/461/441/372/576) and run a 20" on it and have a 28" for the big stuff. (This what my mind wants to say because of CAD!!)
  14. campinspecter
    campinspecter
    The reason I chose the Husky 570, it was a saw that was very familiar having used similar sized saws at work. The 28" bar means that I do not have to bend over at all to buck smaller rounds 6' - 18' that are laying on the ground.
    Much of the roadside waste type wood can have fine sand on portions of the log so being able to under buck and throw the sand away from the cut saves much filing. Also if there is a kickback down when boring into the log, the bar hits the ground before me.
    Much of the wood that I see can be this size or larger so the extra weight was not that important.
    For filing ease I use skip tooth chain.
    When choosing a saw. My advice is if you have found a saw size and bar length that you are comfortable with, stay with it.
    Woodwidow bought this rechargeable Stihl as a Christmas present last year . A great little saw but it has found my fallers pants twice, just not used to the short bar!
    mdavlee, thistle, Oliver1655 and 4 others like this.
  15. Oliver1655
    Oliver1655
    Central Missouri
    The size would really depend on the size of wood you are processing. If you are cutting up truck loads of tree tops where you rarely get anything larger than 12" a saw in the 45-50cc range with a 14-16" bar may be ideal. If you want to have a long bar for the reach, then the saw would need to be larger for the oiling needs as much as the cc's to pull the longer chain. I rarely drop trees larger than 42-46" Most are < 36". For myself, I plan to get a 70 cc saw.
    At this time I have a 56cc saw with a 25" bar for falling, a 56cc saw with a 17" bar for bucking the lower part of the trunks, a 45cc saw with a 14" bar for limbing / bucking the upper trunk & a 39cc with a 12" bar for limbing & in the air work. Man am I thankful for not having to limit myself to 1 saw! :D
    clemsonfor, basod, DexterDay and 3 others like this.
  16. clemsonfor
    I would of said 60-65cc till I have run a 372 now!! I'm thinking 70cc. Yea its a bit heavier than like a farm boss but you can work almost twice as fast!!
    SolarandWood likes this.
  17. SolarandWood
    SolarandWood
    Syracuse NY
    Welcome to the dark side.
  18. Gasifier
    This handles everything I need to cut. Reliable. Not too heavy. Enough power for me. But I also use a smaller Stihl 009 to cut many things smaller. If I don't need the size, and can do without the weight.
    MS 290 STIHL FARM BOSS® Specifications - Mid-Range Use
    DISPLACEMENT 56.5 cc (3.45 cu. in.)
    ENGINE POWER 2.8 kW (3.8 bhp)
    POWERHEAD WEIGHT 5.9 kg (13.0 lbs.)
    GUIDE BAR LENGTHS* (Recommended ranges) 40 to 50 cm (16" to 20")
    FUEL CAPACITY 560 cc (18.9 oz.)
    CHAIN OIL CAPACITY 330 cc (11.2 oz.)
    OILOMATIC® CHAIN
    .325" RM3
    campinspecter and swags like this.
  19. swags
    swags Moderator
    I had the 290 and it did everything I needed it to do, But after getting the 460 I can do the same in much less time. And if needed I can run a much bigger bar.
  20. the GOAT
    the GOAT Banned
    Maine
    Ported 359.
