Ideal Steel Season #2 Tips, Tricks, and Improvements.
Discussion in 'Modern EPA Stoves and Fireplaces' started by JA600L, Sep 13, 2015.
  1. chance04
    chance04
    Denton Md
    I couldn't wait lol I let the cat fire on our second curing burn.
  2. Canadian border VT
    yeah mine was fourth one to see cat flame show... got to 40 degrees that night and all bedroom (5) windows were open:thumbs::banana:
    frosty likes this.
  3. chance04
    chance04
    Denton Md
    I had two windows and the porch door open till midnight sitting in the stove room with shorts while it was mid forties and the cat humming along at 500 and a pretty flame show a cross the top of the stove. I'm really looking forward to this weekend when the lows dip deep into the 30s
    milleo and Canadian border VT like this.
  4. JA600L
    JA600L
    Lancaster, Pa
    I engage the cat at 5-600 degrees on the cat probe. Get the stove hot until the top hits 250. Then I turn it to 3/4 open. This works like a charm. One of these days I will post a video of me doing it. Then you slowly bring it down to burn rate. The cat probe really helped me.
  5. chance04
    chance04
    Denton Md
    Probe is a definite need then is what your saying?
  6. Canadian border VT
    I think it's nice to have in don't think it's a need.. call Woodstock and ask them what temp range should be for double wall pipe.. I am currently moving the one they sent me with stove to other locations to see where else you could put it to get a close reading..
  7. JA600L
    JA600L
    Lancaster, Pa
    The reason I recommend it is because it tells you very quickly when you can close the bypass. The delay in stove top temperature makes it a little more guess work. I went my whole first year without a probe and it was ok, but I find it much easier and trustworthy to utilize both.
    Canadian border VT and papadave like this.
  8. Babaganoosh
    Babaganoosh
    Jersey Shore
    Where did you get your cat probe? Do you use it instead of a thermometer on the stove pipe or in conjunction with it?
  9. BDF
    BDF
    Reading the firebox, the cat and the exhaust temps. all really help run the stove I find. If a digital gauge is used for the cat. probe (does anyone else find that term hysterical? :) ) you can watch it light in a matter of seconds literally. Same thing if it is not going to light- the temp. will drop immediately when closing the bypass.
    No, no gauges of any kind are required to use any woodstove I have ever seen but like most tools, they help and are useful.
    Brian
    papadave and Canadian border VT like this.
  10. JA600L
    JA600L
    Lancaster, Pa
    3-12-1 from Condar. I'm sure other suppliers have one too. The probe is 4".
  11. Canadian border VT
    Yeah more tools! :thumbs::yes:
  12. Babaganoosh
    Babaganoosh
    Jersey Shore
    Got some secondaries going. Hard to see in the pic but the flames are coming from the top. Took a video too. Gotta upload it to YouTube first.
    milleo, Gark, Brad38 and 4 others like this.
  13. Babaganoosh
    Babaganoosh
    Jersey Shore
  14. Babaganoosh
    Babaganoosh
    Jersey Shore
    The secondaries have settled down about 20 minutes ago. Box is mostly dark except for the back right corner. It's glowing there so I assume that's where some of the air comes into the firebox. No flames but the stove is still putting out lots of heat. Had maybe 40% of a load in there, if that.
    This stove is no joke. I would have had to reload my old Russo stove by now. The heat is definitely a lot more steady with this stove. Interested to see how many coals and ash I have in the morning.
  15. pappy88
    pappy88
    Missouri
    Looks like you got it dialed in. Looks good !
  16. pappy88
    pappy88
    Missouri
    I have a cat probe & a pipe probe in my double wall, I can tell exactly what its doing at a glance. this stove runs very even for long periods & I've never even filled it up. Have 5 cords stacked on the front porch, bring it on! samsung s5 074 (Medium).jpg
    milleo, Todd 2, Gark and 3 others like this.
  17. Brad38
    Brad38
    S. Indiana
    I have the pipe probe in my double wall, also. Is it safe to say the cat can be engaged when it reaches 500?
  18. JA600L
    JA600L
    Lancaster, Pa
    Yes at 500 degrees engage the cat. Then use a stove top thermometer to gauge how you shut the air down.
  19. Canadian border VT
    Well I loaded mine with popular and birch 65% full threw cat put air at notch 4 went to watch movie with wife at 9.. at 7 am 4 inch coal in bottom 3 small splits living room still 79 perfect:D hoping 3 splits gets me to temp to shut her back down and take daughter to riding lesson
    milleo and pappy88 like this.
  20. pappy88
    pappy88
    Missouri
    I would say yes. When mines up & running I'll see 1000* cat temp & 350-400* pipe temp. Thats on 1/4 air or less with 19 1/2 Ft. straight flue. At those temps it's rocking some heat !
    Gark and Canadian border VT like this.
