Ideal Steel Season #2 Tips, Tricks, and Improvements.
Discussion in 'Modern EPA Stoves and Fireplaces' started by JA600L, Sep 13, 2015.
  1. Canadian border VT
    Yeah, I told them everything I did.. 675 highest I have got my STT since I owned it.. then first time this year burned real BTU wood. such a mild winter I have been burning popular.. even loaded 3/4 full rarely got above 525 STT. Past weekend I tried to keep that as minimum..
    Eric VW likes this.
  2. Canadian border VT
    Yeah Customer Service SOLD me this Stove... Are there other good stoves out there Absolutely .. But small locally owned company, great guarantee and Solves problems what's not to like...
    Eric VW likes this.
  3. Lorin Day
    Lorin Day
    Hi Canadian border,
    You are not the first to warp an unshielded radiator. The temperatures from the combustor are very high and that heat is projected right onto the radiator above. While there is no harm in running the stove with a warped radiator and the part will still be effective, it can get progressively worse, making it difficult to remove to clean the combustor. Your replacement radiator will come with a stainless steel heat shield attached. This stainless steel heat shield will help protect your radiator from the high temperatures.
    All the best,
    Lorin Day
    Woodstock Soapstone Co.
    Stephiedoll, milleo, frosty and 7 others like this.
  4. Babaganoosh
    Babaganoosh
    Jersey Shore
    I might have a radiator made up out of stainless locally because the radiator seems to be made from plain ole mild steel. The temps that the cats run at definitely damage them..I think I've heard the radiator is a "wear" item similar to tires on a car. The steel peels away from itself. A stainless radiator would not do that but obviously adds to the cost. Is there any negative issues with having a stainless radiator made up? I'd think not due to you guys adding a stainless heat shield to it but one never knows.
    freeburn and Canadian border VT like this.
  5. Canadian border VT
    Babaganoosh, I will see how the one with stainless heat shield works.. But that is a good idea.. One of my concerns with this stove purchase was it was a new design, meaning the IS did not have a longevity record, but their customer service is fantastic, and parts are reasonably priced those factors along with ease of repair alleviated that concern.
    Kudos to Woodstock for continual part analysis and improvement.
  6. JA600L
    JA600L
    Lancaster, Pa
    We had this problem last year on the old thread. You would find it mentioned quite a bit in the old thread.
    Mine continues to scale metal off of the radiator and it has gotten very thin.
  7. Lorin Day
    Lorin Day
    Our Ideal Steel Beta testers of 2013-2014 (some of which really put the stove through its paces), helped us work out the majority of changes pre-production. Once we went into production, and had a much larger user group, we were able to identify some minor changes. The radiator shield is one, and for those who had an early production stove, the "alarm clock" tertiary bimetal plate was the other. Both were easy to fix.
    Lorin Day
    milleo, frosty, papadave and 2 others like this.
  8. Lorin Day
    Lorin Day
    JA600L- Do you have a shielded radiator?
    Lorin Day
  9. Babaganoosh
    Babaganoosh
    Jersey Shore
    I purchased my stove in October and I did not get one that had a stainless shielded radiator.
  10. Beet Stix
    Beet Stix
    NW Ohio
    Agreed. I have scaling on both top and bottom. I usually pull the cat once every week or two and check for metal laying on the cat and scrape the radiator.
  11. freeburn
    freeburn
    Wis
    Lorin,
    Do you recall when Woodstock began adding/using stainless radiator shields to the production of IS stoves?
  12. Lorin Day
    Lorin Day
    It looks like we started using the radiator shield mid-November of 2015.
    Lorin
    Canadian border VT and freeburn like this.
  13. Babaganoosh
    Babaganoosh
    Jersey Shore
    Look at that big chunk of radiator. That was a few weeks ago.
    Doing a clean out today so I'm curious to see what's going on.
  14. BDF
    BDF
    Is the whole radiator stainless steel or is there a S.S. section in the middle of a steel shield? Do you have a photo by any chance?
    I just pulled my cat. out and for the first time, my heat shield is dished down in the center, no doubt due to the extended, hard burning from the recent cold snap. I did not over- fire the stove, merely ran it somewhat harder than normal.
    Just got done receiveing a new door (I bought that) and a new cat. from Woodstock and I agree, their customer service is second to none that I know of. Plus their packing and shipping is just about as good or better than anything else I have ever seen; I have only been a customer since last year but those people are a pure pleasure to deal with every single time I have had any interaction with them.
    Brian
  15. Canadian border VT
    BDF, Brian it's being shipped when I get it I will post a pic. I just called as I saw the dip and wanted to make sure wouldn't hurt anything.. As Donna said I was the first I assume she thought I had warped the new style.. I am only 125 miles from Woodstock so it should be soon..from Lorin description I assume it has a stainless protector plate on it..
  16. BDF
    BDF
    Great-thanks!
    The dip in mine is almost enough to have the radiator clip the thermocouple above the catalyst. I may have to bend it back up a little bit.
    Brian
  17. JA600L
    JA600L
    Lancaster, Pa
    Here is mine.
    Gark and Canadian border VT like this.
  18. JA600L
    JA600L
    Lancaster, Pa
    If you try to bend it back it just weakens the metal and causes more scaling.
  19. BDF
    BDF
    Well, I cannot have it dragging over my temperature probe (man, that sounded nasty, didn't it?) so I do not have much choice.
    Putting a piece of angle stock across the top of the radiator, with the two edges flat on the radiator (with the "V" shape pointed straight up) would go a long way to stiffening the front lip of the radiator too- maybe this summer when the stove is down.
    Brian
  20. JA600L
    JA600L
    Lancaster, Pa
    I thought about a piece of angle iron in the front there too. I'm just not sure if the angle iron would hold up to turning bright red. It might warp too and make the front heavier.
    frosty and Canadian border VT like this.
