Ideal Steel Season #2 Tips, Tricks, and Improvements.
Discussion in 'Modern EPA Stoves and Fireplaces' started by JA600L, Sep 13, 2015.
  1. NVhunter
    NVhunter
    Northern Nevada
    I had the same thoughts on the probe when I got mine. I bought a small magnet that had a .25" hole in it and that holds it in place and it accurately reads the cat temps. Works great!!!
    I'll dig through my email and find out where I ordered it from. It was like $2 or less. Shipping was more...
    Brad38, chance04, Deano31 and 2 others like this.
  2. Gark
    Gark
    SW Michigan
    What cleaning method did you do - vinegar bath, vinegar-water spray, dust and vacuum?
    pappy88 likes this.
  3. CoachSchaller
    CoachSchaller
    Southeast Michigan
    any tips on cleaning the stove top.....
    There was a wax candle that was spilled all over the top and burners. So far some of it has burned away but it has left a dark substance that is pretty hard. It doesn't wipe off anymore (even as we are running pretty hot with these cold temps). Scraping it off with a plastic scraper hasn't worked either. I am thinking of a chemical solution next. Any ideas like Goo Gone or WD-40?
  4. HarvestMan
    HarvestMan
    Southeastern Michigan
    I don't like the idea of using solutions. I would try applying some dry ice to the area (when the stove is cold of course) and see if by chance the cold might allow this wax substance to be brittle enough to be scraped away from the surface. Can't imagine this hurting the steel - not sure if it would damage the paint - just the idea that came to my head.
    CoachSchaller likes this.
  5. BDF
    BDF
    I did not have enough vinegar to give it the 50/ 50 vinegar / water bath and boil it. So I just sprayed it down with vinegar in the kitchen sink, let it sit a while (10 minutes maybe?) and rinsed it off with hot water. like a new combustor..... well, not quite like new but definitely rejuvenated.
    Part of the problem was that more than 50% of the cells were clogged with ash- either a gentle blast with compressed air or vacuuming would have gone a long way to improving that I think. But the combustor is so easy to remove from an I.S. that it really is not worth [not cleaning] properly in the sink IMO. We are coming into a cold snap and now is the time I really want to the combustor to work the best it can.
    Brian
    freeburn, Brad38 and papadave like this.
  6. Brad38
    Brad38
    S. Indiana
    I'm not a "form over function" guy, but I think the paint finish may be one of this stove's weaker points. It does scratch up and mark pretty easily. Suggestion- If good ol' soap/water doesn't get it, you could wait until the end of the season, then get the stuff off by whatever means necessary. Then, you could touch up the paint with the stove Brite paint in the spray can.
    NVhunter likes this.
  7. NVhunter
    NVhunter
    Northern Nevada
    Here's the link from where I purchased the magnet.
    Welcome to SurplusGizmos.com, LLC - We sell the Gizmos that bring your ideas to life!
    $0.15 isn't too bad I guess...
    Mike
    Stephiedoll and chance04 like this.
  8. Brad38
    Brad38
    S. Indiana
    How's it working out? Pic needed! :)
  9. NVhunter
    NVhunter
    Northern Nevada
    image.jpg image.jpg image.jpg Here are pictures of my probe and stove with the magnet.
    T-Stew, Brad38 and papadave like this.
  10. CoachSchaller
    CoachSchaller
    Southeast Michigan
    I agree with you on the paint. I already have a can from Woodstock to match my color and I told the Mrs. That if worse comes to worse, I can sand it or replace it.
  11. Brad38
    Brad38
    S. Indiana
    Yep good call. I used a couple of cans on my double-wall pipe and ceiling support so it matches the stove. Paint goes on easily and matches well.
  12. Brad38
    Brad38
    S. Indiana
  13. Babaganoosh
    Babaganoosh
    Jersey Shore
    I've noticed I can engage the cat a lot sooner that's for sure. It's also interesting to watch the cat temp shoot up when it gets going. Just threw in a load and getting it ready to cruise. Temperature is on its way up at the moment.
    milleo, papadave, HarvestMan and 2 others like this.
  14. Deano31
    Deano31
    It amazes me that Woodstock don't sell a probe for this stove. I was up there talking with mike lorin and another guy from their and they said that you really don't need it I have been burning mine since Thursday and see how much a probe would come in handy I ordered one just waiting for it to come
    frosty likes this.
  15. HarvestMan
    HarvestMan
    Does not amaze me at all. Woodstock's most popular stove ever doesn't come with one and certainly is not needed to operate the stove. I just found out the Fireview actually has a cat probe port and Condar sells a probe that will work for it, but have no intentions of getting one. The only value I see in the probe is letting you know when your cat has stalled - this likely occurs only when trying to burn too low or at the end of the burn cycle.
  16. Babaganoosh
    Babaganoosh
    Jersey Shore
    Some of us are data geeks.
    HarvestMan and NVhunter like this.
  17. Babaganoosh
    Babaganoosh
    Jersey Shore
    I don't need 2 pro level chainsaws, a 27 ton splitter, a 5 ton splitter in my den, or a trailer either. Need doesn't really fall into the equation here. They should sell one because we want one.
  18. NVhunter
    NVhunter
    Northern Nevada
    I'd have to push the probe back in every day or so before I put the magnet on it. The probe is 4" long and adding the magnet didn't affect it's reading at all.
    The probe helps me with activating the cat on start ups and reloads. I like knowing exactly what's going on, just like having gauges on my diesel for towing.
    Brad38, Fanatical1 and papadave like this.
  19. HarvestMan
    HarvestMan
    Hard to argue with that point! Carry on IS geek squad. :salute:
    NVhunter and Canadian border VT like this.
  20. wheelin1
    wheelin1 Guest
    We put our 250 down today for a ideal steel, we were considering forest green door and sides on a black stove with copper color handles. Pretty existed but don't like the steal of the month.
