I will take summer seasoning for the win
Discussion in 'The Wood Pile' started by jrider, Jul 19, 2020.
  1. MikeInMa
    I'm saying the drier the air, the better the seasoning.
  2. sirbuildalot
    sirbuildalot
    Mass
    I assumed that, but your numbers were off.
    When your average person thinks of humidity, they think of a 95 degree summer day. In reality, a fall day with dew on the grass that feels more comfortable because of the lower temperature could actually be 100% relative humidity. High humidity doesn't only occur on hot summer days.
  3. The Wood Wolverine
    Went down to 38%, boy is it sweltering. Glad I don’t have an outside job today. Makes me remember those days fencing out in an open field, no shade. Sit the digging iron down for lunch and can’t pick it back up. Or roofing, eff that!
  4. sirbuildalot
    sirbuildalot
    Mass
    I think this thread is a great way to point out how ridiculous it is when people say "Yeah its 110F, buts its a dry heat!"
    110 degrees is 110 degrees. Its not the humidity that makes you feel like garbage, its the fact that its 110 DEGREES!!! The 100% humidity in other seasons no one ever mentions. But its a dry heat!!!
    Its one of those things people parrot throughout their lives without actually looking into it themselves. Kind of like "You cant burn pine"
    Chaz, savemoney, MikeyB and 3 others like this.
  5. Hookedup24
    Hookedup24
    Bucks county, PA
    Take a look a humidity forecasts. On days it isn't raining it is most humid after dusk until an hour or two after dawn. It's a trade off, work outside at 6AM @75F and 90% humidity or 11AM @ 90F and 50% humidity.
    Chaz, savemoney, Rich L and 4 others like this.
  6. sirbuildalot
    sirbuildalot
    Mass
    Yup
    In fact winter days on average are about 10% higher humidity than in the summer.
    So more humidity, less sunlight, lower temps. I think the question as to which season dries wood better should be pretty obvious.
  7. jrider
    jrider
    Exactly! It feels humid because it’s so damm hot out but the air is much drier than we realize on most of those hot days
    savemoney, Chaz, Midwinter and 2 others like this.
  8. SD Steve
    SD Steve
    South Dakota
    Psychrometric chart anyone?
  9. Paul bunion
    Paul bunion
    Rule of thumb is that the relative humidity will double for every 20 degrees that the temperature drops and cut in half for every 20 degrees that the temp goes up, given the same absolute amount of moisture in the air. (At a constant dew point). That’s why the RH typically goes way down in the afternoon and climbs back up in the evening.
  10. jo191145
    jo191145
    Ct
    If we all just went outside on hot days like today we could see the water boil out of the wood. Mystery solved LOL
  11. oldspark
    oldspark
    NW Iowa
    Beating a dead horse, all sorts of info about drying wood all over the net. High temperatures bring the moisture to the surface and the wind takes it away.
  12. SD Steve
    SD Steve
    South Dakota
    I haven't figured out how to upload a psychrometric chart, but basically just as we all know heat always wants to equalize.....move from places of high concentration to low concentration. Humidity does the same thing. Humid weather is not good for drying out wood. Wind definitely helps, but is not the end all be all.
    Not PSYCHO..........psychRo......notice the R
  13. brenndatomu
    savemoney, Dstrick, Chaz and 3 others like this.
  14. jrider
    jrider
    Another day that feels humid with a relatively high dew point (68) and lower humidity than most would expect.
  15. SD Steve
    SD Steve
    South Dakota
    Thank you!!
  16. jrider
    jrider
    If you told me it wasn’t humid out yesterday, I may have punched you in the face but the data doesn’t lie.
  17. brenndatomu
    Dewpoint of 62 is not considered exactly "dry" though either...
  18. jrider
    jrider
    But 33% humidity is
    Chaz, savemoney and Chazsbetterhalf like this.
  19. sirbuildalot
    sirbuildalot
    Mass
    Punched you in the face he says!!!
    I know exactly how you feel. We'd be up on a roof shingling in 90 degree weather and a homeowner would pull up in there AC car, offer no refreshments and say something idiotic like "It looks hot up there!" Or someone would say "I LOOOOOVVVVVEEEEE the heat, I cant get enough". Meanwhile you find out they spend all day, everyday going from AC house, to AC car, to AC store, back to AC house. One out of every 10 would actually have a job, and it was typically an office job in the you guessed it AC. If you love it so damm much how about spending 9 or 10 hours working in it.
    MikeInMa, Chaz, savemoney and 6 others like this.
  20. Dstrick
    Dstrick
    Maple Valley, Washington
    I have been monitoring my wet and dry bulb temperatures recently as I just put 8 green cord in my shed. I have been running a 30” drum fan. I measured the air coming into and out of the stack. Quite impressive is the temperature drop and near saturation of the air coming out. My calculations tell me I need to lose 2800 lb of water or around 340 gallons to evaporate.
    7/25
    In 58 72 RH50
    Out 58 62 rh95
    7/26
    In 72 87 rh44
    Out 69 74 rh88
    7/27
    In 74 96 rh35
    Out 69 79 rh60
    MikeInMa, Chaz, savemoney and 7 others like this.
