I Turned My Hybrid Stove into a Rocket Stove and Nearly Burned My House Down
Discussion in 'Modern EPA Stoves and Fireplaces' started by Monadnock Monster, Sep 23, 2026.
  1. Monadnock Monster
    Monadnock Monster
    My cats were partially clogged that night. So by opening the bypass, it was in essence like opening a damper. The smoldering fire now had unobstructed draft to take off. At least, that's my theory.
    I'd considered it might have been a chimney fire, except that the first thing I did when I discovered the inferno was to close the bypass. When that didn't work, I blew the extinguisher. If it had been a chimney fire, I think the extinguisher would not have put it out since the cats absorbed and quickly fully clogged with extinguisher. Which actually made cleanup a bunch easier.
    I've known since the beginning my draft's too strong. I added a secondary air control on my outside air kit, which helps me manage a full stove. I've now added a damper on the exhaust side, as well. It's crazy because I can fully close the damper and a loaded stove will still accelerate. But if I also limit air on the intake side through the control on my OAK, I can manage stove temp.
  2. brenndatomu
    Tall chimneys, say over 25-30', sometimes need 2 pipe dampers in a row to control draft on a cold night...
    T.Jeff Veal and MikeInMa like this.
  3. Monadnock Monster
    Monadnock Monster
    Is that right???? I hadn't heard that or known. Honestly I fully expected this one to do the trick, but we'll see how it goes. Maybe I'll add another next Summer, I guess.
  4. brenndatomu
    Another trick that can help is to bolt some fender washers over the holes in the damper plate...might can get by with just one damper then?
