I thought the wood from the new stack was too wet
Discussion in 'Modern EPA Stoves and Fireplaces' started by BDF, Jan 20, 2019.
  1. BDF
    BDF
    But it was not that at all. Finished up a stack of wood that was burning great, then went to the next stack. The stove was choking on this stuff; I could not do a hot- reload without opening up the draft, damper and by-pass for at least 20- 30 minutes and often longer. Once the splits were engaged, the fire would burn OK (but not excellent) and then slow toward the end of the burn leaving an excessive amount of coals. I really thought I had wood with too much moisture even though it 'looked and sounded' dry as well as reading pretty low on a moisture meter.
    Two nights ago, for no particular reason, I checked the draft in the ash pan door only to find it effectively closed. AHA! Found the real culprit! So after cleaning out the ashes while getting ready for a cold snap, I reset the bottom draft to the usual setting (about the equivalent of a 3/8" hole) and the stove acts fantastic again. It restarts on a hot reload w/in 5 minutes or so (I determine it 'running' when the combustor temp. goes above 1,000F), I closed the main draft as well as running the damper in the flue pipe closed down further. The stove now gives a lone, even burn and consumes the coals by the time the house needs to have the stove re- loaded.
    Brian
  2. Backwoods Savage
    Glad you got that figured out before the cold snap Brian.
  3. BDF
    BDF
    Yeah, me too although I suspect there will not be much 'low and slow' stove running around here for the next two days. Temp. right now is about 35F but is predicted to be 6F tomorrow morning. About as cold as it routinely gets here although there is almost always a sub- zero point somewhere in the winter (last year's was - 9F when my water meter froze..... in the cellar!).
    Brian
  4. Canadian border VT
    Low and slow .Not in January!!
    Currently playing game of how long can we keep STT above 550 and closer to 650
  5. Backwoods Savage
    For sure closer to 650. We routinely run our stove to that temperature.
  6. BDF
    BDF
    It had been in the 20's and 30's here up until Monday when the mercury went south. Temps hovering right around 4F and yep, had to kick the stove in the pants a bit. The I.S. is not large enough to heat my house 'overnight' (between 7 and 10 hours) at these temps; woke up this morning to the house being 66F without any central heat running and the dregs of a fire. Used both the wood stove as well as the oil boiler to recover the place. Once running along, I can keep the place in the low to mid 70's with STT of around 500F, and no more than 550F for extended times. And that with an exhaust temp. (in the center of the flue) in the high 400F range!
    I really like this stove but would like one bigger for these longer burn times- yesterday and last night would have been better with a Blaze King King or a Regency 5100 I believe. I do not like the actual stoves as much but that big and rectangular firebox is attractive. I have a tough time fully loading the I.S. often due to the sloping firebox.
    Brian
  7. Backwoods Savage
    Or a Progress?
    Maina, In the Pines and bear 1998 like this.
  8. TurboDiesel
    Same thing here. I want to get the FV installed on the main level just for days like these, (single digits and windy).
    I did turn the oil furnace up to 68 when the temps started dropping on sunday. It only runs when the STT get below 400
  9. Canadian border VT
    Brian, how long are your splits? Mine are about 16" "easy now";)
    I load mine north to south or front to back with three layers of splits and then the final 2 are east West on top front.
  10. BDF
    BDF
    A Progress is just a tad smaller than an I.S., although loading from the side <I think> would allow it to be filled more easily and more often. The problem with a stove with a side- door only is cleaning the glass, at least to me.
    My house is still leaking heat and air pretty badly so I really do expect a very different situation once the second floor is closed up and the attic insulated. I certainly will not make any wood stove changes until the house is finished.
    Brian
    leoht, In the Pines and bear 1998 like this.
  11. BDF
    BDF
    What's that now..... how long do I want my splits? Forever, I want to keep them..... :) From the old joke about buying a 2X4 at the lumber yard: 'How long do you want that?' 'I want to keep it because I am going to nail it in my house......'.
    Most of my wood is right around 17", which will load either E/W or N/S in the stove. That said, I have had really spotty luck loading N/S due to having big splits (this is where the Easy Boys! goes). So the smaller spaces just will not fit in a split(s) available. I really load E/W with a very occasional diversion over to N/S to prove to myself that I really do not like it. :) The other problem I have with the I.S. and loading N/S is the relatively short distance from the firebox bottom to the bottom of the door opening; when scraping the coals forward, I often has enough that they are much higher than the front of the firebox. Many times I have thought of putting a steel sheet or 'curtain' at the front of the firebox to raise the bottom lip at least 6" and maybe 8" higher.
    Brian
  12. Hoytman
    Hoytman
    OH
    Now there is a piece of information usually not noted in most stove manufacturers brochures.
    I have the same issue with the Solarwood wood stove that I have ... it has a convection stove top ... and 3 steel tubes sloping upward in the firebox. It's a pain in the patute! It's leaving asap! Big fire box ... but a waste the way it's made. I can only load about 5 pieces triangular in shape ... about 4" to 5" splits on each of 3 sides. Can barely get an all nighter split in there, let alone an all nighter full log. The larger pieces don't light as easy and the small splits allow for more air circulation but less burn time. I too have had some trouble on re-starts ... it's like the stove is starving for air ... restart or not. Of course, when the stove comes up to temp ... I run about 450 on thermometer on the stove top ... IR gun no more than 530ish ... but when she gets that hot I back it down to 450. Even at 530 I have lots more stove to go yet once it's hot ... even in these sub-zero temps so long as I can get it going. With 3 splits it takes a while to get to temp even with the doors open, but once it's there if I use my drier wood it will hold there easily with 3 splits ... anymore and it's crankin' out too much heat. Had the house thermostat at 82 for nearly 8 hours on just those few pieces of wood ... after a reload that is ... so it puts out good heat. Of course, I'm still learning the stove too, but I'm hoping I won't need it long. I'm certain this stove could heat 2500-3000 sq. ft. easily.
    Odd thing is ... at 450 stove top temp ... the middle of the stack is under 300 ... and I worry about creosote build up. 'Course I've only burned it for 3 days 24/7. It's been a fuss though having to baby sit it to get it up to temps with the doors open a tad. If I close them without the stove having more wood ... which by design is hard to load more unless I use my wetter and smaller splits ... the stove won't come to temp. The bigger pieces, once I get them going, would run like a greyhound if I let it. I'm just a bit cautious though to run that hot ... and discovered an issue that prevents east west loading ... even though I think the air flow is better with north/south loading ... I discovered my latch door, if you close it just a tad too much ...it will come open on its own. YIKES! I was up all night watching that thing.
    I had picked the correct gasket size for the channel and tested it with a dollar bill. Not tight enough as the correct gasket would have made you think. I ended up taking the round 3/8 gasket out and bought a 1/2 gasket. Fit great as far as the dollar bill test. Oddly enough the old gasket I removed was huge and flat, leaky, but allowed the door to close tight. It's almost like the door latch is going past the wedge on the upper lip of the stove with the smaller 1/2 inch gasket ... even though the dollar bill was tight all the way around. I found the issue after the stove heated up ... and it's like a thicker gasket would not allow the door to close so much going past wedge. I'm wondering if when the stove heats up if the door lip frame in the stove opening isn't moving on me with the heat. Regardless, this old early 80's stove will be moved out soon. Either a coal stove, a new wood burner, or an older Fischer will replace it.
    The stove is currently out since the temps came up and I think I may not use it anymore because of this door ... or at least only when I am home during the day and awake. I'll just run the furnace until I need the stove during the day when the temps dip below 20. The door issue really negates the use of this stove and I am likely not going to use it unless the power fails ... then with caution.
    In the Pines likes this.
