I put a little to much wood in the stove lol
Discussion in 'The Wood Pile' started by dylantdyck, Dec 16, 2018.
  1. HDRock
  2. HDRock
    I've been looking at these temperature monitors for a long time, I have a little small one with outdoor sensor ,
    This set up I'm looking at is pretty cool :cool: :emptywallet:
  3. blacksmithden
    blacksmithden
    Alberta Canada
    Just a note to anyone else who might be looking at a new weather station that you can access with a phone. This one has the doo-hickey that you just plug right into your router so you can check on it with your phone through the internet. Some of the Acurite stuff that you access with your phone from anywhere needs to be hooked to a computer in order to get info out onto the internet. Make sure of which one you're getting before ordering. The one that needs a computer hookup sounds like a bit of a pain.
  4. HDRock
    Well, I had to go do some more research , Download the manuals and do a little reading , It can be calibrated , has logging etc , And I found out you can access it on A computer , phone or tablet .
    Well there goes The cordless chainsaw, Maybe someone will get that for me :D
  5. Backwoods Savage
    Now I understand why the temperature is in celcius...
    amateur cutter, Camber, Hammy and 8 others like this.
  6. HDRock
    OK ,now , what was this thread about :D
  7. Creekin
    Creekin
    Manitoba
    Guessing something to do with wood?
  8. brenndatomu
    Christmas shopping I think... ;) :confused:
  9. billb3
    ... and if I remember correctly, that computer has to be on all the time and maybe even not asleep. It's been a while since I was looking.
    I have several with outdoor monitors and I can put all the outdoor monitors in the same place and there can be quite a variance in temps. None of these sub-$500 instruments seem to be terribly accurate.
  10. HDRock
    That's why it is important to be able to calibrate , Do that with an Accurate glass tube Liquid filled Type thermometer
  11. blacksmithden
    blacksmithden
    Alberta Canada
    Yes...on 24/7 365. I was looking at a Davis Instuments one that was around 500 cdn, but it seems they've got a lot of issues with theirs too. I dont really expect to get more than 2 or 3 years out of the Acurite one I ordered. As far as accuracy goes, I'm not expecting miracles there either. If it's with 3 degrees C and 10km/h on the wind speed, I'll be happy. All I really want to know is approximately what it's doing outside so I know how good to feel about being in the basement with the woodstove. :)
    amateur cutter, Camber, Hammy and 6 others like this.
  12. HDRock
    I'm definitely getting me a water sensor for the basement , I have battery backup for my router And modem , so even if the power goes out I'll be all set With the sensor
  13. Horkn
    You know it actually gets below freezing in parts of California. I'm not talking just about dropping to 65° f either. ;)
  14. Horkn
    How much was that bad boy?
  15. HDRock
    Thanks for the heads up Bought my set up yesterday $35 off , Coupon codes are gone today
  16. HDRock
    $239.98 then $35 off $204.98 free ship
    I just looked and Coupon codes are gone today, Got mine just in time
  17. wildwest
    FANTASTIC!!
    I did not read the time of your post and checked for coupons for you today, none except for accessories, glad you got one. raybonz inspired me and helped me with coupon codes. I'm impressed the winds have not wrecked it yet. Mine is not accurate for for snow, the winds just blow the snow all around and it keeps adding to the till so it can read 8" over night though it was only 2" of snow the day before, recycled many many times, but I'm super impressed with with the indoor outdoor temp, RH, wind speed/direction and barometer. I can look and see just fine how much snow we really got.
    raybonz, amateur cutter and Horkn like this.
  18. HDRock
    It's here
  19. brenndatomu
  20. HDRock
    :santa: Santa came early .
    All set up , Now I can check the temperature at home from wherever I am , Then I'll know if I need to get my butt home and Put more wood in the stove fire-3-smiley-emoticon-animation.gif -wood-stove.jpg
    raybonz, Maina, blacksmithden and 4 others like this.
