I need to build a hearth
Discussion in 'The DIY Room' started by Kimberly, Oct 29, 2015.
  1. Eric VW
    About 2 hours from me....I offered a while back.... Then hernia surgery visited me....
    Horkn and wildwest like this.
  2. MightyWhitey
    MightyWhitey
    What's with all the dudes with HERNIAS here??!:confused:! Lotsa frozen peas being thawed in a most unique way!!??:smoke::rofl: :lol:
    Horkn, wildwest and Eric VW like this.
  3. Kimberly
    Kimberly
    The Kangaroo State
    How did you build your hearth? What size hearth did you build?
    Eric VW likes this.
  4. Kimberly
    Kimberly
    The Kangaroo State
    What is this castable refractory you mentioned?
    Eric VW likes this.
  5. Eric VW
    It comes in a 55 lb. bag... Mix applicable amount of water, pour... Mizzou is the most cost effective, Kastolite is a little more pricey...
    Sets up like concrete, just able to reflect heat REAL well! Not at all like regular concrete.
  6. MightyWhitey
    MightyWhitey
    Was it not in this thread that I posted this??!!:headbang::whistle:
    Anyhow; here's how I did mine, briefly......................
    1. Pulled out POS zero clearance fireplace.
    2. Patch wall.
    3. Cut out laminate flooring to accommodate new hearth.
    4. Build hearth frame from 2x4 lumber..............8" on center
    5. Before #4, find which direction floor joists run...........................and build hearth frame with runners 90* to floor joists
    6. Attach hearth frame to bare floor with 3" screws
    7. Cover frame with 1/2" plywood....................I used "real" plywood...............not OSB/particle board
    8. 2 layers of Micore
    9. 1 layer of Durock over the Micore anchored down with long "Durock" screws thru the 2 Micore layers
    10. 1 layer of Durock on the "face" of the frame of my hearth
    11. Joined the seams/corners of durock together with mortar.
    12. Attached porcelain tiles to the hearth and rear wall
    13. Grouted tiles
    14. Sealed grout
    15. Positioned Stove
    papadave, Eric VW and wildwest like this.
  7. MightyWhitey
    MightyWhitey
    Hardest part for me wasn't building the hearth...................................it was figuring out how/where/if I could do my chimney here or there!!!
  8. milleo
    milleo
    Maine
    I only needed 1.1 R value on my hearth for my Jotul so I put 2 layers of next generation cement board on 2 layers of cement board strips to make 1 inch air space under and it gave me 1.87 R value so if you go one extra layer of cement board @.39 it will put you over 2 R value, hope this helps....
    papadave and Eric VW like this.
  9. Eric VW
    Way to step in and make it sound so simple, milleo!!,:rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    I like it:yes:
  10. milleo
    milleo
    Maine
    I did a lot of research and then dove in, I think my figures were right but am not positive but I feel safe....:)
