I need to build a hearth
Discussion in 'The DIY Room' started by Kimberly, Oct 29, 2015.
  1. Kimberly
    Kimberly
    The Kangaroo State
    I did take a course in thermodynamics but I don't recall a discussion on R value. My guess is that as the temperature goes up, the thermal resistant goes down because the thermal gradient is higher. My guess is that saying something has a R value of... without stating the temperature is not completely accurate. I need to ask the manufacture to see what they say. I wanted a low profile hearth; I know some like a higher hearth, but I was wanting a low profile one. With inch of Micore I have a R2 plus the durarock; and a height of 1.5 inch. With the Roxul, it would be 2.5 inches; plus the tile.
    Eric VW likes this.
  2. Eric VW
    wildwest and papadave like this.
  3. papadave
    Since there are so many other methods to get the required value, I'd say 21" of slab is a moot point.
    hoverwheel, Eric VW and wildwest like this.
  4. Kimberly
    Kimberly
    The Kangaroo State
    I contacted Roxul and talked to a rep and was told that they did not have any sort of fire rating for the Rockboard 80 and she could not they me what the R value would be at the temperature coming off of a wood stove. It would have been cheaper than the Micore but I need to know that it will work. The woman told me that it would probably work OK in my application but that is about all. What does others think?
    Eric VW likes this.
  5. Eric VW
    What I was going for in my post on the previous page- can R value be arrived at if you know thermal conductivity, which (for the refractory product I linked) is often given over a range of temps, and solve for the unknown "R"?
    Just wondering....
  6. Kimberly
    Kimberly
    The Kangaroo State
    If I know the equation; maybe I can do a different search and get some info. I looked in the index of my thermodynamics textbook but did not find anything about R value or thermal resistance.
    Eric VW likes this.
  7. Kimberly
    Kimberly
    The Kangaroo State
    Here you go:
    Eric VW likes this.
  8. Eric VW
    Ok Kimberly ..... Now, can thermal conductivity # be used anywhere/plugged in? I'm no math person....
  9. Kimberly
    Kimberly
    The Kangaroo State
    Basically, as the temperature goes up, the R value goes down and that equation is linear. So Rockboard would probably be as suitable for the hearth as Micore; I would think a 1 inch board would have an R value of around 2. Micore at 1/2 inch is a bit over 1; 1 inch gives 2. If I could find the Rockboard in a 1 inch sheet then that would give me the R value I need plus the R of the durarock and still have a relatively low profile hearth.
    Eric VW likes this.
  10. Eric VW
    I still think you could pour a castable refractory, top layer it with durock/tile, and be good to go...
    Just my $.02.
  11. MightyWhitey
    MightyWhitey
    I don't know about Rockboard; but I do know from practical experience, that Micore can be cut with a utility knife.
    Make your line, score it, snap it, and then back cut if needed.................just like sheetrock/drywall. Where a mask or bandana over your mouth and nose though if using this product.
    Eric VW likes this.
  12. Eric VW
    As an aside, my experimental rocket stove is cast with insulating castable refractory, and with a full on fire blazing in it, I can place my hand on the outside of the firebox for over an hour. 1 1/4" thick walls, hand on it for over an hour. 1000+ degree fire an 1 1/4" away... 4 foot flame out of the riser.... Over an hour... Jus sayin. Again.:rofl: :lol::thumbs:
    wildwest likes this.
  13. Eric VW
    Yeah, no one wants mineral fibers lodged in any part of the respiratory path:yes:
  14. MightyWhitey
    MightyWhitey
    I still think that Micore is the way to go for the OP. Light weight, easy to work with, and the best "bang for the thickness" regarding R values out there!!
    wildwest, Eric VW and papadave like this.
  15. Eric VW
    I couldn't agree more, MightyWhitey!:thumbs:
    Phew, I was starting to get wore out on the refractory stuff any ways:rofl: :lol::yes:
    MightyWhitey, wildwest and papadave like this.
  16. papadave
    Yep, use the KISS principle. (That's "Keep It Simple Silly", for those not in the know)
  17. Eric VW
    Well, that's putting it.....nicely:rofl: :lol:
    Diplomatically, even:thumbs:
    I grew up hearing it differently on the end of it:whistle:
    papadave, wildwest and MightyWhitey like this.
  18. MightyWhitey
    MightyWhitey
    Twas gonna post something similar.....................but I would've gotten Moderated!!!!!:rolleyes::doh:
    papadave, wildwest and Eric VW like this.
  19. papadave
    Kimberly, you got this.
    Gotta git 'er dun now that the stove's on the way.
    wildwest, Eric VW and MightyWhitey like this.
  20. MightyWhitey
    MightyWhitey
    If I were closer to Kimberley, I'd go there and offer to build a hearth myself...............seeing as that I have the same stove!!!
    wildwest, papadave and Eric VW like this.
