I love these totes
Discussion in 'The Wood Pile' started by Unicorn1, Aug 29, 2015.
  1. bert the turtle
    bert the turtle
    325 gallons is about 43 cubic feet. Oak about 60 pounds wet, 45 lbs dry per cubic feet, so about 2500 lbs for the big one with fresh cut oak. That would be for a solid block, so reduce according to how tightly stacked, but 2500 lbs maximum
  2. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Just eyeballing it, I'm thinking 1/4 cord stacked tight, which should be around 1000lb.
  3. Unicorn1
    Unicorn1
    Amarillo, TX
    I have another tote full of uglies.
    savemoney likes this.
  4. Hedgerow
    Hedgerow
    SW Missouri
    I love em' too..
    Chvymn99, unclefess and savemoney like this.
  5. savemoney
    That is one big pile of wood. You stacking is about how I would do it. I only made my stacks neat enough so they wouldn't fall down.
  6. Hedgerow
    Hedgerow
    SW Missouri
    I was just dumping bucket loads in the bay with the loader, then shoved the 2 totes into the pile to keep the splits from rolling out into the driveway.
    I'm getting lazy..
    Used to stack everything..
  7. Backwoods Savage
    Frank, as set of forks really do come in handy, even for cutting wood and moving some logs out.
  8. Machria
    Machria
    Long Island, NY
    It holds exactly 1/2 a cord per calculations via inside dimensions stacked just above the top... so you can figure out the weight based on the species / weight per cord in the resources section.
    Red Oak is 3760 lbs per cord, so the bin will hold about 1,880 lbs. Honey Locust is 4000 lbs a cord, so it would be 2000 lbs. Mines a mix of mostly Locust, Oak and then a mix of other stuff thrown in. That explains why I can't even budge it when full! ;)
  9. Hedgerow
    Hedgerow
    SW Missouri
    I shake em down and stack em.
    unclefess and Chvymn99 like this.
