I like the idea of a CAT stove, but I don't like the look.
Discussion in 'Modern EPA Stoves and Fireplaces' started by Shawn Curry, Sep 11, 2014.
  1. Tenn Dave
    Tenn Dave
    For my money, the 2 best stove companies today are Woodstock and BK. If ultimate control and super long burn times are your thing, BK is hard to beat. If both 'form & function' ring your bell, then Woodstock is where you want to be. Both companies are industry leaders. It all depends on what you need and your personal preferences.
  2. Highbeam
    Highbeam
    Oh and do check clearance requirements. I would have a woodstock on my hearth right now if the rear clearance requirement wasn't so high. Seems they were more intended as fireplace stuffers or "hearth" stoves. The rear exit is sure handy for that. The newest models look to be better about the footprint issue.
    papadave and BrianK like this.
  3. BrianK
    BrianK
    West central PA
    With the rear heat shield, our IS rear and rear corner clearances are 6".
    papadave and Backwoods Savage like this.
  4. wildwest
    We were having puffing issues in a very old Blaze King that was in a house we recently bought. I have no doubt its due to poor maintenence with some operator error. As well as the last batch of wood we could get last spring was not dry.....
    Backwoods Savage and Stinny like this.
  5. macpolski
    macpolski
    South Jersey
    What a great looking, super burning, well designed heater from one of the best in the industry. And speak of superb customer service I am referring to Woodstock Soapstone. The stove is the Fireview and after last winter in South Jersey, I can say simply it was perfect for our needs.
    Backwoods Savage and Tenn Dave like this.
  6. My IS heats my home
    My IS heats my home
    Albany, NH
    I think I'm doing the heat shield too Brian, it will help me get a 45 deg double wall elbow to work for the run to the wall flue. Penny added it to my order today.
  7. BrianK
    BrianK
    West central PA
    Good idea.
    I don't really "need" it for my install but it gives me a bit more flexibility and peace of mind.
  8. My IS heats my home
    My IS heats my home
    Albany, NH
    Yea, I don't think so. I ran my woodstove 6" insulated flue and a 3" non-insulated flue (gas hot water heater)side by side in the same size chimney as yours and it just barely fit.
  9. Highbeam
    Highbeam
    This is true, as i said, the newest models are better.
    papadave and My IS heats my home like this.
  10. Woody Stover
    Woody Stover
    Southern IN
    Easy to run, like the Fireview, but I like bigger glass. That, and the good ash-handling system, are the main reasons I got the Keystone. May not be big enough for his place though. I don't recall reading about his house size, layout etc.
  11. clemsonfor
    Puffing is from poor venting. I have a cat stove and will get it if its warm outside or I have a clogged chimney.
    Under 99% of conditions you won't get it if u do turn it up or clean it.
    Shawn Curry and Backwoods Savage like this.
  12. gmule
    gmule
    Conifer Colorado
    The thing about the fire view is that depending on what materials you use to build your hearth with will change the visual look of the stove as illustrated by the pictures tat backwoods savage posted
  13. Wes
    Wes
    NC
    i second the only recommendation for buck. the model 80 would be my suggestion. in the true sense of the word rustic, a lot of the buck line fits perfectly. solid black, not ornate (with the black cast iron door option, and none of the trim) and more of a traditional simple shape than most other modern stoves. more of what people these days would call utilitarian, as a lot of people use rustic for ornate, overly country. it's listed as 2.6 cubic feet, not sure exactly what it actually is, as my 74 (non cat) is also listed at 2.6 cubic feet, but when actually measured it has 2.23 cubic feet (22.75" x 15.75" x 10.75" the second figure could be more above the air intake, and to the sides, but i won't stack it that way since i don't want wood falling against the glass, and the last figure being an average height) of usable space. my best guess is the 2.6 cubic feet on the 74 comes from the measurement without the secondaries.
    Shawn Curry likes this.
  14. Locust Post
    Here's my Buck 91 Cat I installed last year with the platinum trim.
    Todd 2, splitoak, gmule and 4 others like this.
  15. clemsonfor
    My stove I think is a copy of a buck..both were made in NC although High Valley is now made here in SC
  16. Oldhippie
    Oldhippie
    Ashby Ma
    Interesting discussion.
    I heat my house with a Fireview I got last year, after burning 30 years with a Garrison One (big old steel stove). I also have oil with forced hot water and heat all our hot water/laundry with the oil, so I'm always going to burn some oil. It's a 30 year old New England Chalet (think big Cape Cod house) and I'm right on the NH border in north central Mass.
    The oil company I used decreased my monthly oil bill budget from $165 for 10 months, down to $95 for this coming year, based on my usage from last year. This year my wood is going be a lot better, so I think I'll be in even better shape. My wife likes the Fv better because it is not so "peaky" with the heat.. the old box stove was much harder to regulate and it's "cruise range" temps were too much for the living room. Where the Fv is much more manageable as heat output. Also went from cleaning out almost a full bucket of crud every year down to a couple inches of gray ash in the bottom of the bucket.
    ...and, it's pretty.
    macpolski, gmule, Todd 2 and 8 others like this.
  17. Backwoods Savage
    Well said Steve.
    papadave likes this.
