I finally got a Wood splitter
Discussion in 'Chainsaws and Power Equipment' started by 94BULLITT, Apr 4, 2015.
  1. basod
    basod
    Mount Cheaha AL
    You have a stationary wedge - right?
    The force of the releasing split will go anywhere.
    I've never had anything fly - except when attempting to shear a branch(explicitly no-no in manual) yeah they will shoot across the yard and the other side will nearly take your junk off.
    With these they don't fly anywhere the foot holds the stationary end, its the live point of the wedge that will slam the split into the table/carriage and or rotate the split as it shears through a crotch.
    It's not as dangerous as I describe - unless you keep your hands "under the split"
    splitoak and Horkn like this.
  2. HDRock
    So , the thin wedge kinda slices the wood ,instead of popping it apart ?
    I made the mistake one time of putting my fingers in the crack getting ready to pull the wood apart the rest of the way , when I pulled it off the wedge it clamped down on my fingers :eek::startled: , lucky I happened to have a pry bar out there that day :emb:
    basod, splitoak and Horkn like this.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    Harbor Freight called me Friday. They have the part to fix the tongue and are shipping it to me.
    Yes, it is more like a knife. It takes less tonnage to push a narrow wedge.
  4. HDRock
    well that's good they are getting you a new part
    Horkn likes this.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    Great review and videos..
    We contemplated getting this splitter. It seemed like a great deal, but there wasn't enough reviews or people with them 4 years ago.
    That's a quick cycle time and you made a lot of splits in a short time. :)
  6. Woodrat1276
    Woodrat1276
    Ky
    I Like that splitter. It looks like a pretty productive machine
    94BULLITT and DexterDay like this.
  7. 94BULLITT
    94BULLITT
    Thanks.
    It keeps 2 people busy.
    Thanks, it is very productive.
    raybonz and DexterDay like this.
  8. XXL
    XXL
    Ontario, Canada
    Very nice. That dual direction/action is a great idea. I like it :yes:
    raybonz, HDRock and 94BULLITT like this.
  9. 94BULLITT
    94BULLITT
    I got the part for the tongue today.
    raybonz likes this.
  10. HDRock
    Did they get a good weld on that one ??
  11. 94BULLITT
    94BULLITT
    Yes, this one is fine. They sent me a receipt, the part would have been $12 which I thought was cheap.
    raybonz and HDRock like this.
  12. cnice_37
    cnice_37
    How's she running for you?
  13. 94BULLITT
    94BULLITT
    So far it is running great. The engine starts very easily. I have a little under 5 hours on it right now. It has split a decent amount of wood in that time.
    Horkn and cnice_37 like this.
  14. bushpilot
    bushpilot
    Eastern Washington
    Man, I want one ...
    Greg
    raybonz and 94BULLITT like this.
  15. 94BULLITT
    94BULLITT
    Here is a video of the latest modification, a filter.
  16. bert the turtle
    bert the turtle
    I got a new splitter myself. So far the splitter has proven to be very durable. Made in Germany, very high quality steel.
    The power unit seems to be fairly heat sensitive. Did well enough in the spring but in the summer it craps out after only about 10 good sized rounds.
  17. Evanrude
    Evanrude
    Byron, MI
    Liquid cooling is the answer! IE: BEER
  18. HDRock
    That's a good one:):axe:
    I have one of those wedges too and it definitely works better than a straight regular wedge
    Evanrude likes this.
  19. PullinMyPoulan
    PullinMyPoulan
    Manistee National forest
    I got the splitter happy with it watched videos on filter Mod didn't buy the Napa :headbang:Went with a Lenz off the shelf at Tractor supply.Hooked upsame way blew the filter apart at the seem were it is put together found out there is a check valve in the base removed that threw on a hastings filter cross reference to the Lenz was working good for about an hour blew oil seal out the sidelike I over tightened itbut only turned 3/4 spraying.Have you had any trouble with the Napa Wix?.I was thinking I should have mounted it down by the tank?I was able toget the filter parallel instead of tilted to the side.I am going totake back filter and base and get a Wix.Iam thinking the Lenz base sucks and should have went with the WIX.
  20. PullinMyPoulan
    PullinMyPoulan
    I just got doing some research and found the american made Brave 2 way 20 ton does not come with a hydraulic filter only a 4"suction strainer.
