I Drilled The Soapstone For A Probe
Discussion in 'Modern EPA Stoves and Fireplaces' started by fox9988, Jan 16, 2014.
  1. fox9988
    fox9988
    NW Arkansas 72717
    Now at ~12 1/2 hr burn. I increased the draft from .7 to 2 a couple of hours ago to burnd down the coals. The CT has held at 580F, STT still at 290F
    Just reloaded.
  2. fox9988
    fox9988
    NW Arkansas 72717
    This morning experiment:
    I let the fire go aout this morning, stove is still slightly warm. Reloaded with three medium/small splits of Red Oak and three 1x2 splits of Red Oak
    STT (Stove Top Temp)-125F
    CP (Cat Probe)-125F
    PT (Single wall Pipe surface Temp)-<100F
    20 min: Engaged the cat, set the draft to 2, FB full of flame
    STT- 125F
    CP- 500F
    PT- 550F
    23 min:
    STT 160F
    CP 800F
    PT 425
    Lowered draft to 1.5
    33 min:
    STT 310F
    CP 100F
    PT 340F
    Flame in the box on the wood but not fully involved inferno.
    Drop draft to .75
    43 min:
    STT 360F
    CP 1050F
    PT 300F
    Its settling in for today's 10 hr burn.
    With the old cat, I never dropped the draft in stages- reload in the morning, get the STT up to about 250F, engage the cat, set the draft to zero (usually) and go to work. This year I started getting cat stalls. The new SS cat is working great so far, I'm going to stop dropping the draft in stages and I expect no problems. Getting my WS cat confidence back up to where it used to be.
  3. fox9988
    fox9988
    NW Arkansas 72717
    50 min;
    STT 425F
    CP 1100F
    PT 250F
    FB is mostly dark, cat is solid orange.
  4. fox9988
    fox9988
    NW Arkansas 72717
    image.jpg FB seconds after cat engaged.
  5. Todd
    Todd
    NW WIS
    Good info, it's been awhile since I've done a cold start but yeah, you can definitely light off in 20 min with a STT under the recommended 250.
    I always engage at 1.5 and always drop my draft in stages. According to WS and Applied ceramics the cat needs at least 20 min of 500+ heat directed on it to maintain light off. If I engaged the cat and dropped the draft directly down to <.5 I'd stall but maybe your draft is stronger.
  6. fox9988
    fox9988
    NW Arkansas 72717
    This mornings reload.
    OAT- 0F
    House- 70F
    STT- 200F
    CP- 400F
    9:15 am Reloaded on medium bed of coals. 1 larger split, 1 med, 1 small---Red Oak. Maintained 400F or less surface PT during burn in.
    9:30: STT 200F CP 600F PT 400F---Engaged cat, set draft to 1.
    9:35: STT 240F CP 820F PT 340F
  7. charlie
    charlie
    Schoharie, NY
    Nice to know that cat takes right off with the stove top under 250...
  8. fox9988
    fox9988
    NW Arkansas 72717
    9:43- STT305F CP 910F PT 255F
    50% of the cat at a dull glow
  9. fox9988
    fox9988
    NW Arkansas 72717
    30 min since reload. If I were going by STT, the STT would still be at 200F because I wouldn't have engaged the cat yet.
    Maybe it's worse on the Keystone than the FV or PH, but I've always disliked the time lag between FB temp and STT. Too many layers of stainless and stone to see changes in FB temp anytime soon. Of course all those soaked up BTU's will come back at the end of the burn, leveling off the temp swings, but the probe, to me, hurries everything along, saves BTU's and creosote from going up the chimney, and tells me what's going on now (5 min ago) instead of what was going on 35 mins ago.
    papadave and charlie like this.
  10. fox9988
    fox9988
    NW Arkansas 72717
    10:00 (45 min after reload): Without the probe, I'd probably be up to 250F now and engage the cat.:confused:
    STT 400F
    CP- Has been up to 1110 on the high temp indicator, FB is flaming now- burning some of the smoke. So, CP dropped off the paperclip down to 1090.
    PT 250F
    Cat is 90% lit at a medium orange, heat radiating from the glass nicely.
    Todd likes this.
  11. charlie
    charlie
    Schoharie, NY
    I'm waiting on my probe from Omega.. Already have my meter.. Going to be nice to see what the PH cat is doing... I can hear when the cat is heating up in the PH.. I usually get my SST to 275 then engage the cat, close the draft only 1/2 way and leave it there until I see an internal flue gas temp of 450-550 on my stove pipe, then close it down 100%... Seems like with the PH over my previous Fireview,,,, you need to heat the cat up before closing the draft down to zero or open just a hair... I'm thinking the longer S pattern ,,,that the smoke path has to travel before reaching the cat,, is making a difference.. Probing the cat on the PH will be very interesting for me.. maybe allowing a much quicker cat engagement also..
    Todd and fox9988 like this.
  12. Todd
    Todd
    NW WIS
    Keep us posted, I bet you will find you can engage a little sooner than normal and the probe should help you fine tune your burn.
    papadave likes this.
  13. charlie
    charlie
    Schoharie, NY
    I couldn't agree more about fine tuning the stove... I think any cat stove should come with a cat probe as standard equipment... You have a STT gauge, a chimney pipe temp gauge, well why not a cat gauge... All things that I would think any serious wood burner would want to have.. Even my 2 stroke paramotor I fly , I'm installing an exhaust temp probe with an alarm as to catch an air leak from a bad crank seal, head gasket, etc... thus seeing an increase in temps I know there is an issue and to look into things instead of flying blind until I have a sudden engine out situation seizure from a leaned out fuel situation... Cat is kind of the same thing,,, we want to know what it's doing...
  14. fox9988
    fox9988
    NW Arkansas 72717
    Charlie did you get your probe yet?
  15. charlie
    charlie
    Schoharie, NY
    No probe yet... it's been shipped... I knew from my order that it stated it was a week out on shipping.. With this cold weather , who knows when I'll get a chance to shut the stove down.. Guess as long as it's luke warm I can get it done.. Should only be a 5 minute install... Jamie @ Woodstock said the bolt that you remove in the rear for the probe wire feed is only like a 1/4 x20 bolt... I'll just use some HT silicone to seal the wire as it exits... If it was a 3/8ths bolt I was going to drill the center so as to slide the wire through, then reinstall the bolt for a neat job with a dab of silicone around the wire where it exits the bolt,,, being small the bolt will just be left out.. If a mechanical probe would work,, I'd almost like to drill the stone and steel cook top for a drop in probe... I worry on a slow burn if a smoke smell would come out of the probe hole in the top..
  16. Woody Stover
    Woody Stover
    Southern IN
    I don't think so but heck, you could stuff a bit of interam gasket around the probe to seal it....
    fox9988 likes this.
  17. charlie
    charlie
    Schoharie, NY
    I'm not worrying about the stone leaking smoke smell , it would be the steel cooktop maybe emitting smoke underneath the stones , thus coming out around the stone edges.. I know the stone on top you could seal , but no way to seal the steel hole, once the stone is put back in place to insert the probe... I'll see how the K type probe works first.. that's an easy non invasive install..
    BrowningBAR and Woody Stover like this.
  18. fox9988
    fox9988
    NW Arkansas 72717
    @charlie did you get the probe installed?
  19. Tenn Dave
    Tenn Dave
    Charlie died suddenly the day after his last post. Very sad.
  20. fox9988
    fox9988
    NW Arkansas 72717
    Thanks Dave. I got a PM of Charlie's passing, very sad. I don't know how I missed the thread.
    RIP Charlie and God be with your family.
    Todd, Tenn Dave and papadave like this.
