I cant believe im asking this
Discussion in 'The Wood Pile' started by Woodwhore, Oct 19, 2019.
  1. Timberdog
    Timberdog
    Az
    Do it in your freezer. I did a couple times. The hot water froze first. This has been repeated so much there is a scientific name for it.
  2. jo191145
    jo191145
    Ct
    Wrong experiment. You need to throw them in the air for a rapid conversion.
  3. Horkn
    I've unfortunately proven the phenomenon a few times. Don't ask me how I found out.
    If you read the article, you'll see that it doesn't happen in every circumstance, but many times it does.
  4. bear 1998
    bear 1998
    S.C.Pa
    I used to hook up icemakers to the hot water lines...it makes clearer ice also..
  5. brenndatomu
    Huh, that's...unexpected...
  6. Ohio dave
    Ohio dave
    Akron, OH
    I have no idea where that hot water freezes faster than cold water came from. Water has to go below 0*C (32*F) to freeze. If water is at 5*C it will freeze faster than water at 40*C . It has to loose less energy to freeze. There's no way everything else being equal that will happen.
    Personally I think he is wetting down the wood because he heard/saw thats what lumber mills do to try to keep a more even dey rate.
  7. Ohio dave
    Ohio dave
    Akron, OH
    Chazsbetterhalf likes this.
  8. Horkn
    Look up the Mpemba effect.
    You'll see that hot water can indeed freeze faster than cold water. I know, it's totally counter intuitive.
  9. Timberdog
    Timberdog
    Az
    The phenomenon has been observed as far back as Aristotle.
    why does hot water why does hot water freeze faster than cold water faster than cold water - Google Search
  10. Timberdog
    Timberdog
    Az
  11. Ohio dave
    Ohio dave
    Akron, OH
  12. jo191145
    jo191145
    Ct
    I can see in certain environments, like Arizona where cool wet water sprayed on wood followed by hot dry sun rapidly speeding up the aging process. Including checking from rapid expansion and contraction. Increased checking will help the wood dry faster. At least the outer edges. Wether that relates to the same amount of dryness all the way through the split may be a different story.
    In Your average New England humid summer your just as likely to start growing mushrooms which is very common.
    on a similar note I found this laid over stump early this spring in the shaded woods. Part of the visual attraction was the smoothness in which it had been decaying. The roots anyway looked like driftwood.
    Brought it home and set it in the sunniest part of my yard to dry out, stop the decay. It’s not so pretty anymore. Had been hoping the sun would begin to bleach it grey. What happened more was it got rough and checked.
    FatBoy85, Lcsodiver, Marvin and 9 others like this.
  13. Woodwhore
    Woodwhore
    Mason NH
    It rained last night so i ran out and uncovered all my wood. My apologies for creating this one. :rofl: :lol::hair:
  14. Timberdog
    Timberdog
    Az
    Not always but very often it does. Often enough that it is easy to demonstrate.
  15. Timberdog
    Timberdog
    Az
    My dad observed this phenomenon...living in Ohio. Just sayin. If this is indeed the case Im sure it’s only under certain conditions. If the wood remains constantly wet it just becomes waterlogged. If the surface gets wet and immediately dries then...possibly different story. Anyhow, I don’t cover my stacks. I leave them out in the open to the weather for a few years and then move them into the woodshed around September/Oct. So I notice this. I would have to do an experiment to see and right now I just lack the motivation for such an endeavor which would require an investment of time and energy that I just don’t have at the moment.
  16. Timberdog
    Timberdog
    Az
    And I should have just kept my mouth shut, lol. Btw, did you ask your roofer friend yet “why?”
  17. Horkn
    I find it funny that a roofer is saying this. I mean, we all know that roofs keep houses dry. Many houses are made of wood. Dry wood is good wood.
  18. Woody Stover
    Woody Stover
    Southern IN
    Yeah, or when the wood dries out, the rate at which water moves through it and evaporates, slows down. Not saying I subscribe to the theory, but it does seem like it could make sense..
    Harry Mudd, to Jim Kirk; "You sing and dance as well as anyone, Captain, but what in the hell are you talking about?" :rofl: :lol:
  19. SkidderDone
    SkidderDone
    Pollock Pines
    I've never heard of getting something wet in order to get it dry. With that said I don't pretend to know everything.o_O
  20. jo191145
    jo191145
    Ct
    Back up, slow down, start over. Think long and hard. It’ll come.
    All puns intended.
    LOL
