I built a different processor than I ve seen before
Discussion in 'Chainsaws and Power Equipment' started by jmur1, Oct 5, 2017.
  1. Eric VW
    Wow jmur1, really blowing in to FHC with gusto! Awesome :thumbs:
  2. jmur1
    jmur1
    Ontario
    I finally was able to put together an update video. It is linked here:
    Appreciate the interest and the comments!
    jmur1
  3. Casper
    Casper
    Seems like it's cycling faster. Any hydraulic changes?
    campinspecter, jmur1, Eric VW and 3 others like this.
  4. jmur1
    jmur1
    Ontario
    The hydraulic pump was replaced with the same one 28 GPM but the cylinder was decreased from Ø5" to Ø4". It made a big difference in speed. The larger engine (from 15 to 20 hp) seems to have much more torque which also speeds things up. Sorry I had written that in the post but somehow it got deleted when I posted the link.
  5. Chaz
    Chaz
    Southwestern NY
    Impressive machine jmur1
    :yes:
    campinspecter, jmur1, Eric VW and 2 others like this.
  6. jmur1
    jmur1
    Ontario
    I had some further testing on the processor this year. I ran a substantial load of mixed knotty maple though and found the rate of damage went up. I posted this video that gives an idea of the crooked winding logs requiring constant winching- and if you wait till the end it shows the moment the lower wedge was sheared clean off.
    I called it Homemade Wood Processor has a Bad Day
    jmur1
  7. Canadian border VT
    Welcome to the FHC jmur1 great skill set you have!
    campinspecter, Chaz and walt like this.
  8. Chaz
    Chaz
    Southwestern NY
    Ouch!!!!!
    :mad:
    No good.
    :confused:
    campinspecter likes this.
  9. jmur1
    jmur1
    Ontario
    Here is a twist on the standard processor downtime....
    SilentHatch and campinspecter like this.
  10. sirbuildalot
    sirbuildalot
    Mass
    It’s a neat concept cutting kindling, but it seems kinda dangerous with the pieces flying/kicking out while cutting
  11. eatonpcat
    Dial-up problems again??
  12. brenndatomu
    From 3 years ago...don't remember what was going on...dinosaurs probably ripped the line down or something...
    campinspecter and eatonpcat like this.
  13. eatonpcat
    Hahaha...Those Pterodactyl's are heavy!!
  14. Casper
    Casper
    Did you pre-heat the pieces parts of the wedge prior to welding?
  15. jmur1
    jmur1
    Ontario
    Agreed - this machine sends unclamped wood flying. Thats the reason for the enclosure. I run it pretty carefully - when clamped the wood stays well. But the plastic is 1/2" thick bullet proof!
    campinspecter and brenndatomu like this.
  16. jmur1
    jmur1
    Ontario
    The wedges were not preheated. I use a Miller 200 Amp MIG with .045 wire. I made probably three passes on each side. After the first pass the heat would be right up where it needs to be. (your right - it should have been preheated)
    That particular wedge has lasted for about 5 years or use. When I originally started this machine it ran with a 5" cylinder. It would split anything - but I got tired of the time to cycle. The 4" cylinder will still break parts easily enough! Good call!
    Casper, campinspecter and brenndatomu like this.
  17. jmur1
    jmur1
    Ontario
    Thats all I have for now. Let me know if your interested in more and Ill get them later on.
