Hydrogen
Discussion in 'The Wood Pile' started by Daryl, Jan 29, 2014.
  1. Lumber-Jack
    Lumber-Jack
    Actually, since nobody burns ovendried wood, the hydrogen content (in the form of water), in the wood does count towards the total amount of heat energy that can be recovered from firewood. It's just in this case it works as a negative in the equation.
    Moisture in wood or bark fuel
    evaporates and absorbs energy in
    combustion, Generally, all moisture
    escapes in stack gases as heated
    water vapor. Heat in water vapor
    escapes and is no longer recoverable
    as it exits the heat recovery system
    in stack gases. Generally, higher fuel
    moisture content or hotter stack gas
    temperatures result in more heat
    escaping in stack gases. The following
    formula developed on the’
    basis of heat capacity and latent heat
    of vaporization of water, is used to
    estimate the quantity of heat which
    escapes in stack gases because of
    fuel moisture per pound of wet wood
    or bark fuel.
    Stack gas heat loss caused by
    moisture (Btu/lb of wet fuel) =
    MC wb • [970 + (212 - T1)
    + (0.46 • (T2 - 212))]
    where
    T1 (°F) is the temperature of wood or
    bark fuel entering the furnace;
    T2 (°F) is temperature of stack gases
    beyond heat recovery devices;
    and
    MC wb is moisture content of the fuel
    on a wet weight basis expressed
    as a decimal fraction.
    MrWhoopee and fox9988 like this.
  2. MrWhoopee
    MrWhoopee
    Shingletown, CA
    You are, of course, correct. I was trying to head off the inevitable "run your car (stove) on water" assertions based on a complete lack of understanding of physics and chemistry. The sense of deja vu related to an extended disagreement (in which you may have participated) about whether the presence of moisture in firewood reduced the heat available from a wood stove.
    Lumber-Jack likes this.
  3. Lumber-Jack
    Lumber-Jack
    But Mr. W. ,,,, Extended disagreements are what forums are all about. :thumbs: Otherwise, where's the fun in it. ;)
    Now I think we should "discuss" whether the effects of gamma radiation on firewood has any effect on burn times or creosote production.
    [​IMG] [​IMG]
    Gark and MrWhoopee like this.
  4. stuckinthemuck
    stuckinthemuck
    Okay.. I'm back in on this thread.. So water in wood.... The ONLY way it comes into the heating calculation is in determining how much heat is lost from the fuel to evaporate the water in the wood. Sure there is hydrogen and oxygen in the water but the water molecule is so stable that it takes a TON of heat to break it as seen below. If anyone is running their stoves at these temperatures, they have more to worry about. Okay.. Someone else just posted on this..
    Thermal decomposition of water[edit]
    Main article: Thermochemical cycle
    Thermal decomposition, also called thermolysis, is defined as a chemical reaction whereby a chemical substance breaks up into at least two chemical substances when heated. At elevated temperatures water molecules split into their atomic components hydrogen and oxygen. For example at 2200 °C about three percent of all H2O molecules are dissociated into various combinations of hydrogen and oxygen atoms, mostly H, H2, O, O2, and OH. Other reaction products like H2O2 or HO2 remain minor. At the very high temperature of 3000 °C more than half of the water molecules are decomposed, but at ambient temperatures only one molecule in 100 trillion dissociates by the effect of heat. However, catalysts can accelerate the dissociation of the water molecules at lower temperatures.
    Thermal water splitting has been investigated for hydrogen production since the 1960s.[13] The high temperatures needed to obtain substantial amounts of hydrogen impose severe requirements on the materials used in any thermal water splitting device. For industrial or commercial application, the material constraints have limited the success of applications for hydrogen production from direct thermal water splitting and with few exceptions most recent developments are in the area of the catalysis andthermochemical cycles.
  5. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    The only thing I learn from chemistry was"Do like you oughter add acid to water"!:)
    Gary
    MrWhoopee likes this.
  6. Daryl
    Daryl
    My brain just exploded
  7. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I miss Gamma Ray
