Husqvarna carb tune ?’s
Discussion in 'Chainsaws and Power Equipment' started by Chud, Mar 27, 2021.
  1. Chud
    Chud
    NC
    I picked up a 371 a few weeks ago and it was idling high and chain was creeping so I backed out the L and T and it sounded better and stopped the creep. The L screw came to a stop. Is there a limiter on how fat you can make L? It’s idling at 2800 to 3000. It’s revving out to 13,200. This may be recommended peak rpm, but I’m a Stihl guy and it sounds unsustainable. there is a limiter on the H screw that will not let me back off H anymore.
    I noticed the oiler screw is counterclockwise to increase oil, that is opposite Stihl. I don’t see how the carb screws could be opposite, but why would counterclockwise be limited? I know why lean would be limited, but why limit richening the mix, especially if it’s turning 13,200? I can see the white plastic piece limiting movement on H. Is it ok to pull the plastic tubes and limiters off? It’s a pain to find the screws through the tubes. I have to lay the saw on it’s side to get at H.
    Throttle response is good and it’s good in the cut, just trying to figure out why I can’t go further counterclockwise on L and H
    Do I need to add pics?
    tamarack, M2theB and Sandhillbilly like this.
  2. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    No need for pictures, that’s just the huskies are engineered, total pice of garbage. I’ll unburden you of it, how does $50 sound :emb:
  3. Chud
    Chud
    NC
    Sounds about 8 c notes short. :makeitrain"
    brenndatomu, Sandhillbilly and M2theB like this.
  4. Eric VW
    brenndatomu, MikeInMa and M2theB like this.
  5. M2theB
    M2theB
    Central Massachusetts
    My experience is if it’s limited anywhere by the factory, it’s limited everywhere. Meaning H and L.
    It’s fine to pull the limiter and ritchen it, but if you need to it’s because there is another source letting more air through. Muffler mod, air leak, etc.
    13200 sounds ok though
    According to spec, you have a little margin to lean it. 13700 is target, oem
  6. Eric VW
    FHC info share- love it!
  7. huskihl
    huskihl
    Limiters are there for the epa.
    If you rotate the limiter, you’ll see where it lines up with the slot. Thread a drywall screw down into it, turn the limiter backwards until it lines up again, and pull it out with vise grips. Trim the tab off and reinsert it where the slot heads line up. If the plastic is wallowed out round, heat up the end of a tuning screwdriver and push it all the way down into the metal jet slot.
  8. Eric VW
    More great advice!!!
    FHC is the best- and no one can convince me different!
  9. Chud
    Chud
    NC
    Ok thanks for the help. I’ll take a closer look at the limiters and removing them. The muffler does not appear to be modified. One outlet on top. I’ll check for leaks also
  10. The Wood Wolverine
  11. Chud
    Chud
    NC
    It may be me not being used to a screaming saw. I’ll shove the plugs in deeper.
  12. M2theB
    M2theB
    Me 2
  13. Sandhillbilly
    Sandhillbilly
    I had to try!
    The Wood Wolverine and Chud like this.
  14. JCMC
    JCMC
    Just outside of Shushan, NY
    :yes:
    Eric VW likes this.
