Husqvarna 465
Discussion in 'Chainsaws and Power Equipment' started by Huntindog1, Dec 13, 2016.
  1. clemsonfor
    Seems like I am always cutting when it's in the 90s
  2. Horkn
    The only 2 stroke I want to run when it's over 90° is a jet ski or a boat.
    It seems like the auto tune saws ( m tronic too) really are set to err on the rich side until broken in.
    I get it as that reduces warranty claims, but if you're bringing it in because it's hard to start that's no good either.
    tamarack and clemsonfor like this.
  3. Woodporn
    Woodporn
    S. MA
    I used to own a 365 special, always liked the saw although VERY touchy to statrt. Ran like a champ untill it blew up....twice
    I'm Stihl here!
    Horkn likes this.
  4. MasterMech
    I would take it in, make sure you know the starting procedure, backwards and forwards, and show the dealer the problem. If it isn't something procedural, then perhaps they know of a fix.
    clemsonfor and Horkn like this.
  5. Huntindog1
    Huntindog1
    South Central Indiana
    Its in the shop now , I didnt have to show them anything as they have been having trouble with these Autotune carbs replaced several of them on customer saws.
    Mag Craft likes this.
  6. Huntindog1
    Huntindog1
    Well the initial check out is the Autotune Carb is bad. They have ordered me a new one.
    Hopefully that will fix it as its only been ran 3 or 4 times.
    I have spent more time trying to start it than running it.
    By the way I used Stihl Ultra in it with Shells top grade gasoline.
    I didnt know that if I had bought Husqvarna oil when the saw was purchased I could have extended the warranty.
  7. clemsonfor
    Yep buy husky oil, double your warrenty, when you get home dump it in your tractor tank and run something better! Heyoooo!!!
    Just kidding run whatever, but I am a fan of syn oil.
    MasterMech likes this.
  8. Mag Craft
    Mag Craft
    South East Wyoming
    The Stihl ultra that I have used is 100% synthetic. The Husqvarna oil that I have found and used is only a synthetic blend.
    clemsonfor likes this.
  9. MasterMech
    Shame on the dealer for not making you aware of that.
    I hate to just accept "the carb is bad" as a diagnosis but it's their nickel so let's see what happens.
    clemsonfor and concretegrazer like this.
  10. Huntindog1
    Huntindog1
    They replaced the carb I got it back yesterday.
    I didnt get to speak with the mechanic but the saw starts easy now and repeatable.
    They said the day I dropped off the saw that the solenoid in those type carb goes bad.
    MasterMech, clemsonfor and Mag Craft like this.
  11. DexterDay
    DexterDay Administrator
    Northeast Oh
    True! They should tell you that before check out!
    Glad that it is easy to start now though. Hopefully that was the problem.
  12. Huntindog1
    Huntindog1
    Well bad news finally got out with the Husqvarna 465 as the ground froze back up.
    When I first got is back from the shop I started it let it warm up and shut it off and restarted it a few times.
    Cut thru one log just one time and the saw died and couldnt get it started again.
    This is after they replaced the Autotune Carburetor.
    So its back in the shop.
    I will keep you updated. :hair:
  13. clemsonfor
    Not like
  14. Woodporn
    Woodporn
    S. MA
    Sorry man....
    Time for a Stihl or Dolmar??
  15. MasterMech
    Dolly 6100 would cost about the same or less than the 465 IIRC.
    colin.p and CoreyB like this.
  16. Huntindog1
    Huntindog1
    Update on the saw:
    I got it back from the shop today and they said they re-flashed the computer memory.
    Which means they reloaded the software. They took it out and cut with it and it was cutting fine
    and restarting fine.
    I took it to the woods when I got back home.
    I got it started and ran it a little and it was acting up. Then I couldnt get
    it started again. When I was running WOT it was cutting out.
    Plus the issue of hard to get start afterwords.
    So I tried something I cracked open the fuel cap and heard a whoosh sound and then re-tightened.
    This time it started right up and when I went to WOT , no cutting out. I cut for some time like 5 to 6 cuts in
    a pretty large size log. I shut off the saw and opened the gas cap and no whoosh sound. So I thought
    I had it fix but later on it did the acting up again and the whoosh sound came back when I opened the gas cap.
  17. MasterMech
    Sounds like a cheap fix is in your future.
    Sometimes the new tech gets blamed for the old problems...:doh::yes:
    concretegrazer likes this.
  18. Huntindog1
    Huntindog1
    I figure it needs a new gas tank vent.
  19. Woodporn
    Woodporn
    S. MA
    I hate so sound negative.....But I'd be throwing that saw through the dealer's window.
    clemsonfor and Huntindog1 like this.
  20. concretegrazer
    concretegrazer
    Southwest MO
    No reason to abuse a saw like that. Throw the mechanic.
    Woodporn, clemsonfor and Oldman47 like this.
