Husqvarna 236 headache
Discussion in 'Chainsaws and Power Equipment' started by pantelis, Apr 23, 2015.
  1. pantelis
    pantelis
    Europe
    Today a husky 236 start only with choke then die dont even can tuch the throtle
    pessure -vacuum tests = ok
    pressure-vacuum tank -vent test =ok
    coil test inside the cylinder = ok ( blue spark )
    fuel line-filter tests = 0k
    piston - cylinder = crystal clear like a diamond
    carb pressure test = ok
    carb opening inspection cleaning ok also the diaphragms are new the saw is only two months
    carb tuning like the service manual say
    carb adjusting screws out and inspection
    the saw can start only with choke even if its hot , then the tacchometer show 4000 then 3000 adjusting the screws hold a little and then again the same up and down , try to start again hot without choke no way
    any ideas ??
