Husky 51 leaking bar oil
Discussion in 'Chainsaws and Power Equipment' started by capetownkg, Feb 18, 2016.
  1. The Wood Wolverine
    The long aluminum part with the hole... the oil feed tube is behind that hole. IF the tank vent is ok, you can put a small amount of sealant so they stay in contact with each other which should prevent seepage. Again, assuming the vent is working right.
    I use 2 straight screwdrivers in those slots to remove the pump. Takes a little fiddling the first time till you get used to it. Here is a pic I found with it removed to show what you seal up.
    Jeffrey Svoboda likes this.
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    Where would the tank vent be located? Sry to just jump in but I have a 353 leaking pretty good.
  3. ironpony
    ironpony
    Mid Ohio
    my Triumphs are 1952 and older, 1952 Trophy 500, 1950 Thunderbird, 1949 Speed twin they leak, dry sump hahahahaha
  4. The Wood Wolverine
    Here is the manual on the 50/51/55. It shows the oil pump removal (i think pg 28). Found more specific 55 manual too.
  5. Firewood Bandit
    Firewood Bandit
    I used to get bent out of shape with my first 346XP leaking oil. I now just put a piece of carpet or two layers of heavy hardboard under it and accept it. We sealed it once and it still leaked.
    Now if it's not leaking, it's out of oil.:whistle:
  6. ironpony
    ironpony
    Mid Ohio
    the wood shelf I store my leaky saws on is well preserved
