Huskee 22 Seized
Discussion in 'Chainsaws and Power Equipment' started by firecracker_77, Oct 20, 2015.
  1. Horkn
    Briggs has been working on an oil less engine for a while. It's funny, but true at the same time.
    That's unfortunate about your motor, as I've seen a few run extremely low on oil with no harm done, on motors with several times more than 40 hrs on them.
    clemsonfor likes this.
  2. HDRock
    Did you purge the air out of the hydraulic system.
    You should probably start a new thread , help with splitter, probably get more input
    clemsonfor and Horkn like this.
  3. MasterMech
    Have you tried pulling it over with the pump disconnected?
    clemsonfor, Horkn and HDRock like this.
  4. firecracker_77
    firecracker_77
    IL
    I have not tried pulling it over without the pump connected.
  5. Horkn
    Try that. The pump could've roached.
  6. MasterMech
    Just a random thought but this engine is intended for this splitter? IIRC this particular model has a unique crankshaft length. If this engine is a replacement for a lawn mower, it may be equipped with a flywheel brake. That would make it a be-yatch to pull over.
    jeff_t and clemsonfor like this.
  7. clemsonfor
    Why would you want a lawnmower thats hard to crank?
  8. Horkn
    So you have an excuse not to mow the lawn. ;)
    cnice_37, HDRock and clemsonfor like this.
  9. firecracker_77
    firecracker_77
    IL
    Just what I need. An expensive pump to replace. :faint:
  10. MasterMech
    You don't. But if the engine was intended for a mower, it would be equipped with a flywheel brake that would require a cable hooked up to release the brake. I doubt these splitters have such a cable. ;)
  11. clemsonfor
    Oh I got ya! That stupid lever you have to hold. I'm surprised if it had one of those that he could even pull it at all. Would think that you would break the rope!
  12. cnice_37
    cnice_37
    I'd still put some oil in the old engine and break it free - you could have another engine to put on CL.
    Take the engine off, put it on blocks/ milk crate/ etc and pull it over. Cut the problem in half.
  13. firecracker_77
    firecracker_77
    IL
    What's a pump run if this thing is damaged? Pretty expensive when you get into the hydraulics
  14. NYCountry
    NYCountry
    Mohegan Lake NY
    I love them subaru engines. Whatever splitter I buy next has to have a Subaru engine. One pull that's all it takes, 2 pulls when it's really cold
  15. 94BULLITT
    94BULLITT
    Frederick County, VA
    Around $150.
  16. 94BULLITT
    94BULLITT
    My predator starts on the first pull.
    NYCountry likes this.
  17. NYCountry
    NYCountry
    Mohegan Lake NY
    Have you always had those engines?
  18. clemsonfor
    They havent always called them predator. But I know loggers that run them on gas compressors. They run them till they croak then buy a whole new unit. They said there cheaper and last almost as long as name brand stuff? Just passing that along. Take it for what its worth.
    Buy the blue HF engine on the splitter my buddy has is A1 I mean smooth, good on fuel and pretty quiet and starts first pull.
  19. NYCountry
    NYCountry
    Mohegan Lake NY
    Ok thanks for the info. Always good to know about other stuff as well. I seen the blue one when I google predator engines, thanks again
  20. firecracker_77
    firecracker_77
    IL
    If the hydraulic is locked, is there a pressure release valve or something with the Huskee?
