Hunting blind, with heat.
Discussion in 'The DIY Room' started by Need2Saw, Nov 16, 2019.
  1. metalcuttr
    metalcuttr
    western WA
    She sends me to the doghouse. A nice blind like that stored in the backyard would be much nicer digs. Much warmer also!
    Boogeyman, yooperdave, Horkn and 4 others like this.
  2. Ward Hoarder
    Ward Hoarder
    West Virginia
    Needs more firewood in it to hold it down.
  3. Need2Saw
    Need2Saw
    Central Michigan
    I have wondered if I should anchor it down to the ground. Mine seems so stable but you never know with Mother Nature!
    yooperdave, Horkn, metalcuttr and 2 others like this.
  4. brenndatomu
    Install a damper in the pipe?
    M2theB, yooperdave, Horkn and 2 others like this.
  5. Need2Saw
    Need2Saw
    Central Michigan
    Yes. Here is a picture of the setup, with a pop can for size reference.
    Knothead, Loon, M2theB and 4 others like this.
  6. Woodwidow
    That is tiny!!!!
    M2theB, yooperdave, Horkn and 3 others like this.
  7. Need2Saw
    Need2Saw
    Central Michigan
    Because I don’t want to see my wagon wheels off the ground and the forecast calls for 20mph winds with 40-60mph gusts tomorrow, I decided to anchor my hunting blind down. I used 3”x15” earth anchors, by no means is this overkill. I hope it helps keep everything in place.
    Boogeyman, Knothead, Loon and 8 others like this.
  8. Need2Saw
    Need2Saw
    Central Michigan
    I built a new trailer for my mobile hunting blind. I used an old anhydrous tank running gear. Welded up a frame for the blind and a deck.
    I set the blind out last weekend to get ready for the gun season opener. Here it is now.
  9. yooperdave
    What area do you hunt? Generally speaking.....
    I used to pick up those very short wood cutoffs split them and carry them in an old corn sack to the blind for my fuel. Probably nothing longer than 4". I would also pick up sticks on the walk in to the blind for starting the fire.
  10. Loon
    Loon
    North of the border
    That there is a great set-up Saw. :cheers: All ya need later. :coldone:
    Knothead, Need2Saw and yooperdave like this.
  11. Need2Saw
    Need2Saw
    Central Michigan
    I am located in the central lower peninsula.
    Believe it or not, this stove will fit an 11” “log”, just barely.
    Chvymn99, yooperdave and Loon like this.
  12. yooperdave
    I just didn't know if you hunted down there or if you went north some.
    Need2Saw and Chvymn99 like this.
