Humor me on this theoretical mod to a Husky 240 chainsaw
Discussion in 'Chainsaws and Power Equipment' started by saskwoodburner, Feb 28, 2016.
  1. HDRock
    Wow, not cheap
    Only: $24.19
    Item #: STL 33RM60
    clemsonfor and Barcroftb like this.
  2. concretegrazer
    concretegrazer
    Southwest MO
    I'm the opposite. Got the stihl down & can't keep up with the Oregon. To many letters I guess.
    clemsonfor, HDRock and Barcroftb like this.
  3. concretegrazer
    concretegrazer
    Southwest MO
    That's crazy. My dealer is a dollar an inch normally.
    clemsonfor likes this.
  4. Barcroftb
    Barcroftb
    The Mitten
    The Stihl dealers near me often run a buy one loop get a 1/2 off loop in the spring and fall. Might be worth keeping your eye out for.
  5. HDRock
    Yeah I figured I would check out the dealers there is three close by
  6. saskwoodburner
    saskwoodburner
    Thought I'd just come back with an update in case anyone has a dream of a 240 race saw lol. All the mental gymnastics aside, a muffler mod, richening up the carb, and a switch to a 91VXL chain (or the PS3 chain mentioned) is probably as good as it's going to get for these little saws.
    The 91VXL is definitely more aggressive than the original safety chain.
  7. clemsonfor
    Shorter bar with same tooth drum still would help. Less chain and mass to drag around the bar.
  8. clemsonfor
    Get a bigger saw than a 240
    saskwoodburner likes this.
  9. saskwoodburner
    saskwoodburner
    I definitely plan on it once funds allow. :makeitrain"I think I meant to replace it last spring, but it keeps on running lol
  10. clemsonfor
    From a "sharp" chain on a grinder by a hack to one of these guys who really can file and one who can square file you can probably get 10% or more alone!
  11. HDRock
    You should have got one of these when they were a hundred and fifteen bucks, I did, now they are $132.99 still a a good price for a saw that will work for you
    on a budget.
    Poulan Pro PP5020AV 20" 50cc 2 Cycle Gas Powered Chainsaw Home/Tree Chain saw
    Oh ! shoot your in canada :(:zip:
    clemsonfor and saskwoodburner like this.
  12. saskwoodburner
    saskwoodburner
    Princess Auto has sales on the reman versions of this saw from time to time, but I always seem to look at the flyer a week late. I think the Husky 440 or 445? was just on sale here, but apparently calipers and a battery for the truck are a higher priority.:(
    I'm good on wood for a bit yet, almost 2 cord in the shed, better than 2 1/2 cord on pallets, so I have lots of time to decide!
    HDRock and clemsonfor like this.
  13. dougand3
    dougand3
    North Alabama
    PHFSTSHT!!! Drag your feet like Fred Flintstone did...he did fine. LOL
  14. clemsonfor
    You must not burn that much? I burn 2 to 3 cords a year down here in upstate SC!!
  15. HDRock
    Yeah but he is a Canadian, don't need as much heat as you chilly Willies down there:rofl: :lol:
  16. OldJack
    OldJack
    Saskatchewan, Canada
    The real secret is insulation, then more insulation covered by another layer of insulation. Then you shovel snow up against the basement walls. Finally you let the sleigh dogs sleep in the house. :D
    saskwoodburner, clemsonfor and HDRock like this.
  17. clemsonfor
    Yea inulation is something I have almost none of. R19 in ceiling in most of house. Stove room has insulation in the walls.
    A night in the teens is pretty taxing on the stove
  18. saskwoodburner
    saskwoodburner
    I think I burn not quite 3 cords from October to end of April. Just a small mobile home, and I never totally get away from the oil furnace either with the stupid placement of the water lines.
  19. saskwoodburner
    saskwoodburner
    And then I stumbled across this...
    husqvarna 240 porting
    I'm not a member over there, but I might join just to see how he makes out!
  20. CTYank
    CTYank
    CT Panhandle
    Rather than rely on a 240, m'self I'd look at a factory refurb 435 (40 cc) or PP5020 on VMInnovations-dot-com for a saw. Given what I'm hearing about the small white poplar, the 435 would likely be my choice. Get a Husqy carb tool asap, if you don't have one already.
    Whatever the saw, I wouldn't focus totally on what chain(s) to buy, but more on KEEPING the one on the bar SHARP. What that means to me: at minimum each second fillup, I pop on a Granberg filing guide and give each cutter a stroke or two. It's really precise, and one goes with me most everywhere I go with a saw. A sharp chain helps so many ways, including fuel endurance, so often I just pack a liter of mix for a 40 cc strato RedMax.
    When a chain acts dull (easy to detect), file it NOW or swap it out for yer spare. I'd much prefer a sharp chipper chain than questionable full chisel.
