Humor me on this theoretical mod to a Husky 240 chainsaw
Discussion in 'Chainsaws and Power Equipment' started by saskwoodburner, Feb 28, 2016.
  1. Barcroftb
    Barcroftb
    The Mitten
    Short answer, probably not. What Jon said is spot on. Narrow kerf might allow higher chain speed in the cut, but the saw still needs to provide the torque, and there's only so much there. Short of a port job there really is no replacement for displacement.
  2. saskwoodburner
    saskwoodburner
    It sounds like the bottom line is a no go on this exercise. 3-4% cutting speed could be lost or gained just on chain sharpness alone I'm sure. Guess I won't pursue this idea, but it was fun hashing it out on the forum.
    The wood in question is white poplar btw. Technically a hardwood but burns like a softwood?
    Eric VW likes this.
  3. saskwoodburner
    saskwoodburner
    To keep with the theme of the thread, could this saw be ported...?
    Shawn Curry and Eric VW like this.
  4. Barcroftb
    Barcroftb
    The Mitten
    Theoretically it could have some work done. But being a clamshell and not a split case saw there isn't a lot that can be done with it. On top of that is the cost. I doesn't generally make sense to spend twice the cost of the saw on port work.
  5. MasterMech
    Sure it could. You just would have to live without the bump in compression that most builders are including in a port job. Sprocket changes in some small saws can be limiting, as not every option is out there. That's where Stihl's mini-spline drums are nice because almost any of their small saws can accept a rim sprocket for whatever pitch and gearing you desire.
    On the 240, I would buy a loop of Stihl PS or PS3 chain if you want to boost its cut speed. Not even 91VXL cuts as fast as PS series chain. Stay with the 6 pin spur drum and your current bar. Going to a super short bar won't speed up the saw significantly so unless it's a handling issue for you, I'd save the $$.
    We're still around. Most of us are working stiffs. I just wrapped up a 30hr weekend and my total from last week is likely flirting with 90hrs.
  6. saskwoodburner
    saskwoodburner
    I watched a few videos on youtube where they had the PS3 chain, and it seems to pull itself along pretty good compared to regular chain.
  7. concretegrazer
    concretegrazer
    Southwest MO
    Slacker.
  8. MasterMech
    Fast and smooth, keep it outta the dirt and you will like it. A lot.
  9. HDRock
    Most of my chains are Oregon but I have one stihl chain, RM3 and it just stays sharp a really long time.
    So, does stihl have a regular 3/8 pitch Simi chisel that is not a low kick back chain?
    I looked but didn't see one like that
    clemsonfor likes this.
  10. concretegrazer
    concretegrazer
    Southwest MO
    Yes, RM. What gauge? Or are we talking lp?
    clemsonfor and Barcroftb like this.
  11. MasterMech
    Yes, it's called RM and is very similar to the RM3 you have. Unless the nose of the bar is buried, you probably won't notice much if any difference.
  12. HDRock
    I want a, 3/8 . O50, 16" 60 dl Simi chisel preferably not low kick back. For my 55
    As far as I could find Oregon doesn't have a 3/8 . O50, 16" 60 dl Simi chisel
  13. HDRock
    Why is the RM called micro,
    OILOMATIC® STIHL RAPID™ Micro™ (RM)
  14. concretegrazer
    concretegrazer
    Southwest MO
    33RM is what your after.
    clemsonfor, pantelis and Barcroftb like this.
  15. concretegrazer
    concretegrazer
    Southwest MO
    Stihls fancy marketing.
  16. MasterMech
    Mostly.
    Micro refers to the specific shape of the cutter. Micro chisel. Some variants of semi-chisel chain vary in cutter shape slightly.
  17. HDRock
    seems like they dropped the 33 designation is that right or wrong?
  18. concretegrazer
    concretegrazer
    Southwest MO
    The first 3 stands for 3/8ths and the second 3 means .050 gauge.
    I run 36rm aka 3/8 .063.
  19. concretegrazer
    concretegrazer
    Southwest MO
  20. HDRock
