hows you thread
  1. dall
    dall
    West Virginia
    evening holsa hows you
    concretegrazer, huskihl and Rope like this.
  2. Rope
    Rope
    Alaska
    My name is Tom. What’s yours?
    concretegrazer and p61 western like this.
  3. dall
    dall
    West Virginia
    im ok mike coffee is good and getting stuff situated on sending the 361 to stumpy steve
  4. Rope
    Rope
    Alaska
    Evening Mike, how’s you?
    p61 western likes this.
  5. p61 western
    p61 western
    Northern California
    Good evening Tom. I'm doing well, how are you doing?
    concretegrazer and Rope like this.
  6. Rope
    Rope
    Alaska
    damm, I use those, that excuse is off the farm.
  7. Rope
    Rope
    Alaska
    Doing well, about to turn some shift work into:makeitrain"
  8. Rope
    Rope
    Alaska
    All in good time. I may have sensory overload. Definitely need more filing under my belt.
  9. Rope
    Rope
    Alaska
    I am going to order some loops of Oregon from Madsens. Way cheaper to practice on that than the Stihl.
  10. Rope
    Rope
    Alaska
    When I get the vise from homelite I hope it makes a difference in my consistency. I believe trying to convert to square while on the bar, at work trying not to get caught goofing off. May be leading to lack of good concentration and consistency. It’s tough trying to tuck away a chainsaw, files and gloves while pretending that didn’t just happen.
  11. dall
    dall
    West Virginia
    Lmao how many people do you work with
    Rope, concretegrazer and huskihl like this.
  12. huskihl
    huskihl
    I had to shim this one up with a 3/8 nut on all 3 bolts. Otherwise, I was hitting the straps when I rolled the tooth down to the wheel. TM says to barely clear the raker when you swing the arm in
    Rope, concretegrazer and p61 western like this.
  13. dall
    dall
    West Virginia
    pictures of the wheel angles
    the ones on mine are making the bottom of top plate a knifes edge probably 1/8 inch of grind on bottom of tooth i need to make the wheel more blunt to get a work chain angle
    Rope and huskihl like this.
  14. huskihl
    huskihl
    Don't have pics, but it's maybe a little shorter on top than yours.
    Rope and p61 western like this.
  15. dall
    dall
    West Virginia
    Ok go get pictures in a few of the wheel and the teeth wheel is dressed from factory
    Rope and concretegrazer like this.
  16. dall
    dall
    West Virginia
    Wheel angles from factory
    Rope, huskihl and concretegrazer like this.
  17. dall
    dall
    West Virginia
    Dirt on the corner of first picture
  18. dall
    dall
    West Virginia
    Different teeth at different settings
  19. The Wood Wolverine
    Dall, bought this loop from Keith 2 years ago for my 37" bar. It was ground by Jasha.
  20. dall
    dall
    West Virginia
    evening jason hows you
    i think its too sharp of a angle and too much into the straps
    ill play with it more i want durable chains and also faster chains without changing the wheels and dressers all the time
