How to split a log, not a round
Discussion in 'The Wood Pile' started by Yawner, Oct 31, 2019.
  1. Yawner
    Yawner
    Louisiana
    I am talking about a tree of, say, six inch DBH and, a log stem off that tree of, say, nine feet long. When I do a stack of firewood, I sometimes use small trees (saplings?) as the runners to put the first layer of wood on. I saw someone on here had done what I am talking about and I wondered how he split the stems so that the crack propagates all the way down the log.
  2. papadave
    I've just used the chainsaw a couple times. Worked well.
    amateur cutter likes this.
  3. RabbleRouser
    RabbleRouser
    In the woods, New Hampshire
    There are multiple ways to do it. Best when the log you're trying to split is fresh green. The age old method is to use a riving froe, made for the purpose. You can steer the split as you go. Nobody demonstrates this better than Curtis Buchanan, Master Chairmaker.
    You can also start at the end with a hatchet hammered into the end and then start hammering felling wedges or DIY hardwood wedges, into the crack, working down the log as you go. Go slow and let the cracks fully develope before going further and it should go right along the grain.
    If you look on Curtis's channel, he has a video on this too.
  4. buZZsaw BRAD
    never really tried to do that. Post pics if you do. Be interested to see the results.
    Chaz and amateur cutter like this.
  5. Paul bunion
    Paul bunion
    Split Rail fence video pretty much shows how to do it.
    clay shooter, Yawner and Chaz like this.
  6. yooperdave
  7. billb3
  8. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Or you could try blackpowder!
  9. Buffalo Plaid
    Buffalo Plaid
    Pepperell, MA
    I was expecting a lot of kindling with that technique. Surprisingly it didn't create any that I could see.
    yooperdave likes this.
  10. yooperdave
    If that cat had been a little earlier in getting over there it sure would have gone for a ride!
  11. buZZsaw BRAD
  12. buZZsaw BRAD
    looks like a blast doing it that way! :rofl: :lol:
  13. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Good one!:yes:
  14. RabbleRouser
    RabbleRouser
    Yahh.... No. My blackpowder is reserved for finer things.
    Interesting how clean it split though.
