How to mark firewood length
Discussion in 'The Wood Pile' started by Yawner, Nov 25, 2020.
  1. rdust
    rdust
    SE, Michigan
    Stick(old maul handle) cut to the length I want and my kids sidewalk chalk. I can eyeball reasonably well but like taking the thought process out when running the saw down a tree. Limb wood I usually eyeball.
  2. thebierguy
    thebierguy
    Hazelhurst, WI
    I picked up the Acc-u-mark Firewood Marking tool about a year ago. It actually works really well.
    I also demonstrated the usage on one of my later YT videos.
  3. buZZsaw BRAD
    nifty gadget. I like it! :thumbs: Knowing me i'd end up losing it roadside!
  4. papadave
    Fat Max tape. Measure and note the spot, hook the tape on my pants pocket and cut.....rinse, repeat until I don't feel like cutting anymore.
    If I'm feeling especially productivey, I'll keep the tape in my hand while cutting to avoid the extra move.
    Horkn, T.Jeff Veal and amateur cutter like this.
  5. eipo
    eipo
    MI
    I load onto a cutting deck I built with marks on the front board for lining up the cuts.
  6. Woodwidow
    campinspecter uses a stick marked with tape at the length he wants cut. Today we used the 16" marked stick which does four lengths at a time. He lays it on the log and then uses the small saw to make cuts in the log at the marks. He then goes back with the cutting saw and starts cutting the log. Now I have been going out firewood cutting with him, I hold the stick in place and move it to the next section after the four cuts are done.
  7. LordOfTheFlies
    LordOfTheFlies
    NY
    I made this magnetic 16" measuring stick after watching it on a YT video. The link to amazon was selling it for $25 and I figured I could make it for less than half of it. After a few minutes of searching I found the exact magnet and decided to go up a size. I'm glad I did - the bigger magnet stays put but still releases easily when you want to remove it.
    It sticks to the side of the chainsaw and then you just make a short cut and shift over and continue all the way down the log. Works just like the accu-mark.
    If I trim a long I trim to 16". Same for bucking. Anything else is eyeball (shorties for kindling, branches).
    This is the only picture I could find of it quickly. I'll take a picture of it on the saw tomorrow.
  8. T.Jeff Veal
    I've had a few get chewed up too. I usually use a small saw, keep sticking in my left hand, see where spot it a mark it, repeat. It's easy to hold stick and top handle together.
    Safety PO PO would probably give me a ticket though...:rofl: :lol::rofl: :lol:
    Haftacut, Horkn and Yawner like this.
  9. T.Jeff Veal
    So nice he has company/ help along now. Miz Carol usually has marking stick duty.
    Haftacut, Woodwidow and Horkn like this.
  10. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    I marked both of my MS250S (1 16” and 1 18” bar) with a paint pen at 16”.
    I cut right to left when I can.
    Hold the saw over the log with tip facing left and mark lined up with cut end. Look at where tip is or occasionally I’ll blip the throttle and mark it with the tip.
    Step sideways to the left and cut.
    Rinse and repeat.
    Oddballs I used to leave a little long and throw them toward my “shop stove” pile which gets shorts and uglies.
    I’ve started cutting them off at 16s no matter what though this year and just keeping the shorts in a bulk firewood bag for the shop stove.
    Horkn likes this.
  11. Slocum
    Slocum
    North Central Indiana
    I cut to 16”, I have a Mingo marker and it works well but I don’t like looking at my stacks and seeing spray paint. I have a stack of red oak that I’ve been looking at for 2 years with yellow paint at the cuts. I don’t think I’m ocd but it bugs me. Lately I’ve been using a 50’ tape marked with 16” on center in red. Then mark with lumber crayon. Using the tape takes more time than the mingo but the finished product is perfect.
  12. Yawner
    Yawner
    Louisiana
    lol, I feel the same, don't like paint marks on my stacks.
    Horkn, Chazsbetterhalf and Slocum like this.
  13. Ron T
    Ron T
    Northeast Ohio....Bowdil
    18 inch stick and a can of spray paint.
    Horkn and Chazsbetterhalf like this.
  14. Woodwhore
    Woodwhore
    Mason NH
    Heavy magnet and a dowel rod, mark em all up and take it rt off
  15. Paul bunion
    Paul bunion
    My 16" stick eventually evolved into putting a 16" handle on a pickaroon. Dual purpose tool.
    Haftacut, Horkn and Chazsbetterhalf like this.
  16. brenndatomu
    I just today ran across this picture on another site...zip tie on the CS handle, trimmed to proper length to indicate the firewood size you want...the price of admission it right, Ima try it out...
  17. Loon
    Loon
    North of the border
    Gotta do the same thing here with the large logs Cbh as i always cut em too long for some reason? :whistle: :cheers:
  18. campinspecter
    campinspecter
    I like this am going to try it !
  19. Yawner
    Yawner
    Louisiana
    I was real fired up about the zip tie method until I realized that it'll only work if you have a good place to tie onto. If you can only tie onto the handle on the left side of the saw, you can only buck left to right. That only works for free and clear stems; I often buck one to a few rounds at a time in brush and vines and it, obviously, varies as to which direction you can go with your bucking. And even if you can tie a zip tie onto both sides of the saw, the tie spot on certain saws will leave quite a lengthy gap between 16 inches and the zip tie, making marking less accurate... depends on length of bar.
    If left to right bucking is fine, the zip tie on the handle on the left side looks like a terrific solution.
    The more I think about this, the more my top handle Echo 2511t is appealing, using a mark on the saw at 16 inches. As I have said, the issue with holding even a medium size saw like an 026 or 346 against the log to measure is the easiest solution, requiring no additional equipment, but my issue with lower back pain tires me out too quickly when lifting and holding the saw like that over and over for a cutting session. The 2511t is super light, plus it's a chainsaw! Can not only cut the gnarly stuff out of the way but also mark to buck in the same operation. I'd rather just do all of this with one saw but I am going to try this dual-saw method with the 2511t. I often just carry one saw into the woods on my Gator or ATV but taking two might just be beneficial.
  20. Dumf
    Dumf Banned
    Maine
    Another morning gold star award for Lenny !:salute: Right. Right. And right.
    Mark the 261, cut, rinse & repeat. Don't want or need anything on my saws getting in the way. No nothing on the saw.
    Loon and Chazsbetterhalf like this.
