How to lift a water heater
Discussion in 'Everything Else (off topic)' started by Yawner, Jun 30, 2021.
  1. ThomH123
    ThomH123
    East Granby
    I have a glass lined 40 gal indirect. Good luck lifting that. I used a dolly and put short pieces of 2 by 4 under it by tipping it, I was able to work it into place.
  2. Warner
    Warner
    Isn’t that why they call it pennsultucky?
    Screwloose, Chaz, brenndatomu and 3 others like this.
  3. Warner
    Warner
    Where else can you buy a 6 pack at the bar for the ride home. Or go to a drive through liquor store?
  4. wildwest
    Yawner , how's it coming along?
    Screwloose, Chaz and brenndatomu like this.
  5. Canadian border VT
    New Hampshire..??;)
  6. bogieb
    That's the way I move heavy things, including when I moved the P61a to a new spot from where it had been. The stove had been on concrete blocks that were on the concrete floor and I had to move it to where I had installed a slightly raised flooring system (camp basement) that had a raised hearth on it (end result, higher than it had been). I was fortunate that I didn't have to raise it by much, in this case and used scrap wood to build up the section between and build a slight ramp. Used pellet bags to give myself a slippery surface to slide the distance. I've used cardboard to move heavy objects too - in fact I need to quite procrastinating and move some stuff this weekend in which cardboard will be the method of choice.
    With the bags removed, you can see the ramp
    Oh yeah, I'm a smallish woman who is nearly 60.
    Screwloose, Woodwidow, Chaz and 4 others like this.
  7. Woodwidow
    Where there is a will, there is a way to get things done. Might not be done "normally" but it gets done.
  8. Yawner
    Yawner
    Louisiana
    Reporting back. I got that sucker in there over that pan with a bear hug. The key was I could not get a good grip on it and then I thought to put on some gloves with the nitrile rubber-like palm and that sure worked. It's right where it needs to be and I didn't destroy the pan, lol. Now to hook it up and hope it works.
    Highbeam, eatonpcat, bogieb and 5 others like this.
  9. wildwest
    :yes:
    PA Mountain Man likes this.
  10. bogieb
    That's great!
    MikeInMa likes this.
  11. eatonpcat
    Hercules, Hercules, Hercules!!
    brenndatomu likes this.
  12. brenndatomu
    :D
    eatonpcat likes this.
  13. lukem
    I've always gone the bear hug and send it route. Works better when they are empty.... probably one of many reasons my back hurts most days too.
    MikeInMa, bogieb, brenndatomu and 2 others like this.
