How much secondary air is enough or too much? What if it was adjustable?
Discussion in 'Modern EPA Stoves and Fireplaces' started by saskwoodburner, Jan 22, 2018.
  1. papadave
    True. I'd like control of that though.....to actually lessen the amount of air being allowed into the stove via all inlets/intakes, not just the primary.
    Purely for investigative purposes.:)
    Eric VW likes this.
  2. saskwoodburner
    saskwoodburner
    Are you absolutely sure about that? If you have a link to something technical that says that it would be great. I can't wrap my head around that. If it didn't cut down or slow air flow, every fire would rage out of control, either at the bottom of the stove, or the top. My primary is controlled, but the secondaries are fully unregulated.
    I'm not sure on air flow dynamics, but I would think to a certain point, air holes being restricted might boost velocity. But eventually it would hit a wall. Kind of the same reason the air intake and exhaust on your car aren't 1/2" or 3/4" tubes or pipes. If it never restricts air, you should never be able to stall a fire, and running the stove would be easier, just warm it up and throttle primary air full back. If an elbow in the chimney can restrict flow, surely making air run through a smaller hole must as well?
    Eric VW likes this.
  3. saskwoodburner
    saskwoodburner
    For investigative purposes, my secondaries fired less intense, and slower, and longer, and at about a 40 degree angle downward with 33% less cowbell.:D Which doesn't jive with same volume of air. At least not to my non engineer brain.
    Suburban wood snob likes this.
  4. MikeInMa
    Interesting thread.
    My VC Dutchwest is a cat stove. About 5yrs old.
    There are air controls for both the primary firebox and the cat itself.
    I usually burn with the primary air open full.
    Now, the cat air is the puzzle. The control is a round dial, with no markings. Clockwise closes, counter opens.
    I've always burned with the thing open a couple of turns, figuring for the cat, more is better. I've never expetimented with it. The manual just makes note of the air control, without any real guidelines for its use.
    Any cat stove vendors or anyone support them here have any input?
  5. Eric VW
    Here's some light reading on the subject...
    Fluid dynamics - Wikipedia
    MightyWhitey and saskwoodburner like this.
  6. Eric VW
    Found this in a Gooble search....from another forum-
    Pay no attention to the fact this is about OWB's in general.
    Reference not cited:
    10-12 LBS of air are required to burn 1 LB of wood efficiently. The actual stochiometric ratio (Thanks - having that word allowed me to do a useful Google search instead of stumbing around!) is around 6 but more air is required in real burners.
    This slideshow from EPA pg 11 shows that wood combustion requires about:
    1100 to 1500 F temperature
    Air ratio of 10-12 : 1 air weight to fuel weight
    Residence of 204 seconds in high temperature zone
    No flame contact with cold surfaces that quench the flame
    12 lbs per pound would mean that a wood stove that burned 40 LB of wood in 2 hours would produce about 125,000 BTU per hour, and would burn up 0.33 LBs of wood per minute, needing about 49.4 say 50 CFM of combustion air. YMMV depending on wood species, moisture, and the usual other variables.
    A bigger furnace that burned 75 LB of wood in 2 hrs would require 92.5 say 100 CFM of combustion air and produce roughly 235,000 BTU/Hr.
    Thus a really small fan should be enough to supply the combustion air. These fans have little static pressure capacity, so generous ductwork would be needed to keep the static pressure under the spec of 0.26 inches W.C. This fan is more expensive but should handle more pressure
    >>>>>>>>Preheated combustion air is a lot more important that I realized, since temperatures under 1100F will put out the flame. My own experiments with a heat gun also showed this - there was clearly a lot more secondary combustion observable when the heat gun was set on "10" and provided hot secondary air, rather than set on "0". Of course in a real stove one would never use electrically preheated combustion air, this was just an experiment. But an outdoor wood furnace could potentially be sucking in flame-robbing cold air below zero - it isn't just the BTUs required to heat the air, heated air helps the flame stay hot. That is really interesting.
    brenndatomu likes this.
  7. saskwoodburner
    saskwoodburner
    Might need to dumb that down a bit for my brain to grab it!:rofl: :lol:
    Eric VW likes this.
  8. Eric VW
    I shoulda used the appropriate smiley above... :picard:
    I can only grab a portion of it myself.... I'm not really too much of a :nerd: myself!
    saskwoodburner likes this.
  9. chris
    chris
    SE WI
    My first stove circa 2002 was set up with both primary and secondary air control- sorely miss the secondary control on today's stoves. I could get almost a ten hour burn from a full load. Unheard of now with something the size of a NC13. It was a tube stove made out west somewhere - Company declined to spend bucks on EPA so shut that part of business down.I still have it will have to look at the name on it.
  10. papadave
    The secondary air intake on the 30 is 2", I believe, and the primary is 3". Less air, but I almost never completely shut down the primary so probably similar volume on a normal burn.
    Hmmm
    I did move the aluminum tape back over about 1/2 of the secondary intake a couple days ago, and notice it needs more primary to produce the same kind of secondary burn. The tertiary (doghouse) air is still doin' it's thing.
    Overall, I don't think much has changed but the air adjustment.
    Back to our regularly scheduled burn method.
    Eric VW likes this.
  11. MightyWhitey
    MightyWhitey
    But your chimney is still "drafting" the same when you "slide" you lever in.................all you're doing is causing the air entering the stove (via the draft from the chimney) to enter the "burn box" in different locations!! Doesn't matter if secondary and tertiary/doghouse air is regulated or not!!!
    papadave likes this.
  12. papadave
    I thought that was the point I was trying to convey.
    Evidently, I didn't succeed.
    However, as stated in a previous post, if all intakes were regulated, there would be less air being drawn in if I chose.
    It would probably burn like crap though.
    I'm done messing with it, and the tape is coming off the secondary intake. That little experiment didn't change burn time.
    Eric VW likes this.
  13. brenndatomu
    When your primary adjustment is wide open you are flowing a lot more air through the stove (in total) than with it closed, the secondary air system tends to be long with lots of turns and kinda restrictive, so with the primary wide open you may be 90% primary, and 10% secondary...whereas when closed it may be just the opposite, 10% primary, 90% secondary...but as I said before, the total air flow is way down...that is part of the reason you see the STT go way up when you close down the primary air...yeah once secondary combustion starts, the firebox temp goes up, but also the hot flue gasses have more contact time with the stove top due to the lower velocity (less CFM through the stove and up the chimney)
    Matt Fine and saskwoodburner like this.
  14. MightyWhitey
    MightyWhitey
    I'm gonna disagree.....................and think about this some
  15. brenndatomu
    Feel free...once you do a little more research you will find I'm right.
    Ever look at your chimney with the air wide open vs closed down? (early in the burn, when you can still see the steam)
    I have, and there is obviously much more volume/velocity coming from the chimney when the primary air is wide open...
    Eric VW and saskwoodburner like this.
  16. saskwoodburner
    saskwoodburner
    I believe the same, when primary is throttled back, there is less total air flow through the stove, and the percentage running through the secondaries is increased in relation to the primary.
    I also believe the air intakes (6 holes on my stove) for the secondaries eventually limit or slow the air flow, although still flowing more than needed. This may cause the whistling I hear under crazy wind/hard draft.
    I know some think that air is air, and it will flow no matter what, but let me ask this. If you duct tape a 4" pipe to your face and breathe for a minute, then do the same with a garden hose, then do the same with a straw, do you think the outcome would be different?
    papadave and brenndatomu like this.
  17. brenndatomu
    Bingo!
  18. saskwoodburner
    saskwoodburner
    Now I just need to figure how much airflow I need to cut on the top end of the secondaries to achieve just an extra " random percentage" of settle down.
  19. brenndatomu
    Yeah, that is kind of a trial and error thing, I think it will be different on every model stove, and every install...I was able to cut about 1/3 off on my wood furnace secondary air inlets with no ill effects...it didn't extend burn time a ton...but it did extend it out to the point of being noticeable.
    If you go too far it will make your coals last forever...but that doesn't help you if its really cold out and you need maximum BTUs...at that point a lil more primary air will do more good that anything...
  20. papadave
    Ah jeez, another experiment I'm gonna' feel obligated to try.......not.:rofl: :lol:
    MikeInMa likes this.
