How long to you go before you turn a bar over?
Discussion in 'Chainsaws and Power Equipment' started by Lastmohecken, Oct 15, 2020.
  1. buZZsaw BRAD
    Using a longer bar its a good idea to turn it up.
  2. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Anytime I have seen wear there, it's caused by a loose chain.
    drumbum, mat60, fox9988 and 4 others like this.
  3. brenndatomu
    That might explain why I haven't had an issue with wear, despite not flipping very often...I try real hard to keep the chain adjusted, because I hate having them jump off/try to come getcha! :startled:
    Plus I think they cut better when tensioned properly...pretty easy to keep tight if you are checking it when touching up the teeth upon every re-fuel like I tend to do.
    mat60, ThomH123, JackHammer and 3 others like this.
  4. Lastmohecken
    Lastmohecken
    Arkansas
    I really try to keep an eye on my chain tension, anymore. I don't like throwing chains.
    mat60, brenndatomu and Horkn like this.
  5. ThomH123
    ThomH123
    East Granby
    I flip every other sharpening or a good days cutting, I like to clean everything also, easier to keep clean than doing a big cleaning. I like to put the straw of penetrating oil in the oiling holes on the bar, both sides, you can see it blow out in the chain link groove.
  6. Lastmohecken
    Lastmohecken
    Arkansas
    Good idea on the straw to blow the hole out.
    coreboy83, mat60 and brenndatomu like this.
