How long to you go before you turn a bar over?
Discussion in 'Chainsaws and Power Equipment' started by Lastmohecken, Oct 15, 2020.
  1. mat60
    mat60
    ME
    Thanks.. I was wondering what to look for.
    amateur cutter and brenndatomu like this.
  2. Dumf
    Dumf Banned
    Maine
    Now THAT is one used bar. :salute::salute:
    Comments from the FHC peanut gallery ?
  3. campinspecter
    campinspecter
    Woodwidow pointed out that I got this one on upside down the first time!
  4. Horkn
    In order to turn a bar over, you'd need to drink all the liquor first.
    Oops, wrong kind of bar.
    I think the answer is a lot sooner than I've been doing it.
    I think I need to swap a new bar into the 029 super. Even with a freshly sharpened chain, it wants to cut at an angle.
    MikeInMa, Marshel54, ThomH123 and 7 others like this.
  5. bushpilot
    bushpilot
    Eastern Washington
    I never flip mine.
    M2theB, campinspecter and mat60 like this.
  6. Dumf
    Dumf Banned
    Maine
    Flip Greg. It'll last longer.:makeitrain":makeitrain"
    BTW--bars have two equal sides ( here at least ).:faint::faint:
  7. bushpilot
    bushpilot
    Eastern Washington
    I am starting to gather that. I guess I can just flip it whenever the bar comes off, and then it is not something new I need to think about.
    mat60 and campinspecter like this.
  8. SD Steve
    SD Steve
    South Dakota
    I usually flip it over every time I change the chain out. And like someone said, if it has burrs on the sides I file them
    M2theB and mat60 like this.
  9. Ohio dave
    Ohio dave
    Akron, OH
    I flip mine whenever the chain needs sharpened or replaced.
    M2theB, mat60 and jmb6420 like this.
  10. Nixon
    Nixon
    West Sunbury,Pa .
    I flip mine whenever I remember to .
    MikeInMa, M2theB and mat60 like this.
  11. buZZsaw BRAD
    I used to flip every time i sharpened the chain. Lots of times i "field" sharpen on the tailboard of the PU and dont flip it then. When i pull the bar and chain off and use the vise to sharpen then it gets flipped. Im not religious about cleaning schmutz when bar is off and cant say ive noticed any oiling issues. Have you adjusted the oiler on your 362? Screw on saw bottom. Some guys turn it all the way up.
    MikeInMa, M2theB, mat60 and 1 other person like this.
  12. Chud
    Chud
    NC
    Turned up to 11 on every saw. Not sure why that screw even turns left.
  13. Horkn
    Some saws will leave a lot of oil flinging off the end of the bar if you crank them up to 11. My dolkita with a 20" bar was set way too high when I got it and would spray oil from the bar while cutting. I turned it down a bit and it doesn't make a mess anymore. On pro saws, of you use a shorter bar option, and the saw can use a much longer bar, you'll see this. To run the longer bars, you need to turn the oiler up.:yes:
  14. Hoytman
    Hoytman
    OH
    I once watched a very experienced tree climber/trimmer/arborist cutting some treated post to points on one end. Couldn’t figure out why his saw wouldn’t cut. Stopped several times and had the saw completely apart. He was having a really bad day. Finally got fed up tossed the saw in the work truck, said screw it and went and sat down.:hair::headbang:
    I grabbed the saw:whistle:, took the bar and chain off, flipped the chain around the correct way, fired it up and cut posts for two hours with the same saw. :D:rofl: :lol::rofl: :lol:
  15. Lastmohecken
    Lastmohecken
    Arkansas
    I am not sure that my oil flow is adjustable as it comes stock on the 362. Actually, I think I am going to post a new thread on that subject. There does not seem to be a screw on the bottom. I think it's an optional feature, I would have to add, but I suspect that I need to add the option.
    mat60 and buZZsaw BRAD like this.
  16. buZZsaw BRAD
    Im not 100% sure but i believe an adjustable oiler is a standard feature on pro model Stihl saws. Had to satisfy my own curiousity...just went downstairs and checked. My 261, 361 and 460 all have them. Its on the underside and recessed into the housing. Orientation arrows for more or less oils.
    mat60 and M2theB like this.
  17. Hatchetdancer
    Hatchetdancer
    Let’s just say I needed to run the chain really tight. I did flip it every other time. That’s the last time I’ll run a Stens bar. I’ll stick with the Oregon from now on.
    mat60 likes this.
  18. Lastmohecken
    Lastmohecken
    Arkansas
    I see the Orientation arrows, but no screw. Is the screw right by the arrows?
  19. brenndatomu
    It's down in the hole...hard to see...just stick a small/mediun sized flat blade screwdriver down in there...it should drop into the slot...
    mat60, M2theB and buZZsaw BRAD like this.
  20. Lastmohecken
    Lastmohecken
    Arkansas
    I found it. That little bugger was hard to see, and not where I expected to find it. It looks like it only turns about a half a turn all total and it was in the middle, I turned it up all of the way, and now I do get some oil flying off if the end of the bar. Since I am running a 25 inch bar, I suspect I should run it on the high side. At least I can tell I am getting more oil now.
    Thank you.
    MikeInMa, mat60, M2theB and 2 others like this.
