How long to you go before you turn a bar over?
Discussion in 'Chainsaws and Power Equipment' started by Lastmohecken, Oct 15, 2020.
  1. Lastmohecken
    Lastmohecken
    Arkansas
    I was just wondering how long most people go, before then turn their bar over on the saw. I know some people never do, but it makes sense to me to do that before the bar get's badly worn. Do you just look for wear, or rotate over when you have worn out a chain? After so many sharpening's? After a season's cutting or a certain amount of wood cut?
    Also, how often do you remove bar and chain and just clean everything up. Do you ever have problems with the oil delivery to the blade stopping up and needing to be cleaned?
  2. Chud
    Chud
    NC
    I flip it every time I sharpen the chain.
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I flip it every 2 sharpenings.
    amateur cutter, mat60, jrider and 2 others like this.
  4. coreboy83
    coreboy83
    NW of Twin-Cities
    I flip every time the chain is off. Saw gets completely blown out and serviced after a hard day of cutting. I do my rakers every 3 sharpenings
  5. Chud
    Chud
    NC
    Didn’t read it all. The bar groove and oil cut out will get caked up and should be cleaned. There is a specialty groove cleaner tool but any hard plastic or metal piece that can fit the groove will work, but something needs to be poked into oil hole to make sure it clean. Compressed air is good for blasting the oil hole, but doesn’t always get everything out of the bar groove.
  6. thewoodlands
    thewoodlands
    I flip it when I clean the bar after cutting for a certain amount of time. If I don't think the chain is getting the oil it should, I clean the saw and the bar and flip it. I've been cutting a bunch of dead pine so it can get flipped three or four times a day.
  7. Lastmohecken
    Lastmohecken
    Arkansas
    Thank everyone.
    It sounds like I need to do a little more saw maintenance, then I have been doing.
  8. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I flip it when I clean the saw after cutting for the day.
  9. brenndatomu
    Wow, you guys flip alot. o_O
  10. JimBear
    JimBear
    I flip my bar every time I change the chain, sometimes once a day, sometimes several times. It just depends on how long I cut & how much debris I hit. I don’t sharpen in the field, I take several chains, there are always rainy or snowy days to sharpen in the shop.
    I carry a putty knife to scrape the bar down & clean the bar groove out. Honey Locust thorns work great for this also as well cleaning out the oiler hole. They make nice tooth picks as well.
  11. JustWood
    JustWood Guest
    I feel for a burr on the rail occasionally . When there is one I’ll flip it and file the burr off.
  12. Dumf
    Dumf Banned
    Maine
    I get dentist "picks" used for cleaning and probing teeth for the bar and saw cleaning.
    The picks are ideal for those tiny oil holes, the bar groove, and those dirt clogs inside.
    Dentists throw them out when they're used a few times, even sometimes new in a sterile package.
    I give extras to my pros.
    Don't do your teeth with them. :doh::doh:
    Of course do as Msr. Dennis recommends, file bar burrs sides and top with each sharpening.:thumbs:
    amateur cutter, Horkn, mat60 and 3 others like this.
  13. Homemade
    Homemade
    Wisconsin
    Anytime the chain is off but then I forget which way I had it after cleaning out the bar groove and so on, so it’s pretty random which way it goes back on.
  14. Backwoods Savage
    Usually every other filing.
  15. coreboy83
    coreboy83
    NW of Twin-Cities
    "Hey, your blade is upside down" :headbang:
  16. campinspecter
    campinspecter
    When I put on a new chain .
  17. fox9988
    fox9988
    NW Arkansas 72717
    When the rails need filed (by feel), I remove, file and flip.
    M2theB, amateur cutter and dingbat like this.
  18. jrider
    jrider
    I don’t sharpen on the saw so each time I take a chain off and put a new one on, I flip.
  19. Hatchetdancer
    Hatchetdancer
    Even if ya keep flipping they’re still going to wear out 9D686B79-FE1A-4B7A-911A-CF7169023AE0.jpeg
  20. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Pretty much the same as many have said. If chain comes off, the bar usually gets flipped. And after a cutting session of any length saws get blown out with compressed air, including bar groove and oil holes, and the little grease hole for nose sprocket. I don’t sharpen in the field, instead I carry several extra chains for each bar length. Air filters get blown out pretty regular too
