How long does it take to get your garage / workshop warm with your pellet stove
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Jan 14, 2017.
  1. Pete Zahria
    Pete Zahria
    New Hampster
    No.
    You can run a gas furnace in your garage...
    I guess gas is a lot safer than pellets.. :rolleyes:
    I have four gas appliances in my basement.. I can see open pilots on all of them.
    I see no open flame on my pellet stove...
    Dan
    Orson_Yancey likes this.
  2. Lousyweather
    Lousyweather
    in alluding to garages, I believe its SOLID fuels which are prohibited.....going on memory here though, and cant comment on gas.
    stuckinthemuck likes this.
  3. don2222
    don2222
    Salem NH
    Hello
    I think you are correct about solid fuels LW
    However if pellets are accidentally dropped on the garage floor, is that so much more dangerous than oil or gas leaking on the garage floor? Are they not more flammable???
    Just trying to make sense of it all but time is a factor about when these codes were developed like ArtC said.
    Maybe there is not enough effort in making a relatively safe pellet stove into acceptable garage heat with a specific type of install?
    Anyway here is what I just found on acceptable garage heat! Hope this helps Artc ?
    Look at the time when some of these codes were written
    Late 1950's !!!
    Code Acceptable Garage Heaters
    Heating (§ 13-108-080)—Chicago Decoded—Chicago Decoded
    artc likes this.
  4. Lousyweather
    Lousyweather
    I think, yea, gas and oil are considerably more flammable than pellets, not to mention the flammable vapors. I would drop a lit match in a 5 gallon bucket of pellets all day long.....drop a match in a 5 gallon can of gasoline though? I don't think so. I think the pellets are considerably less flammable, but I have to guess that its the vapors that are dangerous. Do you think the stove, or glass, can get hot enough to ignite gasoline? (that's around 495 degrees) I know burnpot temps go way above that......
    don2222 likes this.
  5. stuckinthemuck
    stuckinthemuck
    I thought the deal with solid fuels is that you can't stop them with an off switch. My oil boiler in my basement has a red emergency off switch. The ability to immediately stop the flow of fuel to a heating appliance is likely the issue here. If some authority was to say, "you can't heat a garage", more people would violate the code. If they said you can only heat a garage with radiant floor heat, they wouldn't be allowing for self standing garages without requiring that the heating appliance be stored outside. The ban on solid fuel heaters is likely a compromise as a gas, oil or kerosene appliance can ignite lingering vapors just as easily as a wood or pellet stove.
    As with anything there are many interests involved. Often times, it is the insurance companies who determine what they will and will not insure. I think in the case of a pellet stove or wood stove in a garage, it would be up to the individual to understand that a related claim would be denied due to code violation. Doesn't mean a garage can't be heated with a solid fuel device safely. It just means that it's against the grain and not an accepted practice. Now for a licensed installer to do the job, it could be business suicide. The liability carried with a potential problem would cause cancellation of insurance and likely a lawsuit no matter how much paperwork was signed and how many warnings were given.
    Why isn't it against code to build a house at a beach that sees 12 feet of water every time a category III hurricane rolls through? Perhaps that's where the insurance company owners want to vacation so their special interests allow for insurance and federal relief every time they lose their second or third homes.
    I like to think that I do a pretty good risk assessment of my daily activities, but in doing my assessment, I do things that would be frowned on and could come back to bite me. One headlight out? Car shouldn't leave the driveway.. But I'll still drive it for a couple days til I can get it fixed. I've driven on tires past their useful life and I've leaned a step ladder against a wall and climbed up two steps (OSHA violation).
    Best thing to do is to stop and think about the potential risks of every decision, heed sound advice and consider the legal implications if things don't go as planned.
    Lousyweather, don2222 and Pete Zahria like this.
  6. Pete Zahria
    Pete Zahria
    New Hampster
    That is correct...
    Dan
  7. don2222
    don2222
    Salem NH
    I guess the vapors from the gasoline are the main concern. The old wood stoves did not have outside air kits. Therefore if the pellet stove has an outside air kit to bring in fresh air for the fire then it is much safer than oil or gas and Kerosene appliances that use room air with flammable vapors they can pull in and ignite!
    That is why the gas heater must be higher than 8 feet in the code to be above the vapors!!
    So that settles it! :)
    Lousyweather and artc like this.
  8. Lousyweather
    Lousyweather
    unless you open the front door of the stove........then, well, direct contact with the vapors :deadhorse:
  9. Pete Zahria
    Pete Zahria
    New Hampster
    I believe that is so you can't hit it...
    I think the fuel rail on a furnace has to be at least 18" off the floor...
    I agree LW:
    Dan
    Lousyweather likes this.
  10. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I have been around and through the ringer with the county on pellets...
    The insurance WILL allow it however they want a waiver from the county and the county will not allow anything but NG or Propane. I have actually been told it's bad for business by the county to use anything other than NG or Propane.
    Code 10% air drawn in from the environment required which means the furnace has to be elivated 2ft on a approved base and not hanging on the wall to be above the fumes.
    Pellet stove do not have 10% air intake from inside it's either all or none. Why can't I use a pellet stove and draw through an oak kit ? Resolving the fumes issue. The county has yet to give me any other answer than bad for business that indicates a real explanation... It is not against the law in my county but you are not allowed to draw a permit without insurance approval. The insurance company will tell you that it's a no go without having the correct permit from the county that they know you can't get.
    For my house it's a decorative devise requiring no final install inspection. That makes no sense to me.
    After arguing for over a year I gave up. It's very obvious to me that they are affiliated with the gas company here even if it's not financial...
  11. don2222
    don2222
    Salem NH
    What does it take to make it classified as a room and not a garage?
    Then a pellet stove would be easily approved.
    Pallet Pete likes this.
  12. Lousyweather
    Lousyweather
    In our town, its an overhead door........overhead door=garage
    Pete Zahria likes this.
  13. Pallet Pete
    Ovid
    According to the county no chemicals of any kind gas, fuel, paint and so on not even cleaner spray bottles during inspection in the room and it had to be permanently closed in with no garage doors. They can not be temporarily closed they have to be walls with a man door and nothing bigger.
  14. don2222
    don2222
    Salem NH
    I have a friend that has a nice detached 2 car garage. Not much room for a pellet stove with the 2 cars rolled in. There is a gas grill with a nice hood vent in the back on one side and a fridge and TV on the other side in the back. Therefore he got a nice US Stove Wall mount pellet stove on the left side. This way he can still get the truck in there. :)
    The stove works great and takes up zero space!!!
    The venting is like the Selkirk DT that brings in fresh air thri a 3 Rd wall
    He did have one of those Window Pellet stoves which worked fine but this Wall Mount Pellet Stove is so much safer and the wall mount puts out much more heat!
  15. Dr.Faustus
    Dr.Faustus
    Hudson Valley
    my answer is "never". I have a completely uninsulated detached 2 car garage. starting temp is always whatever it is outside. If i were to put my 25pdvc in there it could run all day and probably bring it up just a few degrees. Thats just a guess. For the garage i use a large torpedo heater with either kerosene or diesel in it. That raises the temp in a hurry if i want to work on something. If im there an hour it can hit 80 and really start to melt the snow off the roof.
