How Long Does it Take For the Pellets to Catch Fire In Your Stove?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Orson_Yancey, Nov 20, 2017.
  1. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Larry, 113/67
    savemoney likes this.
  2. savemoney
    STB 133/73 after meds and coffee
    SmokeyTheBear likes this.
  3. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Hey the docs used to shoot for that kind of reading now I have no clue what the ole saw bones will be going for.
    bogieb likes this.
  4. savemoney
    I only get that reading 2 hrs after meds. Usually up in the 150-160 range. Heavy dosing of meds, makes me have dry mouth and feel dizzy. Slows memory. New standards "High blood pressure should be treated at 130/80 rather than 140/90, according to the new parameters set forth by the American Heart Association, the American College of Cardiology and nine other health professional"
    bogieb likes this.
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    They will no longer recognize what was "high normal" at all it becomes hypertension and they want to get things below 130 and below 80 now as I understood the 2017 guidelines.
    ETA: Most non Beta blockers start working about one hour after swallowed but don't reach maximum strength until many hours later. Beta blockers are usually immediate and have relatively short half lives. Note half lives are all over the place and can change on you, note amLODipine has a half life of 30 to 50 hours and takes days to reach steady state in the blood stream however metoprolol tartrate goes from 3 to 9 hours (or in my case from 9 to 3 hours).
  6. savemoney
    Right you are. If the numbers come down, so does the numbers of strokes and MI's. I lay a lot of the problem to processed foods, too much of it. Processing food with all these chemicals has an impact. Not good.
  7. Pete Zahria
    Pete Zahria
    New Hampster
    Just because it was cheap, doesn't mean it won't work.
    It could have had a decent alcohol content....
    I like cheap.
    I is cheap.
    Dan
    (when I start my shop stove, I never use the autolight..
    I go right for the mapp gas and lighter fluid... would do the same on the Harman if need be)
    imacman, SmokeyTheBear and bogieb like this.
  8. badbob
    badbob
    OK Cleaned the Accentra,so sucked a good bit of pellets out of auger,did not prime system,Took 6 minutes,and I think I have the 300 watt ignitor,seems like they make a 400 now.
    imacman and bogieb like this.
  9. subsailor
    subsailor
    Winthrop, Maine
    That's 2 of the 3 I take.
  10. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Is the third one an arb or ace inhibitor?
  11. subsailor
    subsailor
    Winthrop, Maine
    IDK. Losartan.
    jtakeman likes this.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    That is an ARB I take lisinopril an ACE inhibitor.
    ska as a pit viper venom chemical analog.
  13. jtakeman
    Thats what I take. 50 mg a day. So far so good.
    imacman and subsailor like this.
  14. brokenwing
    brokenwing
    Northern MD, Near the PA LIne
    I love the air pump pellet stove fires up really quick, usually less then 2 minutes, I have good fire going!
  15. ivanhoe
    ivanhoe
    Northern Ontario
    Just checked the Fahrenheit furnace and it was 2:45 and that includes the auto-clean at start off:yes: and also has a air pump assistance:thumbs:
  16. vtktm802
    vtktm802
    Hyde Park, Vt
    About 2 minutes on a cold start off, just wish I had 10k more btu's.
  17. jtakeman
    Got room for a second stove? We have several members who do and Are much happier. Nothing worser than being cold.......... The older I get the more I hate it!!
    Or replace the PS 50 with a big giant beast or a pellet furnace if you can afford it. A bunch of members seem to really like the 50F.
    bogieb, SmokeyTheBear and imacman like this.
  18. vtktm802
    vtktm802
    Hyde Park, Vt
    Nope, no room for a second unit. have the PS50 in the basement where the wood stove was.
    Small raised ranch, approx 1000 sq ft, Peerless oil fired boiler. In a nutshell I was on a budget
    after a kitchen reno last fall. Even doing the work myself it all ads up. Plan was to get a p61 but
    I was being a cheap bastard and thought let's see if the pellet heat will go upstairs. Well it does
    but not at the rate the wood stove did. May try and find a used P61 next yr. Also want to research
    a pellet conversion on the boiler, any info here on these ?, hey pellets are easy on the ole back.
    :thumbs: :thumbs:
  19. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Add 10 years and they aren't so easy on the ole back. There are pellet fired gun burners but the conversion isn't just insert new burner where old one was.
  20. bogieb
    There is a system for using the pellet stove for FHW and having the boiler run in tandem as a back up. Dang if I can recall what it is called though.
    imacman likes this.
