How Long Does it Take For the Pellets to Catch Fire In Your Stove?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Orson_Yancey, Nov 20, 2017.
  1. CleanFire
    CleanFire
    4-5 minutes here.
    IHATEPROPANE, imacman and Rich250 like this.
  2. ChandlerR
    ChandlerR
    Seacoast NH
    Mine lights in 20 to 25 seconds. But...I'm using a torch with MAP gas! :rofl: :lol::dex:
  3. bogieb
    P61a is 6-10 minutes. Actually, if it has short cycled and is still warm it may only take 2 minutes.
    P43 is 4-6 minutes - this stove doesn't short cycle
  4. Dpopps
    Dpopps
    MI
    Mine takes about 2-3 MIN
  5. CleanFire
    CleanFire
    That sounds like more fun! :thumbs:
    Russell, bogieb, ChandlerR and 2 others like this.
  6. jtakeman
    Not that bad really. Put some pellets in the pot. Grab the torch. Stick it to the pot and hit the go switch. Sis had a Harmone P38 manual light And I had to use this trick when my ignitor when flouey......
    Russell, CleanFire, bogieb and 2 others like this.
  7. imacman
    imacman
    Denver, NC
    Cheap hand sanitizer too.
  8. subsailor
    subsailor
    Winthrop, Maine
    What do you mean by short cycle?
    Russell, CleanFire and bogieb like this.
  9. badbob
    badbob
    I think he means,stove is still warm,comb. fan still running,but no burning coals in pot?
  10. Pete Zahria
    Pete Zahria
    New Hampster
    Just make sure you get the highest alky percentage you can...
    Junky stuff doesn't work for crap...
    If you don't really have to use it that often... get the real deal starter..
    Dan
    Russell, CleanFire and badbob like this.
  11. badbob
    badbob
    Ya I found that out the hard way,many years ago,torch much easier
    Russell and CleanFire like this.
  12. bogieb
    Where it is still warm as it is starting back up (running on temp probe).
    Russell, subsailor and CleanFire like this.
  13. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    We have one self starter (Quadrafire 1000) and it will auto lite in about 1-2 minutes if the pot is clean and there are no clinkers covering the igniter port, and if there are some clinkers then the time goes up a bunch with far more smoke too.
    Our Whitfields are hand lite and I use a propane torch
    I add a few pellets, hit it with the torch with the door nearly closed and within 2 minutes from start to finish I have a fire going, and then switch the auger on and let the nut shells fall on the burning pellets.
    I can start with shells but the smoke at startup on the shells is nasty if it poofs into the room and makes the house smell like a 5 alarm kitchen wreck. :bug: so I use a few pellets.
  14. CleanFire
    CleanFire
    You get to play with FIRE ! :dancer: :ups::banana:
    :fire::MM::campfire:
    Pushing the Start Button is so freakin' boring. :D
    Happy Turkey Day everyone ! :handshake: :stirpot: :cheers: :drunk:
    Russell, bostonfan49 and bogieb like this.
  15. savemoney
    Seems like it is only 2-3 min. but to be honest, I haven't timed it. Whenever I thought it was slow, I knew it was time to vac it out and brush down the pot really good.
    This stove is so simple to keep clean.
    Russell, bostonfan49, imacman and 2 others like this.
  16. Pete Zahria
    Pete Zahria
    New Hampster
    Longer than what I read here.......
    Dan
    bogieb, imacman and CleanFire like this.
  17. subsailor
    subsailor
    Winthrop, Maine
    Ok, thanks. Never heard it called that.
    bogieb and CleanFire like this.
  18. bogieb
    I just didn't know what else to call it.
    subsailor and savemoney like this.
  19. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I haven't had to manually start mine in almost three years but it only took about a minute, that is likely longer now for some reason. I soak a handful of pellets in a cup using rubbing alcy, then into pot followed by a match. Fire starts up fast.
    ETA: If things are clean it takes about 2 minutes to light off with the cartridge heater.
    bogieb and savemoney like this.
  20. imacman
    imacman
    Denver, NC
    If the ignitor went out, I wanted to get fire easily, so I tried the dollar store stuff.....worked just fine.
    bogieb, savemoney and jtakeman like this.
