How do you split?
Discussion in 'Chainsaws and Power Equipment' started by redRover, Jun 9, 2016.
How do you primarily split?
  1. Manually (Maul, wedge and sledge, etc)
    26.8%
  2. Horizontal only hydraulic splitter
    17.1%
  3. H/V mostly in vertical
    9.8%
  4. H/V mostly in horizontal
    40.2%
  5. Other
    6.1%
  1. HDRock
    Good thing too.
    Was no carrying this bugger.
  2. Andyshine77
    Andyshine77
    Cincinnati, OH
    I won't even fiddle with rounds that large. I find it faster and more efficient to just noodle them up. The hernia helps make the decision even easier.
    Stinny, HDRock and Kyle Mulligan like this.
  3. NHMike
    NHMike
    Central New Hampshire
    I have a Super Split splitter & use my tractor to help save my back. I load the bucket with the rounds and park it by the splitter. To make it easier on my back, I use the backhoe to lift all the logs up so when I cut the rounds, everything is at waist height.
  4. clemsonfor
    Splitting is what kills me. If I am bent over that long cutting I will take a knee sometimes so that it does not have me doubled over so long.
    HDRock likes this.
  5. Gasifier
    All depends on the size of the rounds. Bigger-more vertically. Smaller-more horizontally. I usually split more vertically, but lately have found putting the loader bucket right underneath where I split I can fill the bucket by catching the splits right off the horizontal. Then just bring the loader over to the stacks. Saves work.
    Andyshine77, HDRock and redRover like this.
  6. Fishnuts2
    Fishnuts2
    SE, MN
    Monster Maul and an old car tire to hold the shivering pieces till I get another whack at 'em.
    My wood is across the lake and I don't feel like trying to get a splitter across by boat. Monster Maul is faster anyways.
  7. dusky
    dusky
    Pittsburgh
    Wo-manually with a Stihl PA 80. Occasionally bring out the sledge and wedge but not often.
  8. Boog
    Boog
    Where my spirit is free
    Like many of you, I've split with a 23lb monster maul my whole life (HS teens to 61) until two years ago when I picked up an old H/V splitter. Horizontal 95% of the time. I'm 6'3" and found the splitter too low for comfort, started hurting my back right away. I solved the problem by backing my splitter up onto a set of "car ramps" used for auto repair. That raised it almost a foot higher to a nice ergonomically correct height for me.
    HDRock, Fishnuts2, unclefess and 2 others like this.
  9. LinkedXJ
    LinkedXJ
    Indiana
    Ignore the wood near my small garage..
    This wood doesnt sit here long at all.
    unclefess, HDRock, dusky and 2 others like this.
  10. dusky
    dusky
    Pittsburgh
    Liking your double wheelbarrows, IMO can't have enough wheelbarrows!
  11. clemsonfor
    The dang things cost so much now a days for the deep ones!
  12. LinkedXJ
    LinkedXJ
    Indiana
    It works very well for me
    The one on the left was the first one i ever bought. Had the 8cu. ft. poly tub.
    Didnt last but a few months once winter hit.
    The one on the right i picked up for free off of craigslist.
    Both are 6 cu. ft. steel tubs.
    Now just the other day.. a brand new temper popped up on craigslist, 8 cu. ft. poly tub.
    Had to have it. Got it for $60, never seen dirt.
    Big problem i had with my ast poly tub was that the bottom of it/floor cracked.
    the cracks just kept on traveling.
    I reinforced the floor on this one with a piece of 1/8" aluminum.
    Did the same to the previous poly tub but did it too late. That happened
    after it had already cracked.
    Going to try and take it easy on my new one.
  13. clemsonfor
    I have a larger metal tub one I got free. Has been used to mix con rete by a previous owner. I use it a lot for wood
    dusky likes this.
  14. dusky
    dusky
    Pittsburgh
    My big wheelbarrow I use the most has a poly tub with a huge crack. It still works for most things so I don't mind. I got it in a package deal of a bunch of useful things that I got in a barter deal. I landscaped a neighbor's house before they sold it. They were moving cross country and only taking what fit in their car and a POD.
    I have back up wheelbarrows with steel tubs, different sizes. Add in the pneumatic tire hand truck and I can move a lot all by my lonesome.
    clemsonfor likes this.
