How do you clean your chimney?
Discussion in 'Modern EPA Stoves and Fireplaces' started by wood and coal burner, Aug 13, 2019.
  1. Eric VW
    :whistle:
  2. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    I understand and if any cats were injured in the cleaning of any pipes I make this offer:
    amateur cutter, Horkn, Marvin and 5 others like this.
  3. justdraftn
    justdraftn
    On the road
    ….now that brings back some great memories.
    Side note: fuses burned under water.
    (how did I know that?)
    Biddleman, Horkn, Chvymn99 and 4 others like this.
  4. Brandon Scott
    Brandon Scott
    Does me too. Packed in mud.....made the best fishing lure I ever used.
  5. eatonpcat
    You are a brave man Tim (Since we are on the subject of abusing cats - Octopu$$y)!!:beerbbq:
  6. Brandon Scott
    Brandon Scott
    amateur cutter, Horkn, Marvin and 6 others like this.
  7. Backwoods Savage
    Getting back on track... I don't clean the chimney. My wife does it all! Easy too as we have 6" stainless that runs outside the wall. Just remove the bottom cap and stick the brush in; push it up and hook on another length of rod and push it up again. Only about a 10 minute job and even then she doesn't get much of anything but she feels better by cleaning it annually. With our stove and good wood, we could clean it maybe every 4 or 5 years or thereabouts.
  8. TurboDiesel
    I didn't clean my flue (the vertical run) for the first five years. Last year i brushed it and just got some loose dusty stuff.
    I do clean the connector pipes, snout, tees and clean-out each year before the start of heating season. There usually is a little flaky black junk there.
  9. FatBoy85
    FatBoy85
    Washington State
    It fails if the holder isn’t a reader....
  10. Highbeam
    Highbeam
    Funny how it’s not in 12 different languages
  11. Highbeam
    Highbeam
    I clean both chimneys one time every year whether they need it or not. They have never needed it because I clean them preventatively.
    I have gotten a cap pretty dang clogged a few times after wearing out cats or with a noncat but before I realized that screen filters are a bad idea. The actual chimneys hardly have anything.
    Oh and for the how question, I use a sooteater from the bottom up. Right through the loading door. Works great.
  12. bushpilot
    bushpilot
    Eastern Washington
    OK, so you have used cats to clean the chimney enough to wear one out? Is the noncat a dog? I am confused ...
    :confused:
  13. Ctwoodtick
    Ctwoodtick
    Southeast ct
    I use sooteater top down. Short easily accessible chimney. The hardest part is dealing with the cast iron baffles on my Jotul insert. Balancing these so that I can make sure the secondary burn tubes are in correctly is a major PITA.
  14. Hoytman
    Hoytman
    OH
    Last time I seen one of those...35 years ago...trash had just landed in the yard and the lid was still bouncing it’s way down through the limbs from a long trip to the sky. Lol!!!
  15. timusp40
    timusp40
    Lake Orion, Michigan
    Thanks to the sick humor of your members, I am leaving this forum. Nothing about these posts is good for FHC.
    amateur cutter and Brandon Scott like this.
  16. Brandon Scott
    Brandon Scott
    My apologies for offending anyone. All was in jest.
    FatBoy85 and Horkn like this.
  17. Horkn
    Lol. But they don't get that extra scratching action when you yank on the rope if you use the frozen ones.
    I just use the fiberglass rod and the nylon brush once in the fall before burning season.
  18. brenndatomu
    No cats were harmed in the writing of this thread...:D
  19. Horkn
    I'm not going to apologize to anyone. I only say things like this because it's funny. I hope you don't think any of us would hurt a cat. Now, you do have to realize that more of us are dog people.
  20. amateur cutter
    I clean my chimney by pulling the deflector baffle & leaving the door open for a few minutes. Works great & doesn't require much effort. :emb: Ok, ok I know, it's an outdoor boiler in a metal carport & I wait for a nice snowy or damp day. Haven't had enough buildup for any fireworks yet though, wood's pretty dry.
