How do I tune this saw?
Discussion in 'Chainsaws and Power Equipment' started by bobdog2o02, Jan 26, 2016.
  1. clemsonfor
    Nope? And also with a muffler modd you no longer have a stock saw either? You can get exhaust out easier and can pull air in easier so now you need more fuel. This may equate to more RPMs and maybe not? I am no super expert.
    saskwoodburner and bobdog2o02 like this.
  2. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Roger that, so the consensus is that the H is rich... I'll work on that tomorrow. Ill share another video after i work on it without the intro and backstory. I'll also try to remember to set the camera to FHD 1080P....
    saskwoodburner and clemsonfor like this.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    You probably want it to turn around 14,000rpm out of the wood.
    bobdog2o02 likes this.
  4. MasterMech
    Def a tad rich... But sounds beastly for a 38cc....
  5. MasterMech
    Is this a real thing? I have a hard time wrapping my head around how that works with a fuel pump in a diaphragm carb...... Constant pressure under the metering diaphragm is maintained by the pump and regulated by the inlet needle spring. It wouldn't change unless it was starving for fuel, either a pump issue, clogged filter, pinched/leaking line or just plain out of fuel....
  6. clemsonfor
    Is this maybe something from an oldschool partial gravity fed tank or something?
  7. colin.p
    colin.p
    Ottawa Canada
    clemsonfor likes this.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Here we go again.
  9. saskwoodburner
    saskwoodburner
    I think you've got it bout near perfect. Little bit of bounce in n out at the start of cut and then cleans up.
    clemsonfor and bobdog2o02 like this.
  10. clemsonfor
    Yep like saska said close if not perfect. Not sure if the times it went back to 4 stroking you let up on pressure or just the saw so I can't say for sure. I personally would leave it where it is and run a few tanks through it to seat rungs well. And if you still getting that swap from 2 to 4 stroke with constant pressure turn the H screw in just a tad and see what you have. A touch more fuel in break in is not a bad thing.
  11. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I noticed it happening too and I think it was the chain being extra grabby for the smaller displacement saw. I put a real good edge on it just before starting to cut those cookies.
  12. clemsonfor
    Well if you think thats the case I would leave it as be. I dont think its too lean so I wouldnt worry there.
  13. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Thanks everyone for their input and feedback. I'm a happy boy having put a new skill in my back pocket. Now for more practice, cue up the CS-400.
  14. 94BULLITT
    94BULLITT
    Try tooning a saw with a full tank and see what happens.
  15. 94BULLITT
    94BULLITT
    I think it sounds good. Now if you want to fine tune it you can make small adjustments and time your cuts to find where the saw performs the best.
