Honey Locust Honey Hole
Discussion in 'The Wood Pile' started by KSPlainsman, Nov 22, 2022.
  1. KSPlainsman
    KSPlainsman
    Kansas
    Of course. It just matters whether a guy wants to mess with it or not. I've done a lot of thorny honey locust trees. So I don't run from them, I can assure you of that. I took down a buddies thorny locust tree that yielded 3 cord, from one tree. The stump was 42"x48" and there were thorns everywhere.
    What will be the yield vs effort put out. This is a tiny tree and probably only 6 ft in length before it turns to crap.
    Something else I think of, is what to do with the thorns after I'm done shaving them off. I'd have to sit there and pick all those things up, out of grass and dirt. The gentlemen who own this farm, are going to push what's left in a pile with their tractor and burn it. That means there's going to be dozens of thorns, which are basically like nails laying around if I don't pick them up. That's an easy way to ruin tires and tractor tires aren't cheap to replace, or fix.
    So I'm trying to be respectful and realistic. That's a lot of tedius work for 6 foot of 6" locust and those thorns are better left on that tree, than all over the place. I will still end up with YEARS worth of wood without that little piece. :yes:
  2. KSPlainsman
    KSPlainsman
    Kansas
    Load 4 is on the ground because I forgot to take a picture, because I blew a tire.
    IMG_20221125_150018_858.jpg IMG_20221125_150026_638.jpg IMG_20221125_150048_348.jpg IMG_20221125_150052_278.jpg
    Sandhillbilly, SimonHS, Horkn and 7 others like this.
  3. KSPlainsman
    KSPlainsman
    Kansas
  4. The Wood Wolverine
    Did a thorn get the tire?
    Horkn, KSPlainsman and buZZsaw BRAD like this.
  5. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Your 5 loads would heat our place for a season +. Being locust maybe 1.5 seasons.
  6. buZZsaw BRAD
    That was my thought too.
    Horkn and KSPlainsman like this.
  7. KSPlainsman
    KSPlainsman
    Kansas
    Yep. Right through the frickin sidewall. I was dragging some limbs around to clear a better path and a few of them had thorns. They were from a pile that was there before I started. I did a quick visual, but apparently I'm Jeff Healey.
    MikeInMa, Horkn, JimBear and 3 others like this.
  8. KSPlainsman
    KSPlainsman
    Kansas
    That's why I didn't get my trailer loaded today. I didn't want to risk pulling a trailer back to town, in case I got another flat, since I didn't have a spare. Without the trailer, I could at least get hauled back, if my luck got worse.
    I did stop and weigh load 5 because it felt pretty salty. I'll weigh again on my way out of town, to see how many pounds I had loaded.
    Sandhillbilly, Horkn, JimBear and 2 others like this.
  9. The Wood Wolverine
    That sucks. I punched a hole in one of my truck tires sidewall once. It wasn’t that big so I patched it from the inside and kept it on the rear. Ran it till it wore out.
  10. KSPlainsman
    KSPlainsman
    Kansas
    I wish I could've done that here. It must've hit the worst way possible, because it was almost like a slit, instead of just a hole. I fixed tires of all kinds for 7 years and have never seen anything like it. It went flat immediately.
    I was needing to do something tire wise anyway, but was hoping to wait a couple more months. chit happens. Onward I go!
    Didn't you weigh a load on your Toyota?
  11. The Wood Wolverine
    Yep. HL is heavy stuff!! Between truck and my little 4x8 utility trailer I had about 4,800lbs of wood (and 2 saws)! And I wasn’t stacked near as high as I typically do.
  12. KSPlainsman
    KSPlainsman
    Kansas
    Lol That's a load for that little truck! You make that sucker earn it's keep and I love it!
    Load 5 weighed 8360 total. I haven't ever weighed my pickup, but they say they weigh about about 3250 lbs with an I6, plus me, 275. So probably 3600 with saws and what not. 4660 lbs loaded, unofficially.
  13. The Wood Wolverine
    My truck alone was 5060. 32 seems light for a full size truck. The Jeep was 46xx.
  14. KSPlainsman
    KSPlainsman
    Kansas
    Oh wow. Maybe it is off. I just searched "weight of a 80 C10 with I6" and multiple sites had it between 32 with 6 cylinder up to 4000 with a v8.
    This is basically what mine is. So it looks like maybe 3700
    https://www.cjponyparts.com/resources/1978-chevy-truck-specs
    This is just a 2wd, with an inline 6, not a V8.
    The scale is a half block away. So I'll get a weight in the morning.
    Horkn and The Wood Wolverine like this.
  15. The Wood Wolverine
    Ah, 2wd would be a good bit less for sure. I was surprised how heavy it weighed loaded. It's good to know for reference. I'm not looking to kill the old gal anytime soon.
    Horkn, buZZsaw BRAD and KSPlainsman like this.
  16. Chvymn99
    Those are some big chunks of HL... Lotta of BTU's there... :handshake:
  17. KSPlainsman
    KSPlainsman
    Kansas
    Yessir! That big round is 3' diameter and was starting to rot, but I'm burning it anyway. I've thrown whole pieces of locust that were that reddish brown color and they still put out some heat, just not quite as much, or for as long.
  18. KSPlainsman
    KSPlainsman
    Kansas
    So apparently, whoever came up with those numbers online is way off.
    I weighed my pickup with all the same stuff in it and it weighed 5020. So that load was 3340 lbs. Not too bad for a 42 yr old pickup with 330k on it.
    Out of curiosity, I weighed my load with a trailer today and it weighed 11,160. So 6140 lbs of wood and a trailer on load 6.
  19. KSPlainsman
    KSPlainsman
    Kansas
    Good evening everyone! Here's today's hauls. Load number 6. Started loading up some small stuff in the trailer.
    IMG_20221126_150021_384.jpg IMG_20221126_150054_873.jpg IMG_20221126_150035_907.jpg IMG_20221126_150050_014.jpg IMG_20221126_150108_236.jpg
  20. KSPlainsman
    KSPlainsman
    Kansas
    And here's load number 7.
