Homemade fire starters...on the cheap.
Discussion in 'Everything Else (off topic)' started by TurboDiesel, Aug 10, 2019.
  1. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Exactly what I’m aiming for!
    mat60 and Erik B like this.
  2. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    First impression, not impressed.
    I lit 3 of them in the grill to get the charcoal going. When I came back after 5 minutes only 1 was still burning. Not a particularly breezy day.
    865CA55F-902C-4983-8A9C-ED3BEA6205CD.jpeg 7AD3A205-08C9-4880-B1D5-245B2E76B9DF.jpeg
    I added 3 more and re-lit them. That worked but it really should have only taken two or three.
    TurboDiesel, billb3 and Chvymn99 like this.
  3. TurboDiesel
    So you used 30 matches?
    Seems a little much.
    JackHammer and yooperdave like this.
  4. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    The matches were garbage but yes it’s overkill.
    TurboDiesel likes this.
  5. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Dixie cups are doing a fine job
    828E17A0-97DD-4E48-A61F-19757DCD3602.jpeg 1AEA8917-16F7-44F6-AC10-7D5D2EE35B9E.jpeg
  6. chris
    chris
    SE WI
    i cheat , used mineral spirits and dry rotted wood cut into 3" x 1 x 1 or so pieces on band saw, toss pieces in bucket liberal application of mineral spirits. +no time to scrounge old candles ect and buying wax - too much cost. The spirits are from my parts washer- used in cleaning saw blades and sometimes chains. the pieces get stored in a coffee can( real can not the cardboard or plastic ones)takes about 15 minutes to make 3 coffee cans full.
    T.Jeff Veal and TurboDiesel like this.
  7. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Brings back memories. My dad used to bring home gallon jugs of mineral spirits from work to light the Kingsford charcoal in the Weber kettle grill and burn trash in the barrel.
  8. JackHammer
    JackHammer
    A few weeks ago I dumped a crock pot full of hot wax into some saw dust. So I have been chipping off some wax dust, putting an inch in a Dixie cup and lighting up. Seems to work well and I can add as much or as little as I want.
    I would have added it in the cup while it was still warm but I didn't have cups at the time of manufacturing.
    I tried some muffin cups too but those were very large and very messy.
  9. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    2nd run on the wax coated corrugated cardboard with matches. Set them sideways this time to try and get the wax burning faster. Helped a lot. If I did these again I think I’d submerge the entire piece of cardboard and the match heads. There’s a gap between the match heads and the wax now that may be causing these to stall.
    Still nowhere near a couple pieces of Supercedar…
    D0DE85DA-CAF2-44C1-A344-D8EDD6BC89B0.jpeg E1BD7CA2-152F-464A-ACA9-89BF654BAC9A.jpeg
  10. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    In case anyone wants to know what a box of 100 unwrapped Supercedars look like…
  11. billb3
    That's a lot of fire starting
  12. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Between the masonry heater being fired twice a day and the Jotul once a day I sometimes start 3 fires a day so they will go pretty quickly. I had a part time job that got me free newspaper but have long since let that go. These are so much better!
    1/4 Supercedar this morning on 4 splits of red oak and shagbark hickory with 2 pieces of pine kindling.
  13. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Trying some new glass cleaner soon too…
    Eric VW likes this.
  14. EODMSgt
    EODMSgt
    White Mountain Region, NH
    Just a little hack for matches in the event you ever want to try and get a little more kick out of them. Melt a ping pong ball in acetone until it's a gooey consistency and then dip the match head in the solution. Let it dry and then you'll have a much more potent match (it also works great for waterproofing your matches). One melted ping pong ball goes a long way and if the solution ever hardens in the jar, just add more acetone.
  15. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Unused envelope stuffed with paper scraps and 15 pumps of nasty hand sanitizer we got last year. Worked surprisingly well. [​IMG]
  16. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    My egg carton starters didn’t work as well as I’d hoped. Ended up using 2 or 3 per fire with a couple sticks of kindling. Dixie cups work MUCH better with shredded paper.
    TurboDiesel and Eric VW like this.
  17. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Found some new Swedish matches at Meijer this weekend. Smoother striking with none of the flaming bits I’ve experienced with the Diamond green tips so far.
    TurboDiesel, Eckie and Eric VW like this.
  18. Eric VW
    I’ve never had any kind of amazing success with shredded paper starters.
    We use cedar pet bedding chips and regrind in an old paper shredder. With a little ladled in melted candle remnants and cardboard egg cartons, they burn every bit as long as a 1/4 Super Cedar.
    :yes:
  19. TurboDiesel
    I can hook you up with hardwood shavings from the lathe if you wanna try them. No need for re-grinding. I keep a bucket full of fine stuff just for firestarters.
    Eric VW and yooperdave like this.
  20. Eric VW
    :handshake:
