Hitzer 354 test fire, install, first fire
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Hoytman, Jan 30, 2020.
  1. Well Seasoned
    You can get your point across, the member can read it and make their own decision, keeps the thread how the op intended it to be.
    Chaz, fox9988, wildwest and 1 other person like this.
  2. Eric VW
    Couldn’t say it any better. :yes:
  3. BHoller
    BHoller
    Central pa
    Ok the resources are the code books and the owners manuals. I can cite them when asked to but I cannot supply them for public use. But the second I mention codes here certain people go nuts.
  4. Eric VW
    Can’t link sites?
    Chaz and wildwest like this.
  5. Well Seasoned
    Add some general info here....
    Chaz, wildwest and Eric VW like this.
  6. Well Seasoned
    He means that the mfg sets precedence in clearances, then we go to fire code, kinda hard to reference all that. Alot of info.
    Basics would be good.
    Example- refer to stove data plate. If none, 3 feet clearance. When using a wall heat shield, clearance can be reduced by 66% down to 12" etc.
    Single wall 18" to clearance, dbl wall 6" etc
    WeldrDave, Chaz, fox9988 and 3 others like this.
  7. BHoller
    BHoller
    Central pa
    Yes I can link to sites. But unless I were to pay for an unlimited access licence I can't link to the actual code sites.
    And yes I can link to the manuals but why would I not do that case by case? Linking every manual in existence just is not realistic.
    So if you want I will make a recource saying if your stove is unlisted refer to the standards for unlisted stoves in nfpa 211. If it is listed follow your manual. Masonry chimneys go by irc chapter 10 and liner manufacturers instructions. Prefab chimneys go by manufacturers instructions. That's pretty much it.
    moresnow, Chaz and Well Seasoned like this.
  8. Eric VW
    That’s a pretty good start.
    Update your Resource thread as needed.
    WeldrDave, Chaz and wildwest like this.
  9. Well Seasoned
    I like it.
  10. BHoller
    BHoller
    Central pa
    It doesn't seem like I have the ability to post a recource
  11. Eric VW
    Does “Add Resource” not appear on your screen...?
  12. BHoller
    BHoller
    Central pa
    Yes but then it doesn't allow me to select a subject. And if I hit continue it just keeps asking for a subject
  13. Well Seasoned
    This on yours holler?
    Chaz and Eric VW like this.
  14. Eric VW
    Chaz likes this.
  15. BHoller
    BHoller
    Central pa
    Yes I get that but it won't let me select any of the categories
  16. Well Seasoned
  17. BHoller
    BHoller
    Central pa
  18. fox9988
    fox9988
    NW Arkansas 72717
    Blasting is a two way street, sharing opinions/info politely is another.
  19. Well Seasoned
    I'll look into it tomorrow. I need to figure out why it's doing that
    wildwest, Chaz, Eric VW and 1 other person like this.
  20. Well Seasoned
    I'm still working on some test resources to see what the problem might be with you opening it. Hang tight....
    wildwest and brenndatomu like this.
