High Temperature Alarm?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Well Seasoned, Feb 7, 2015.
  1. HDRock
    A single unit for $65 set to the proper temperature on your pipe, I think is cheap insurance, could save your house and your family.
    Its not that hard to get distracted while getting a fire going
    DaveGunter likes this.
  2. fire_man
    fire_man
    North East MA
    I agree. I'm choosing the AT100 Universal Thermometer and the TC-K-WA Washer Probe. I don't see the need for the remote siren with my house layout so I don't need the AT200.
    Total cost $56 + shipping - not bad!
    HDRock likes this.
  3. ChuckinMichigan
    ChuckinMichigan Banned
    Southeastern Michigan
    Isn't that the case with the PH too?
  4. HDRock
    the alarm that's built into the unit worked just fine for me.
    You will just have to set up some parameters on that unit, no big deal though
  5. DaveGunter
    DaveGunter
    Here is the response from the tech at Auber. Not sure what she means by "go into" I assume it's just button pushing on the front. This would be a great set up for me as my stove is in the basement and I find myself trekking up and down the stairs a lot just to check on things.
    Hi Dave,
    Each slave has its unique id set inside, the master unit can only show the temp of one slave at once. So for example, if you have slave 1 and slave 2; the master can be set to display either the temp on slave 1 or slave 2. And to do the switch, you will need to go into change the id in master unit.
    To purchase an additional slave unit, the price is $60 ea + sensor cost. You can check out with $60 FEE-SRV and a sensor with the AT210-Combo purchase on our website.
    Best,
    Azalea
    Auber Instruments
    www.auberins.com
    770-569-8420
    HDRock likes this.
  6. HDRock
    Yeah, going into it would be pushing some buttons.
    I haven't read the manual for the wireless, didn't know you could only display one at a time, so, you wouldn't need an extra slave unless you like had one upstairs and one in the garage or something like that.
    I don't understand $60 Plus sensor for a slave unit because, the slave unit has only one plug and that is for power.
    Yeah it would be perfect for stove in the basement situation
    You could do the same thing with the wired unit but you would have to run a long wire upstairs from whatever probe you have on the stove or pipe
  7. capetownkg
    capetownkg
    southern, MD
    Ok guys I am trying to decide what setup is good for me. My nc-30 is slammed in my fireplace with a flex SS liner. So is it better to have both pipe and stove top sensors or is one enough? I would ideally like a unit down by the stove with a temperature reading and a wireless unit upstairs in my bedroom so I can see what is going on in the night.
    So I am thinking about getting the wireless package one with a magnetic thermal couple for STT. This sound like the right setup? or should I get the washer k type thermocouple and drill it in the stove top?
    Wireless Thermometer, Thermocouple based [AT210-T] - $108.62 : auberins.com, Temperature control solutions for home and industry
    Truman likes this.
  8. HDRock
    Wireless Thermometer for Stove Pipe,Chimney,Outdoor Wood Boiler
    So is it better to have both pipe and stove top sensors?
    Depends what you want and want to spend , for both pipe and stove top, you would need 2 packages .
    Do you have a place on the pipe to put a washer thermocouple ? what kinda pipe , sw, dw?
    Can't really tell you what's best for you , I can only go by what I have but , I would use the magnetic probe for stove top , more money though
  9. capetownkg
    capetownkg
    southern, MD
    The pipe isnt super easy to get to since its in my fireplace. But after already (3rd day) having the ac16 fan start making a god awful racket. I am trying to get things together to pull the stove out and put a new fan on, build a convection deck and attach these alarms so i can get it all buttoned up before truly cold weather hits.
    papadave and HDRock like this.
  10. HDRock
    Thing is I don't know jack about your type of install.
    building a convection deck is very good idea , my stove comes with one and works great getting heat out into the room, don't know why they don't put em on all stoves, probably to keep costs down.
    Anyway , if my stove was in basement ,I would like to monitor both pipe n st with wireless
    EDIT Perfect opportunity to put what ever you want on there , if your going to pull it out
  11. Smokinpiney
    Smokinpiney
    "South" Jersey
    Hey sorry guys just saw this. Yes the slave unit connects to the probe and the master is wireless (other than the 110 plug). I have the slave in our bedroom directly over the stove in the basement (shortest run for the probe wire) and the master is in the living room across the house. Saves me from running to the bedroom to check temps all the time. Plus i can just roll over in bed and see what my temps are if needed.
    concretegrazer and HDRock like this.
  12. capetownkg
    capetownkg
    southern, MD
    Got my alarms and put it on the stove. Anyone else notice their alarms reading lower then it does with a ir thermometer? I have the magnetic connector and it reads 60 to 100 degrees lower then I get with my ir.
  13. capetownkg
    capetownkg
    southern, MD
    Like right now it reads 590 but with my ir it reads 670. Not really liking that discrepancy
  14. Well Seasoned
    I am ordering one this week finally. Looks like Aubers brand is the way to go HDRock swags and Smokinpiney
    Do any of you suggest just the stove top one or chimney as well? Thx
    HDRock likes this.
  15. HDRock
    Yeah , from what I've read the magnetic probes all do that , mine is 60, 70 degrees low , pipe probe is more accurate.
    Just compensate when you set alarm temp.
    I was thinking I might change Configuration Parameters to compensate for temp difference .
    2. PSb. Calibration offset. PSb is used to set an input offset to compensate the error produced by the sensor. For example, if the meter displays 5 ºC when probe is in ice/water mixture, set PSb= -5, will make the meter display 0 ºC.
    papadave and Well Seasoned like this.
  16. HDRock
    I like having both ,but if I was to only have one ,It would be on the pipe
    Well Seasoned and Smokinpiney like this.
  17. Smokinpiney
    Smokinpiney
    "South" Jersey
    I have the wireless unit (internal probe) for my flue temps. Im planning on ordering the magnetic probe for the stove top soon.
    HDRock and Well Seasoned like this.
  18. swags
    swags Moderator
    I only have the pipe probe, the reason I did that was I have made a mistake a few times and forgot to close the bypass. So if that happens the pipe will heat up much faster and this will save me from a big oops.
    Well Seasoned likes this.
  19. fire_man
    fire_man
    North East MA
    When you say "Pipe Probe" do you mean the magnetic one?
  20. swags
    swags Moderator
    No mine is a probe that sticks inside the pipe. I drilled a small hole for the probe.
    HDRock, Well Seasoned and papadave like this.
