High temp silicone
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Geek, Oct 29, 2015.
  1. subsailor
    subsailor
    Winthrop, Maine
    I just looked at the tube again. It says High Temp Silicone. Withstands temps up to 2000*. Interestingly though, Rutland's website only shows a 500* and 600* for their high temp silicone.
    bogieb, CleanFire and slvrblkk like this.
  2. jtakeman
    Sub, You might have bought the gasket cement. This is used for sealing inside the firebox and is really hard when dry.
    Rutland Products
    Russell, slvrblkk and CleanFire like this.
  3. CleanFire
    CleanFire
    That should work just fine Geek.
    Just so the folks know, if you can't find High-Temp RTV at the local hardware / Box store,
    an Auto Parts store is your friend -
    Permatex High-Temp RTV is rated to 600 degrees,
    Permatex Ultra Copper is rated to 700 degrees,
    and both are essentially the same as the Rutland 600 Red RTV gasket product ..
  4. CleanFire
    CleanFire
    +1 JT - Sub, you would have to chisel that stuff off (if it is the cement), had to use that on a firebox repair years ago - strong stuff - .
    slvrblkk likes this.
  5. subsailor
    subsailor
    Winthrop, Maine
    Well if that's the case the guy at the hardware store don't know chit. I bought it and was sitting in my truck and questioned whether or not I had the right stuff and went back in the store. He showed me a kit they sell of rope gasket and silicone and said what I bought was the same stuff as what was in the kit.
    Fortunately I only had to repair a 2 inch section of the door gasket that had come loose, but it sounds like that is going to be a PITA to get out next year.
    eatonpcat, bogieb, CleanFire and 2 others like this.
  6. CleanFire
    CleanFire
    It will come off, but you may be using some muscle and a hefty screwdriver / or a dulled chisel to scrape - using a Dremel tool w/ some precision will speed things up considerably, speaking from experience.
    eatonpcat, bogieb and slvrblkk like this.
  7. subsailor
    subsailor
    Winthrop, Maine
    I went to Rutlands site again. It is the cement.:(
    eatonpcat, smoke show, bogieb and 2 others like this.
  8. CleanFire
    CleanFire
    No worries Sub, just will take a little longer to clean up on next gasket change - at least you know that section is staying on there this season! :yes:
    subsailor and slvrblkk like this.
  9. jtakeman
    Its often used in wood stove door gasket kits. Wood stoves get much hotter than a pellet eater. Only place I've used this on pellet eaters is inside the stove near the burnpot or drop chute. Like CleanFire say's you'll need a chisel to get it off later. Or wire wheel on a drill or dremel tool.
  10. Geek
    Geek
    My plan is to twist lock the pipes really well and place a bid of silicone on the junction outside, not planning to put silicone inside.
    CleanFire and jtakeman like this.
  11. jtakeman
    Thats what I'd do as well. Plus seal the seams too. PV most likely will leak at the seams as well as the joints.
    Don't forget to fill the area on the adapter. It leaks like a sieve where you can see between the inner and outer area.
    bogieb, Geek, CleanFire and 1 other person like this.
  12. CleanFire
    CleanFire
    If that makes you feel comfortable w/ the install Geek, then go for it - that's what you should do.
    bogieb and imacman like this.
  13. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    There are several 2000 degree items that are actually cements, they are not sealants, I have used various 2000 degree cements for things like returning an old gravity hot air coal furnace to operation and they can actually bond metal to metal in some instances. The gasket cement I use is a 2000 degree product from Rutland. I would never expect to get anything apart that was joined with that stuff without likely damaging at least a bit of whatever was joined together. I have an unopened tube of some "furnace" or "retort" cement also a 2000 degree item.
    CleanFire, bogieb and imacman like this.
  14. krooser
    krooser
    Waupaca, WI
    Any auto parts store will have it. Even Wally World carries it...
    CleanFire likes this.
  15. ttdberg
    ttdberg Pellet Pig
    CT
    Question for you guys, after all this talk about the 2000 degree cement Sub got for his door gasket. I have done gasket jobs on my wood stoves in the past and it was always done with the super cement sub got. Now, I have never done a gasket job on a pellet stove, because neither of my stoves have needed it done yet (knock on wood). However, if/when they do, I would have just naturally gone ahead and used the exact same super cement. Getting the impression from this thread, that is not correct. So...what is it that's used to hold the gasket in place on a pellet stove? The same Rutland 500 / 600 degree silicone you use to seal flue joints?
  16. imacman
    imacman
    Denver, NC
    AFAIK, all the stove manufacturers use the high temp silicone. When I replaced the gaskets on both of my stoves, they had silicone holding them right from the factory.
  17. Lousyweather
    Lousyweather
    I don't believe that's silicone....so wont stay flexible. The problem with stuff that gets hard is that with the expansion and contraction of the vent pipe, it may crack and leak, which tends to be bad.
    If it isn't seen, I like Super red, if on black pipe, then black RTV, galvie pipe would be clear. Rutland makes all 3, in small squeeze tubes and larger caulking gun tubes.
  18. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    I have tried our local Ace store and they have the full sized calk tubes of high temp black.
    Waaaaaaaaaaay tooooooooooooooooooo large a quantity.
    I headed over to the Napa next door and get the small tubes in Black, Red, Copper color
    eatonpcat, imacman, bogieb and 2 others like this.
  19. CleanFire
    CleanFire
    Welcome Snowy Rivers!
    Nice to see you here!
    bogieb, Russell and imacman like this.
  20. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    The other joint was getting a tad stale.
    I still frequent the place but I enjoy a variation of chat.
    bogieb and Russell like this.
