Hickory
Discussion in 'The Wood Pile' started by ReelFaster, May 24, 2018.
  1. TurboDiesel
    Welcome to the club, modenacart ! :handshake:
    I think you're going to like it here!
  2. modenacart
    modenacart
    New Bern
    New Bern is a nice place.
    I have heard not to use green wood a lot but I am still not convinced it is a rule. It would be nice to do a bunch of blind taste tastes to settle it. Until then it is conjuncture. It may be true but we don’t know.
  3. modenacart
    modenacart
    New Bern
    I think so. It is nice to share as much as we can.
  4. modenacart
    modenacart
    New Bern
    I am surprised the soaking myth continues. It it were true, uncovered firewood would never dry.
  5. WeldrDave
    It's like the basic rule of the "fire triangle" To get combustion you need three things, heat, fuel and oxygen. You will still get "minimal" combustion in the smoldering effect with little oxygen input which is what you want. More O2, more fire! :fire: Trick is to keep down the oxygen.
  6. WeldrDave
    I have "never" covered my firewood in 40 years! I bakes in the sun outside. Wood "wicks" when drying and some simple physics makes it happen, heat expands, cool contracts. Put air across anything and it will dry, perfect example: hanging your clothes on the line. The only time my wood is covered, (and only so it doesn't get wet or snowed on) before it comes into the house, it goes into our winter wood shed. I have 4 and 5 year old wood outside right now with a moisture content of around 10%
  7. WeldrDave
    Smoker #5. All have been built the same way. I usually get 5 to 8 years out of a tank, they rot out and I build another. :)
  8. billb3
    Um, you kinda just proved his point.
  9. WeldrDave
    Noted! But I was making a point also about soaking wood, it may get wet externally, but it will still be dry inside.
    Got long winded!
    Backwoods Savage and modenacart like this.
  10. stuckinthemuck
    stuckinthemuck
    Makes sense. So resist the urge to take a peek every five minutes as that could heat things up. Separate note, now that you are retired can you change your name back to USCGDave or do you have to leave it as is to get your retirement check?
  11. WeldrDave
    I can, but why? The main reason why I changed it was because we had an @$$HOLE of a CO and "SUPER" politically correct, and didn't want ANYONE to have any affiliation in any forums or social media. I do not do face book or any such stuff but this individual would scan the forums and have our XO report anything military related. I was senior enlisted and was told that, "Quote" It would be best for you to not advertise your affiliation with the USCG. Basically the Command didn't want any thing coming back on them. I think he saw the site one time after over hearing a conversation I was having with someone about firewood and burning in the shops. I said Ok and carried on! I wasn't about to lose a pension or get busted back over some so trivial. Anyway, thats it in the nut shell.... I was a HP and coded welder all my life so it fit as well.
    Chaz, stuckinthemuck and ReelFaster like this.
  12. ReelFaster
    ReelFaster
    S.Jersey
    Great info guys, I have been reading a lot about trying to burning a clean fire with less white smoke. So to achieve this less oxygen?
    WeldrDave likes this.
  13. modenacart
    modenacart
    New Bern
    Some of it is time. Some of the smoke are volatiles that just need to burn off. Not every agrees that you need to wait until they burn off.
    ReelFaster and WeldrDave like this.
