  1. Stinny
  2. bogieb
    Welcome to the Beer Side Ambient!
    ivanhoe, imacman, Ambient and 3 others like this.
  3. Ambient
    Ambient
    Northern New York
    Thank You all for your warm welcome!
    ivanhoe, CleanFire, imacman and 3 others like this.
  4. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
  5. eatonpcat
    Welcome Snowy and Ambient!
    CleanFire, ivanhoe, imacman and 2 others like this.
  6. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
  7. CleanFire
    CleanFire
    Belated welcome Snowy and Ambient - nice to see you both here. :yes:
    You'd be proud Snowy, side panels are off the stove now, had to trace an electrical issue: stove switched into "Final Cleaning" on it's own a few times over the past week, was a bit concerning (to say the least).. Lots of DVOM testing here.
    Traced the problem down to the door switch, on this stove there is a latch gate mechanism, screwed to the side of the stove (acts as a pivot point), that raises the latch gate to engage a magnetic reed contact switch when the door latch is closed, completing the circuit.
    Issue was a worn / failed shim at the pivot point, allowing too much movement / play of the latch gate mechanism, preventing reliable switch contact.
    Fix was a new washer at the pivot point, with some lithium grease. Seems to be running ok, on day 2 now.
    The Ecoteck stove is fully programmable, but is a lot of work to tune and run -
    I like your reliable, industrial-grade quality "old school" controller solution(s) much better. :yes:
    Ambient, ivanhoe, imacman and 3 others like this.
  8. ivanhoe
    ivanhoe
    Northern Ontario
    Welcome Ambient, grab a seat next to the fire and make yourself at home:campfire:
