Hey buddy, will you give me a lift?
Discussion in 'Chainsaws and Power Equipment' started by brenndatomu, Jul 23, 2023.
  1. eatonpcat
    Any chance that you were running the splitter for JRHAWK9's buddy that day??
  2. brenndatomu
    I was waiting on this comment...:rofl: :lol:
  3. brenndatomu
    Well, I bought this Huskee 22 ton (what was left of it) on March 5th, and today was finally the maiden voyage in her new configuration...pretty happy with it, only had a couple minor issues...couple fittings need tightened up a bit more, that kind of thing.
    Another one was that the hose between the auxiliary and the main hydraulic oil tanks was not gravity flowing enough oil to keep up... overflowed the tank...but nothing a rubber expansion plug didn't fix. That allows the auxiliary tank to get pressurized, then the hose tying the two together keeps up fine. The main tank is still vented, and that's all that's really needed anyways.
    The cylinder cycle time calculator that I used showed a theoretical cycle time of 8.2 seconds round trip (assuming 100% pump efficiency) but I knew it wouldn't be quite that fast...so anything under 9 seconds was my actual goal, which was met, it came in 8.8 seconds (and the oil was still cool too!) not bad since you'd spend a minimum of $4k to get into a commercial splitter that would be that fast!
    The 8HP 301cc Predator doesn't even grunt when I hold it against the relief valve...I really think a 6.5HP 212cc would have done the job...which is good, because that means that the "5HP" electric motor that it will wear most of the time is even more likely to have enough butt to do the job...I was a little worried because it is only a 16 amp motor, which is more like 4 HP realistically (its an air compressor motor, they are notorious for "over rating" those) when comparing electric to gas, most people say that its takes 1.5X to 2X the rated gasoline engine horsepower to accomplish the same work. (electric has more torque)
    I did back the relief valve setting down a bit, it was set at 3300 PSI (surprisingly) and I took it down to about 2500, which is what the hoses my neighbor made for me are rated at for working pressure (I thought they'd be at least 3000, but I forgot to verify with him before he made them) oh well, 99% of the time you never even get over 1500 PSI with most wood anyways...I "cut" (sideways) an 8" ash log in half with it today and never saw over 2000 PSI! But I was mostly splitting cherry today, and those rounds barely even made the 0-5000 PSI gauge come off zero before they popped.
    Speaking of the hoses, I went to see the neighbor to pick up a piece of return hose today and asked him if he had my bill for all this figured up yet, he says "how about going over my bike for me, and maybe putting a new rear tire on?" Barter...I like it! :yes:
    Ok, enough yackin, time for some pics! :ithappened:
    IMG_20231216_163440032.jpg Just rolled up, lift support leg dropped onto the splitter foot.
    IMG_20231216_163611070.jpg Cable attached, ready to go.
    IMG_20231216_163724954.jpg I don't have any big stuff on site currently, but you get the idea.
    IMG_20231216_163802063.jpg Ready for action.
    Screenshot_20231216-201033.png And the results...made a couple videos of it running, but I don't have a YT account, so I guess no way to post them up here?
    Stinny, Eric VW, T.Jeff Veal and 17 others like this.
  4. Screwloose
    Screwloose
    That looks pretty sharp!
    Stinny, Horkn, Chaz and 2 others like this.
  5. Canadian border VT
    How high th the work table from ground
    looks beautiful
  6. brenndatomu
    Thanks!
    Stock height for a Huskee 22ton... sorry, I didn't measure it...it could probably be a couple inches taller for me, but it's not terrible, I'll just park it on some blocks if it's an issue...
  7. Chaz
    Chaz
    Southwestern NY
    Slick work Dave.
    :cool:
    Great job.
    :handshake:
  8. brenndatomu
    Thank you sir!
    As usual, I way underestimated how long it would take! :picard:
  9. Chaz
    Chaz
    Southwestern NY
    Isn't that always the case?
    :doh:
    Cruizin along nicely, then WHAM, life gets in the way.
    :hair:
    Horkn, Screwloose, walt and 2 others like this.
  10. The Wood Wolverine
    Really cool build! Would it be possible to add a pressure gauge like that to my Huskee?
  11. brenndatomu
    Thank you!
    Yes sir, just add this to the inlet side of the control valve.
    5602-12-12-12 Tee Hydraulic Fitting, 3/4" NPT x FP x FP, Pipe Adapter | eBay
    Then get a 0-3000, or 4000 PSI gauge. I bought a 0-5000, but really won't need that high, it works fine, just harder to read small changes with one that high.
    2.5" LIQUID FILLED PRESSURE GAUGE 0 - 4000 PSI, STAINLESS STEEL CASE LOWER MOUNT | eBay
    Horkn, Screwloose, Chaz and 3 others like this.
  12. brenndatomu
    You'll have to make sure that you can use a 3/4" tee like that Wood Wolverine but you should have the same Energy control valve that I have...even if you have 1/2" lines (probably do) you'd just move the bushing/adapter from the valve to the tee...
    Here is a lil closer pic...
    Horkn, Screwloose, Chaz and 5 others like this.
  13. eatonpcat
    Very nice, fishing pole holders!
    Horkn, Screwloose, Chaz and 4 others like this.
  14. brenndatomu
    Hey, I'd be willing to give that a whirl! And if I caught a whopper, I could pick it up on the lift! :thumbs:
    Horkn, Screwloose, eatonpcat and 5 others like this.
  15. brenndatomu
    Oh, and you can see in the pic there, I used a 3/4" to 1/4" pipe bushing to adapt the gauge...
    Horkn, Screwloose, eatonpcat and 3 others like this.
  16. JRHAWK9
    JRHAWK9
    Wisconsin
  17. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Very nice build, great pictorial, thanks for posting all of your work.
  18. Screwloose
    Screwloose
    I'm not sure why you think that it took so long........I bought the motor for my electric conversion probably over 5 years ago!
  19. Horkn
    Excellent work!
  20. brenndatomu
    Thank you.
    Well, I guess it just took a lot longer than I imagined it would...and once I sold my Champion to my boss this summer, I knew I had to get this done sooner rather than later...otherwise my "too be split" piles would quickly get out of control, at least by springtime anyways!
    Plus, I still don't have the electric motor wired up yet either...that's next! I'm off next week, we'll see what happens...
    Chud, Screwloose, Horkn and 4 others like this.
